* * * * * 1 votes
2567 replies to this topic
#1456 prosparky OFFLINE
prosparky
  • 2 Thanks
  • 8 posts
Posted June 04, 2013 - 01:42 PM
I found a very loose cylinder head bolt on my 2002 Simplicity Conquest (16 HP Vanguard Twin). I have recently heard a noise like an exhaust leak, so when I was checking this out, I found the loose bolt.The engine shroud was the only thing keeping the bolt from vibrating all the way out. I also pulled the top engine cover, and cleaned the dirt and gunk from underneath. The flywheel and the ignition coils are very rusty. I cleaned them up a little, but they are going to need a thorough de-rusting in the future. I should also mention that I put a new voltage regulator on it a few weeks ago, after finishing mowing, and finding a dead battery on attempted restart, and I found a small shorting spring in the seat safety switch plug that wasn't "unshorting" when plugged in to the switch. I removed the spring, and this solved the intermittent problem of the engine dying as soon as I would let out the brake pedal, with the PTO disengaged, and while sitting on the seat. I am learning!
Edited by prosparky, June 04, 2013 - 01:55 PM.
#1457 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 12, 2013 - 09:02 AM
This is about a 3 week saga. Mowing around the garden and the mower on my 318 quit working(Neglect).
That's what you get when you run things without maintainence.
Spindle bearings were completely gone. Parked it and used the Ford 1500 with brush mower.
A week later I put the 318 in the garage and took the deck off and cut the bolts holding the spindle on with the angle grinder.
Bought a new spindle housing and shaft and put that back together. Mounted the mower last Friday night and mowed 1 minutes and the Tension spring broke. Took the mower off and went to John Deere and got a new spring Saturday morning, put it back together and started mowing. Mowed for a couple hours and Lyall from State Center stopped by. After he left I mowed about 15 minutes and the mower quit again. I had shredded the belt?  It is supose to rain this afternoon so I will be putting it back on the 318 tonight.
Lessons learned, Trying to get by does not always work out!! I should have replaced the spring and belt while it was down the first time!!
  • larrybl said thank you
#1458 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,753 Thanks
  • 4,299 posts
Posted June 12, 2013 - 10:02 PM
I have 3 mowers all capable of mowing I use each winter down time to refresh one. That way I have a main mower and a backup and a second backup. But by refreshing each mower every 3 years I have not needed to use the backups. (none are JD's)
  • twostep said thank you
#1459 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 13, 2013 - 08:19 AM
You make a good point Larry. And I try but got a little lax. Once I got the Ford 1500, I neglected the Gt's some and am paying for that.
I do have a backup machine, a Murray 22.5 Hp with a 52" deck. This is one of the heavier Rail Frame Models and has exceeded my expectaions beyond my wildest dreams. The first season I had it I used it to shred 5 acres of cornstalks(blatant abuse). But the drive pulley on the Hydro stripped. the pulley is back on and it needs to be put together. I'll be moving it into the garage tonight  and finish putting it back together. When it is not mowing the wife uses it and the garden cart to carry things back and forth to the garden.
With the foot control hydro she likes it.
  • larrybl and twostep have said thanks
#1460 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,753 Thanks
  • 4,299 posts
Posted June 13, 2013 - 09:28 PM
I think ---- and this is my opinion --- If you spend a few $$$ ($300.00 in my case)  and maintenance time on the down seasion you will save $$$ and agervation durring the mowing seasion.
my 2c
Back-up machines are a MUST with 2+ acres to mow.
#1461 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 13, 2013 - 09:37 PM
my 2c
No doubt about that Larry. I have 1 1/2 acres in lawn out of 8.9. But I now have the Ford 1500 with a 5 ft brush cutter to do all but the lawn.
#1462 IlovemyCub OFFLINE
IlovemyCub
  • 172 Thanks
  • 204 posts
Posted June 14, 2013 - 05:33 AM
Rebuilt a Kohler K-301 for a 212 that I have. Hoping it will run great.
#1463 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 19, 2013 - 08:17 AM
The Back up machine is back together finally!!  I have a Murray "Yard King"(Walmart Special from 1999) Rail Frame Gt.
Last summer the drive pulley on the Tough Torq Hydro stripped the splines. I tore it down and never got it put back together.  Last night I put it back together and put a new belt on it. It lives!!
