345 Antifreeze Leak
11 replies to this topic
#1 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted June 05, 2013 - 09:08 AM
I have a 345 that pukes antifreeze out the exhaust.I have had this tractor for over a year now and when I first got it,from time to time it would pull a streak where the exhaust would turn white from antifreeze for about a minute and then it would clear up but it has been getting worse and the left plug is always the wet one.I pulled the head and I can't see anything wrong.I never noticed any antifreeze in the oil in the past but this time there is some in the oil.Anyone have any ideas on the problem?
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 05, 2013 - 10:51 AM
I hope the block isn't cracked. Has it been overheating or perhaps it was overheated before you got it. The obvious culprit would be the Head gasket.
  • Username and WNYTractorTinkerer have said thanks
#3 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted June 05, 2013 - 05:16 PM
I would have the head checked at a motor repair shop. they can find cracks with a magnet and iron filings, I believe it's called magnafluxing.
  • Username said thank you
#4 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted June 05, 2013 - 06:44 PM
I never had an over heating problem and the problem has gotten progressively worse.I am leaning towards a cracked head and I am considering just replacing the head.
#5 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted June 05, 2013 - 06:50 PM
Like the others have said, only a few possibilities. Cracked engine block, cracked head or hopefully just a bad head gasket. I would replace head gasket and if that didn't work, add some sealant and hope for the best.
P.S. Below is a link to a detection kit,
http://www.cylinderh...m/skpokit1.html
#6 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted June 05, 2013 - 07:00 PM
I think it would have to get past the fire ring on the head gasket to get in the cylinder if it were a head gasket and I don't see any signs of that.One other place is the intake manifold as it has a cross flow port for the coolant but it looks good.
#7 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted June 05, 2013 - 07:10 PM
Yep, magnifluxing is correct, and it'll find cracks you'll never see with the largest magnifying glass!
#8 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted June 05, 2013 - 07:35 PM
Does it build pressure in the radiator? What motor does it have?
#9 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted June 05, 2013 - 09:01 PM
That is right, if no pressure buildup, then I would "think" the crack would have to be between the water jacket & the exhaust outlet.
#10 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted June 06, 2013 - 10:02 AM
It has an FD590 18 HP Kawasaki.I never noticed excessive pressure in the radiator.
#11 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,464 Thanks
  • 5,768 posts
Posted June 06, 2013 - 10:21 AM
If you are getting AF in the cylinders it will wash the spark plug like new-  Pull and inspect them..  Inspect any cylinder with a clean one..  I'd at least pull and change the head gasket on that cylinder and watch it..   If neither plug is washed then it is a crack in a head to the exhaust port..  You should be able to spot a difference once you remove the muffler to look..  If not inspect both heads..
Edited by WNYTractorTinkerer, June 06, 2013 - 10:23 AM.
#12 Mrfixit8 OFFLINE
Mrfixit8
  • 1 posts
Posted August 13, 2013 - 08:57 PM
Did you ever find the problem and the remedy?  I found your post while searching out the same problem.  I have pulled the heads and they appear to be fine, as do the head gaskets.  I am having the heads sent out to a machine shop for magnifluxing. The one thing that peaks my interest is the intake.  My muffler had a lot of coolant in it.  Thanks in advance.
