Homemade Mig Cart
11 replies to this topic
#1 Ryan313 OFFLINE
  • 3441 Thanks
  • 5250 posts
Posted June 07, 2013 - 01:27 PM
My Dad bought a Hobart Handler 135 about 10 years ago; with the welder he bought a cart for it. The Cart was very flimsy, and could not support the weight of the welder and shielding gas cylinder; once the cart bent up good he added supports to it and made it stronger, but still pretty weak. One of the places he worked at years before re-purposed a shopping cart, and he really liked that, so he ended up paying a few dollars for a shopping cart when a local store went out of business. The cart sat for years in the garage with stuff in it, and was never made into a welding cart. Last summer during one of my cleaning raids in the garage I went through everything in the cart and I was going to make it into a welding cart; although, I never got a chance to until last night, when I decided to start.
Here was the starting point.
AD02C6C3-E26A-4962-A2BF-7F56B026B4F2-405
The first step, was to cut the pins that held the basket on.
8FBA68E2-EE29-4CD7-AFEB-B682CFB02C21-405
With the basket of, I cut off part of the bottom. I also unbolted the front wheels, which also took off the bottom basket.
51BCD48B-7C7F-4263-AB61-BBEDB93036EC-405
I did not need, or want the cart to be as wide as it was so I bent the sides in so they where parallel to each other. Since the sides where bent in, the wheels did not face forward, so they had to be cut off. I also shortened the rails about 5 inches.
8860EBCE-5B5B-45C0-B482-195B55FC8CAF-405
I cut out a section of the basket, and welded it in.
EDDD8FF4-9BDA-4764-AD24-4171853E6B16-405
Then, I welded the rear wheels back on, and bolted the front on again. I also made something to hold the gas cylinder; I used the back rest of the child seat. All I did was put a bend in the middle, and weld it on.
EA51FB60-340D-4069-897E-F78C237636C1-405
All I have to do now is make something to wrap the leads around.
  • daytime dave, Texas Deere and Horse, hamman and 2 others have said thanks
  • 15114 Thanks
  • 15570 posts
Posted June 07, 2013 - 01:32 PM
Looks good Ryan, :thumbs: Make sure the bottle support is strong enough for the bottle. I hate breaking gauges and regulators. :wallbanging:
  • Ryan313 said thank you
#3 twostep OFFLINE
twostep
    Rockstar
  • 1994 Thanks
  • 2541 posts
Posted June 07, 2013 - 01:50 PM
yup, X2 on the tank holder. It needs some more beef.
When I first saw the picture I though You were going the same route I went. You cut a lot more out of yours though. That powdercoating is nasty stuff, hard to get off and stinks when it starts burning!
  • Ryan313 and JRJ have said thanks
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3791 Thanks
  • 3907 posts
Posted June 07, 2013 - 02:42 PM
Since Brian pointed it out, Would not the push handle loop make a stronger tank support?
Don't cut it too short, I think you would want it higher that the center of the tank so it can't lever over the top.
Edited by JD DANNELS, June 07, 2013 - 02:44 PM.
  • Texas Deere and Horse and Ryan313 have said thanks
#5 Ryan313 OFFLINE
  • 3441 Thanks
  • 5250 posts
Posted June 07, 2013 - 04:06 PM
Actually, the cylinder support is MUCH stronger then it looks, it will be plenty to hold it in place, it is really pretty sturdy.
I could have made something better to hold the leads, but I wanted it to be made 100% out of the cart; this is what I came up with.
7CDFE025-F88D-4F6A-BF24-1A39FCD9FC06-439
It holds everything nicely!
5087313F-AFD0-4B68-95A4-B859DD4B02A8-439
71219A8D-357D-43B0-92A4-C30BF773E6AE-439
I did not put a push handle on it, because I do not really need one. For the most part, it is going to stay in one spot; if I do need to move it, it will only me moved a few feet if the gun does not reach, which will not happen often.
  • daytime dave, Texas Deere and Horse, hamman and 1 other said thanks
#6 Texas Deere and Horse OFFLINE
  • 15114 Thanks
  • 15570 posts
Posted June 07, 2013 - 04:32 PM
That should work good for the short bottles like you have. I use C-125 bottles and they are about 4' tall and very heavy.
Nice job Ryan !! :thumbs:
#7 daytime dave OFFLINE
  • 5478 Thanks
  • 6780 posts
Posted June 07, 2013 - 04:40 PM
It looks really good Ryan.  Nice job  :thumbs:
#8 backwoods OFFLINE
backwoods
  • 2699 Thanks
  • 2834 posts
great work on the cart ryan looks cleaner having it like that then the cords wrapped around the top of the tank or how ever else most people have them
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3791 Thanks
  • 3907 posts
Posted June 07, 2013 - 08:08 PM
Yeah thats the size tanks they used in the factory and what I was thinking about. You would want a bracket about 3 ft tall to prevent them from falling over.
#10 twostep OFFLINE
twostep
    Rockstar
  • 1994 Thanks
  • 2541 posts
Posted June 07, 2013 - 09:33 PM
Looks good!
#11 Team_Green OFFLINE
Team_Green
  • 2214 Thanks
  • 2305 posts
Posted June 07, 2013 - 11:49 PM
Looks good.. But it makes my back hurt thinking of bending down to use it....
#12 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 7214 Thanks
  • 3095 posts
Posted April 26, 2014 - 02:25 PM
Turned out really nice Ryan. Good job.        Roger.