I'm not going to put the mower on for about a week. It has to come off to get at anything?? So I'm going to use it w/o the mower for a litle while, pulling the garden cart and stuff and make sure everything is working right .
The amazing thing to me was after sitting almost a year, I put gas in it and the 22Hp Briggs only turned over about 4 times and fired up and ran smooth as silk!!
I never was a big Murray fan. But after shredding 5 acres of cornstalks the first year on this place, I realy like this one.
#1464 OldBuzzard ONLINE
OldBuzzard
  • 6,969 Thanks
  • 4,777 posts
Posted June 19, 2013 - 12:00 PM
Since I figured that they needed to see what a REAL GT looks like, I took the Bolens HDT1000 over to the local John Deere dealer this morning to have Rim Guard put in all four tires.  :D :D :D
The Rim Guard was just $3.20/Gal. installed, and they put in a total of 24 Gal. which gives me @ 264 extra lbs.
Now I need to get the front and rear wheel weights on, and I'll be ready for some plow days. :dancingbanana:
Edited by OldBuzzard, June 19, 2013 - 12:33 PM.
  • KennyP and twostep have said thanks
#1465 twostep OFFLINE
twostep
    Rockstar
  • 1,951 Thanks
  • 2,522 posts
Posted June 21, 2013 - 07:32 AM
I sold my 682. Sad to see it go but I'm excited about having funds for my FEL.
#1466 OldBuzzard ONLINE
OldBuzzard
  • 6,969 Thanks
  • 4,777 posts
Posted June 22, 2013 - 06:40 PM
Put the Dual Wheel Kit on my recently purchased Bolens 1250 with the Haban Sickle-Mo mounted on it.
With the Sickle-Mo cutter bar down, the tractor can get a bit 'tippy' with all that weight hanging out on the side.
I don't think that will be an issue now :D :D :D
#1467 breimer OFFLINE
breimer
  • 132 Thanks
  • 164 posts
Posted June 23, 2013 - 10:29 PM
Took some pics and posted them in the introduction forum. I'm new to this forum as of today. likeing it.
  • olcowhand and twostep have said thanks
#1468 twostep OFFLINE
twostep
    Rockstar
  • 1,951 Thanks
  • 2,522 posts
Posted June 24, 2013 - 11:39 AM
I was home alone all week/weekend so I got quite a bit of stuff done.
It started with the hydro on the Cub 682 going out last week while mowing. Luckily I had just bought a parts Cub 1711 and the rearend was good in it. So I swapped those out just in time to sell it on Friday.
With 682 out of the garage I was able to do some work to the new GT14 Wheel Horse. First I lubed, rerouted and hooked up the choke cable, works great and now I don't have to pull the hood evertime I cold start it. Next I pulled the deck off and pressure washed it. The deck tin is rough shape but the mechanical components are in amazing shape... PO must have put new bearings in. The hanger parts are shot though... so the mower deck is going in storage. I want to keep the GT14 as my loader GT anyway. Next I pulled the beat up drive belt guard off. It was bent in a few places and all but two of the spot welds on the belt guides were broken. drilled a couple of holes and re-spot welded them. Ever since I picked it up I knew that he parking brake lever was pulled up instead of pushed down. When it is pulled up there is supposed to be no tention on the idler pully... but there is anyway. So the drive belt must be shorter than it should be. Also I noticed that the lever is actually on backwards. Obviously there are a few things to work out but the GT is solid and it runs great!
After mowing last week (with the JD since the Cub laid down on me) I pressure washed it and the kubota's finish mower. After letting it dry for a bit it wouldn't start. Starter clicked over one good time and that was it. Turns out it was the solonoid went bad. Don't think that the washing had anything to do with it but yet again the parts Cub 1711 came through with a good part to keep me running. (I love parts tractors!!).
Last I put an hour meter (off of a parts GT) on the Kubota. It reads 8xx hours but all I need it to do is work...
#1469 WHdbJD OFFLINE
WHdbJD
  • 663 Thanks
  • 508 posts
Posted June 25, 2013 - 10:00 PM
Hot day to wear a sandblast hood, but I got the db weights cleaned up.  Both weights looked like the one on
the right, found some original green paint under the rust when I did the one on the left.
#1470 hatedge OFFLINE
hatedge
    Beer Guzzling Canuck
  • 292 Thanks
  • 577 posts
Posted June 26, 2013 - 07:17 PM
Wheel Horse C160
Changed the iddler pulley on the trans drive belt
