It Really Refused...
19 replies to this topic
#1 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted June 05, 2013 - 08:46 PM
soo.. i borrowed my my fathers JD317 with tiller to do my garden.. Well I got 20 feet done and iot started smoken under the hood and out the front..  I turned it off and oil was pouring out all over the engine.. I checked the oil level.. its at least a liter over full... i will check it tomorrow... maybe..  i hope its a cheap fix.. supposedly this is my fault.. hahaha i might end up with another 317.. If so.. its getting a v6 or a inline 4....
  • hamman, larryd and JRJ have said thanks
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,857 Thanks
  • 10,037 posts
Posted June 05, 2013 - 08:52 PM
It's your fault it's over full???  Is there something you haven't told us yet?
  • larryd said thank you
#3 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted June 05, 2013 - 08:59 PM
my ole man dropped it off.. It was on his trailer. I drove it off the trailer and out to the garden.. Turned on the tiller.. 20 feet later.. oil show..
#4 olcowhand ONLINE
  • 42,307 Thanks
  • 31,776 posts
Posted June 05, 2013 - 09:20 PM
My Onan that was on my Massey w/FEL would do the same now & then.....huge cloud of smoke, and I mean huge.  It would send a mess of oil up the crankcase vent into the air filter housing.  Not overfilled in my case & on level ground.  I need to check the reed in the breather assembly.  I also had a Cub Cadet with Kohler twin that would do the same thing, but usually on an incline tilted to the left I believe.
  • Team_Green and larryd have said thanks
#5 MH81 OFFLINE
Posted June 05, 2013 - 09:45 PM
Really sounds as if the float failed or stuck open. Excess gas running down into the crank, maybe?
I sure wouldn't work it until you track the problem down.
If it does end up being the float, you can tell your Dad it was the cheap gas he's been using... See if you can get a response... :rolling:
#6 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
This is level ground and enough oil came out to puddle on the dirt.. If this storm gets out of our area for tomorrow i will go drag it to the house..
#7 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted June 05, 2013 - 09:48 PM
I smelled the dip stick.. its clean oil.. no gas smell... not at all..
The response i would get i can't put on this forum only to follow with a beating that i would get..  yes.. my 74 year young father could whip my but now..  I already told him if its a dead engine i have a replacement for it.. a Chevy V6..
  • MH81, backwoods, twostep and 2 others have said thanks
#8 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted June 05, 2013 - 09:50 PM
I can't remember if the KT 17 has a mechanical fuel pump or a vacuum pump? If mechanical, it could be leaking into the crankcase. Does the oil smell like gas?
#9 MH81 OFFLINE
Posted June 05, 2013 - 09:56 PM
So, why did you put all that extra oil in?
  • WNYTractorTinkerer and larryd have said thanks
#10 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted June 05, 2013 - 09:57 PM
Bored i guess.. lol  hhahahahaha Im tempted to go find me my own tiller since it looks like i will get my 317 back when my sister passes away...
#11 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted June 06, 2013 - 03:33 AM
I agree with all the above , to much oil or gas in the crankcase
larryd
#12 JDBrian OFFLINE
  • 9,634 Thanks
  • 14,156 posts
Posted June 06, 2013 - 05:13 AM
In those KT17's the breather reed fails and it spews oil all over the engine. This is a common complaint. The PO of my 317 told me this happened when mowing every once and a while for no apparent reason. It's a series 1 engine. I bought a new breather reed/plate assembly which will hopefully prevent this happening again. when the engine goes back in the tractor it will be clean and I hope the new breather prevents the problem. The entire engine compartment was soaked in oil.
#13 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,857 Thanks
  • 10,037 posts
Posted June 06, 2013 - 06:57 AM
Look on the bright side, 317s never rusted.
#14 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted June 06, 2013 - 11:46 PM
Do you have a link to this part so i know im looking at the right part... Thanks in advance..
I will get the machine drained of the extra oil tomorrow.. Today was a recliner and meds day.. I might have scored a tiller for my 112 so i may just get this thing running (with out smoke or oil pouring out) and i will use my own stuff..
#15 JDBrian OFFLINE
  • 9,634 Thanks
  • 14,156 posts
Posted June 07, 2013 - 05:19 AM
Part no. AM38415 - Breather kit (valve cover plate with a reed valve)  about 20$ can. Go to jdparts.com and enter 317 in the model no. search. It looks like this is a replacement for some sort of pop up valve arrangement which was original equipment.
  • Team_Green said thank you
