E3 Plug Update
4 replies to this topic
#1 fedora OFFLINE
fedora
  • 48 Thanks
  • 55 posts
Posted June 09, 2013 - 12:53 PM
Hello all,
A while ago, I asked about the E3 spark plugs, and just tried them in my string trimmer and push mower.
In the trimmer(poulan pro 125)(replacing a champion RCJ6Y plug), it started in 2 pulls vs. 10, I didn't notice any power gains, but it does idle a little higher and it doesn't bog down under throttle for the first minute anymore.
In the push mower(cub cadet 6.5 hp)(replacing a torch plug), it starts quicker(electric start) and has a noticeable power gain.
I won't be checking for any reduction in fuel usage, I have no base to go from, and I burn less than a gallon or 2 in each per year. The starting, idleing and power gain could  be from being new plugs, but I'll keep an eye on them and report back if I find anything else.
  • hamman, New.Canadian.DB.Owner and LilysDad have said thanks
#2 KC9KAS ONLINE
KC9KAS
  • 5,384 Thanks
  • 4,692 posts
Posted June 09, 2013 - 02:19 PM
A fellow in my Gold Wing motorcycle club stated he has installed these plugs (E3's) in his M/C and can tell a increase in performance.
#3 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted June 09, 2013 - 02:30 PM
Just be MAKE SURE to fill out the warrenty card and send it in.  We used them once in a 9,5 Saab with bad results
#4 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted June 10, 2013 - 07:47 AM
That would be the real test, see if the benefits are still there with a regular new plug.
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,324 Thanks
  • 9,790 posts
Posted June 10, 2013 - 11:16 AM
It's possible with the multi point design that it is less likely to gas foul on start up.
