Today's Haul
cub 1710
2 replies to this topic
#1 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted June 06, 2013 - 11:45 PM
Picked up the reminants of what I believe is a 1710 today. Basically the same as my 682 but a yellow CCC version. No hood and no side panels. The series two KT-17 is appart and one of the pistons is seized in the jug. Seems to still be lots of good parts. With no headlight assy, grille, hood & side panels and the engine in pieces I don't belive it's worth working on... other than to part out.
Deck spindles seems decent. I plan to keep the hydro for a backup and there are a coupld of other little things that I might keep but if you need any parts off of this thing let me know. The rear rims and tires seem to be in really good shape. The fender pan is also in good shape. There is a little bit of surface rust but no rot to speak of...
Pic's to follow.
Edited by twostep, June 07, 2013 - 02:05 PM.
  • hamman, jd.rasentrac and Arti have said thanks
#2 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted June 08, 2013 - 10:13 PM
Well here it is... The seat is actually better than the one on my 682 plus it is original cub so I'll keep that. Not sure of the hydro but I plan keep the whole rear end with the good rear wheels/tires. The frame, dash plate and tins are in pretty good condition.
If you need any parts off of this (besides the rear axle and wheels/tires) let me know. You'll be surprised how cheap I will sell this stuff. I'll keep adding stuff as I find it.
Parts that are for sale:
Seat hinge/brackets
Rear fender pan
frame
grille frame
firewall
gas tank
drive shaft
Dash cover
hour meter
amp meter
throttle cable
hydro linkage
hydro lever
speed control knob
steering column
steering linkage
front axle
wheels (front) with tires that hold air)
tail light
battery box
deck level knob
deck lift handle
KT17 Series 2 engine parts (fuel pump, magnito, starter, etc.)
KT17 muffler w/exaust manifolds
50C mower dack (deck is rough in the middle but spindles seem decent
Mule drive and mower frame
Edited by twostep, June 08, 2013 - 10:21 PM.
#3 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted June 11, 2013 - 09:28 AM
I was going to modify the above post to clean it up but can't seem to find the "edit" button.
Anyway, here is the classifieds link.. I hope to get my money back and be able to save a couple of parts for spares/future projects.
http://gardentractor...cub-cadet-1710/
  • LTD said thank you
