Another Question On John Deere Stx 38
3 replies to this topic
#1 slime OFFLINE
slime
  • 4 posts
Posted June 08, 2013 - 10:43 PM
As I mentioned in another post, I just got a John Deere STX 38, Model M00STXB010979 riding mower with Gear Drive 4 speed.  Do not have an operator's manual.  My question is should the clutch be engaged when turning the solenoid switch on to engage cutting blades?  Also, is it ok to leave blades engaged when backing up?  Thanks.
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,798 Thanks
  • 4,292 posts
Posted June 09, 2013 - 03:57 AM
hi slime, do you have a pic from the rm? you can post it with the [ More Reply Options ] button down on the right side
  • slime said thank you
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,269 Thanks
  • 10,111 posts
Posted June 09, 2013 - 04:36 AM
Clutching is not required when engaging the blades.
There is no problem with backing up with the machine with the pto engaged.
#4 KC9KAS OFFLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted June 09, 2013 - 09:35 AM
Some mowers have a safety switch that will kill the engine if the mowing deck is engauged and you try to operate in reverse.....just saying.
