314 Sleeve Hitch
5 replies to this topic
#1 rainman_210 OFFLINE
rainman_210
  • 22 Thanks
  • 16 posts
Posted June 09, 2013 - 08:45 AM
Hi fellas...bought a sleeve hitch for my 314...when i go to connect the lift rod to the lift shaft bracket on tractor the rod gets wedged up against the neutral detent bracket bolt on side of transaxle...am i sposed to bend the lift rod around that bolt?....thanks in advance for any advice2013-06-09_08-29-27_849.jpg 2013-06-09_08-29-43_526.jpg 2013-06-09_08-29-27_849.jpg
  • Texas Deere and Horse, larryd and JRJ have said thanks
  • 14,889 Thanks
  • 15,514 posts
Posted June 09, 2013 - 11:43 AM
I maybe wrong, but that rod doesn't look like the right one. If you look at page #9 of this drawing, it has has all the dimensions for the right lift link.
http://gardentractor...-square-fender/
  • larryd said thank you
#3 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 09, 2013 - 11:44 AM
Does the other end have a bend in it? Maybe you installed it backwards?
#4 xshooter OFFLINE
xshooter
  • 34 Thanks
  • 93 posts
Posted June 09, 2013 - 07:55 PM
It looks like you have a lift rod for an early 120/140. The newer tractors need one that has a bend in the front and the slot cut in at an angle.
#5 rainman_210 OFFLINE
rainman_210
  • 22 Thanks
  • 16 posts
Posted June 09, 2013 - 09:18 PM
thanks texas and shooter....you both are correct I have the wrong lift rod
#6 jimbobbillyray ONLINE
jimbobbillyray
  • 3,169 Thanks
  • 2,938 posts
Posted June 09, 2013 - 11:29 PM
Here is a pic of the sleeve hitch lift arm/rod you need and a pic of it installed.
