Lawn Tractor Stopped Running
electrical battery solenoid engine starter
19 replies to this topic
#1 Chet OFFLINE
Chet
  • 2 Thanks
  • 14 posts
Posted June 06, 2013 - 08:03 PM
Simplicity lawn tractor #1686814 with 40 inch deck.  Stopped running while operating, would not re-start. Belts fine and deck fine.  Oil levels fine. Determined battery low, fully recharged but wouldn't hold charge over night.  New battery installed, would not turn over.  Started using my car battery, ran ok.  Confirmed that new battery was good-still will not turn over.  Get click or whining sound.  Did overfill gas tank prior to mowing.
Any suggestions on the next move?
#2 olcowhand ONLINE
  • 41,237 Thanks
  • 31,440 posts
Posted June 06, 2013 - 08:28 PM
The "click" is simply the starter relay solenoid.  Whining sound is usually the starter unable to overcome compression, either from weak/worn starter, weak connection, or automatic compression release not functioning properly, or severely flooded engine causing "hydro-lock".   Many times a worn out starter will work decent with a high amp battery pushing it, but the small GT batteries won't.   What make/model is the engine?
  • Craig. and Dieselcubmike have said thanks
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
If you get a click you might have a loose ground somewhere. Maybe a loose electrical line somewhere would be my next guess. hopefully someone can help me out here
#4 Chet OFFLINE
Chet
  • 2 Thanks
  • 14 posts
Posted June 06, 2013 - 08:30 PM
Hydro 14 horse
#5 Chet OFFLINE
Chet
  • 2 Thanks
  • 14 posts
I did overflow the gas, it spills to the rear of the engine.  Could have shorted something
  • skunkhome said thank you
#6 olcowhand ONLINE
  • 41,237 Thanks
  • 31,440 posts
Posted June 06, 2013 - 08:32 PM
Hydro 14 horse
Briggs & Stratton?
#7 Chet OFFLINE
Chet
  • 2 Thanks
  • 14 posts
Posted June 06, 2013 - 08:34 PM
I recently replaced the 38 inch mowing deck with a used 40 inch synchronized floating deck.  I sense a bigger drag on the engine, but has been working fine.  My suspicion is an electrical short caused by the gas overflow
#8 Chet OFFLINE
Chet
  • 2 Thanks
  • 14 posts
Yes, Briggs and Stratton
#9 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted June 06, 2013 - 09:18 PM
Pull the spark plug & try to start it.  If it spins, check for fluid coming out the spark plug hole.  If you have fluid coming out, you hydro locked the engine.  Spin it until the fluid stops coming out.
Next hook a volt meter to the battery and turning the key to START.  If the voltage isn't 12vdc or more, you have a battery problem.
Next hook a volt meter to the small terminal of the solenoid and turning the key to START.  If the voltage isn't 12vdc or more, you have a wiring problem in your safety switches.
If those don't solve the problem, we'll offer more help.
  • MH81 and Chet have said thanks
#10 MH81 OFFLINE
Posted June 06, 2013 - 10:21 PM
In my limited experience, gas rarely would cause an electrical issue unless it ate the wiring coating or a plastic connector, or (I would put this on the VERY rare end of things)
Flames from spilt gas DO often cause electrical issues (just kidding)
I would be more inclined to say it's a low current battery + well used starter but I like NCDBO's train of testing.  Start there and let us know what you're finding.
  • Chet said thank you
#11 916 hydro OFFLINE
916 hydro
  • 114 Thanks
  • 139 posts
Posted June 08, 2013 - 03:56 PM
make sure the wire is on the ammeter
#12 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted June 09, 2013 - 05:39 PM
What model do you have? I can find nothing for 1686814. Are you sure that number is right?
#13 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted June 10, 2013 - 05:56 AM
Phil, 1686814 is the part number for a 38" mower deck housing.
#14 Chet OFFLINE
Chet
  • 2 Thanks
  • 14 posts
Posted June 14, 2013 - 06:45 AM
The mower is a regent model, 14 horse.  I got it running, starts ok, replaced spark plug. But now the electronic clutch will not work to engage the deck.  Could it be a low battery charge?  Loose connection? Any suggestions?
#15 MH81 OFFLINE
Posted June 15, 2013 - 12:03 AM
Are you getting 14 volt DC at the clutch?
Also tagged with one or more of these keywords: electrical, battery, solenoid, engine, starter
