Kohler Magnum 8
7 replies to this topic
#1 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted November 05, 2010 - 03:46 PM
I have no rectifier on my '86 Wheel Horse 308-8 it only has metal filler plate to cove the hole up no wires leading from the charging system so how does it charge the battery ?
#2 caseguy OFFLINE
  • 1,629 Thanks
Posted November 05, 2010 - 05:36 PM
I just uploaded the manual for it to the manuals section. Here is a direct link to it:
Magnum 8 - Manuals - Garden Tractor Talk
Hope this helps you figure it out. If it doesn't, some pictures might be helpful.
#3 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted November 05, 2010 - 06:29 PM
I will try it out the manual section Thanks . Ben
#4 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted November 05, 2010 - 06:49 PM
Caseguy , I have the same Kohler Magnum Service Manual for 8 , 10 , 12 , 14 , 16 HP brand new not some reprint I ordered from OPEENGINES.COM . my engine should have the 3 amp charging stator ( 2 poles ) or 1.25 amp charging stator ( 2 poles )
maybe the 15 amp stator and rectifier - regulator . ?
#5 caseguy OFFLINE
  • 1,629 Thanks
Posted November 06, 2010 - 04:07 PM
Is there a way to get a pic of the left side of the engine shroud, looking from the flywheel end of the engine? As near as I can tell from the drawing, there should be a single, small black wire going to the keyswitch for either the 1.25 amp or the 3 amp unregulated system. If you have the optional lighting circuit, there will also be a yellow wire coming out with the black one. There is no way to tell which system you have unless you have the tractor manufacturers book and it specifically says which one was used. Of course you could take the flywheel off and look at it. That's the best I can do without seeing it. Sorry I'm not being more helpful.
#6 GWest OFFLINE
GWest
  • 553 Thanks
  • 504 posts
Posted November 06, 2010 - 04:37 PM
According to service bulletin 301G the 1986 308-8 has a 1.25 amp charging system.
Adding - a look at the wiring diagram shows the AC circuit (dark green wire) for the lights plus a rectified but unregulated circuit (white wire) to charge the battery. I don't know how they come up with 1.25 amps.
Garry
Edited by GWest, November 06, 2010 - 04:42 PM.
#7 caseguy OFFLINE
  • 1,629 Thanks
Posted November 06, 2010 - 08:19 PM
Garry
I don't have a copy of that service bulletin. The one that I quoted was from the Kohler website. Sorry if I've misled.
#8 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted November 08, 2010 - 01:11 PM
Garry , I thank you for answering my question about if the '86 308-8 had a rectifier only the 1.25 charging system . Ben
