#1
OFFLINE
Posted June 05, 2013 - 09:16 PM
I want to use a wider wheel than the 5.5 that's on it. Is there a 8.5 that will fit?
I have room to run a 10.5 tire. Thanks
- larryd and JRJ have said thanks
#2
OFFLINE
Posted June 05, 2013 - 09:27 PM
Mostly all garden tractors use the same lug pattern. You can use up to a 10.5 tire, but you'll have to flip the wheel around, as you won't have the clearance due to the offset. I had a B-10 many years ago, and the only way I use the 10.5's was in reverse mounting. I didn't like the look, so I went back to the 8.5's.
- larryd, JRJ and Quigg have said thanks
#3
OFFLINE
Posted June 06, 2013 - 03:37 AM
larryd
- johndeereelfman and Quigg have said thanks
#4
OFFLINE
Posted June 06, 2013 - 05:08 AM
Measure your clearance with the stock wheels and tires on it. That will tell you how much more width you can add to the inside of the rim. When looking at wider rims measure the depth on both sides and that should give you a pretty good idea if they will work mounted shallow side in only or both ways.
- johndeereelfman, larryd, JRJ and 1 other said thanks
#5
OFFLINE
Posted June 06, 2013 - 07:00 AM
Some wider wheels wont work whether you flip them or not, because they have equal offset, others have a different offset. Any of the Simplicity/Allis Soverign wheels should fit
