Ss12 New Ign Switch
26 replies to this topic
#16 MH81 OFFLINE
Posted June 10, 2013 - 02:13 PM
Are you sure Dale's system requires the juice to the new module he builds? I know his is supposed to be drop in replacement for the old SSI modules.
That's why I keep asking... something tells me it's supposed to be unpowered...
Did the new unit come with an installation book or anything?
  • TAHOE said thank you
#17 TAHOE OFFLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted June 10, 2013 - 04:26 PM
Yea, I think the only change to the wiring other than maybe connector is Dale recommends adding a diode to one of the wires to keep juice from feeding back in to his module. Other than that, it is a direct bolt in using the stock switch meaning..... a switch with a grounded M needs to be used, not a coil/battery style switch.
#18 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted June 10, 2013 - 08:42 PM
Dales ign has cleared customs, so I should have it in my hands within the week.  If you read here...... http://www.overnight...les/Page682.htm  You will have a better understanding of what his ign needs.
H
  • DH1 and MH81 have said thanks
#19 MH81 OFFLINE
Posted June 10, 2013 - 09:16 PM
That's what we were looking for. It needs 12v supplied.
The Tecumseh HET has been in production since 2005. It is meant to be a simple bolt in replacement for OEM 610759/610760 ignition components at left for HH100 & HH120 models. It will fit all other models equipped with these components as long as a 12V battery is available.
HET is short for Hall-Effect-Trigger, and is a battery powered ignition that does away with aging OEM CDI (capacitive-discharge-ignition) components.
All that you will need to provide is a switch to turn the power on and off to the system. The stock ignition switch only provides ground or open, not 12V. A separate toggle/other switch rated at a minimum of 5A is suggested.
This means that the ignition switch for a sears with an Onan would work. You will want to trace out the charging circuit just to be safe.
  • redb4 said thank you
#20 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted June 10, 2013 - 09:30 PM
Can you tell me the model numbers of the Onan equipped tractors?
Thanks
#21 MH81 OFFLINE
Posted June 10, 2013 - 09:37 PM
Thanks
Yes, at least one of them... give me a minute.
#22 MH81 OFFLINE
Posted June 10, 2013 - 09:39 PM
917.25191 is the 18/6 model.
917.257082 for the 19.9
The switch seems to be :
Switch
PART NUMBER: 2683R
#23 TAHOE OFFLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted June 11, 2013 - 08:21 AM
Good, glad we all figured that out correctly :smilewink:  You have the older first generation style CDI, I'm used to working with the later model that has triggers on outside of flywheel, I know those are direct replacements and do not require 12+v to power.... my confusion
I'm running the Blue coil on my 16 :thumbs:
#24 MH81 OFFLINE
Posted June 11, 2013 - 11:40 AM
What switch are you using?
#25 TAHOE OFFLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted June 11, 2013 - 12:08 PM
My stock switch started getting a short in the kill circuit so I just unplugged the M ( kill wire) and added a toggle switch to power the coil. I normally turn key off then flip toggle to kill motor.
#26 redb4 OFFLINE
redb4
  • 39 Thanks
  • 61 posts
Posted June 11, 2013 - 12:16 PM
From what I can see it looks like the 18/6 uses a start solenoid, similar to the Ford one I was thinking of using.  Can anybody confirm this?
#27 MH81 OFFLINE
Posted June 11, 2013 - 01:32 PM
I do know there is a solenoid in there on my 18/6 engine.
