* * * * * 1 votes
2584 replies to this topic
#1426 hatedge OFFLINE
hatedge
    Beer Guzzling Canuck
  • 292 Thanks
  • 577 posts
Posted April 27, 2013 - 09:36 PM
Not really my tractor but ill tell anyway. Got up bright amd early today and jumped over the neighbours fence to get his Allis chalmers carb off. I met him at the local hardware store and he told me that he had been using a shovel all winter because his tractor would not run more than 5 minutes before sputtering and dying. I was sorry he hadnt bothered asking me to take a look at it. Especially since he knows I like fixing old engines. So I took the carb off his GT and told him Id give it a lookt over, it was full of a tan colored gel, everything was plugged and clogged. It took 2 hours to get it cleaned to my likings. When I reinstalled it the neighbour was amazed at how shinny it was (I gave it an extra buffing :) ) It took 10 minutes to get it installed and another 10 minutes to have it tuned right. He was very happy and told me He had'nt been able to run the throttle low before because the engine always died. I told him that now I was officially attached to his GT and that I forbade him to run regular gasoline in there from now on or I would personally drain his fuel tank.
Gotta hate that ethanol crap they put in regular gas it kills our old engines, eats at the gas lines and destroys gaskets :(
  • Newpaws493 said thank you
#1427 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 28, 2013 - 10:04 AM
well yesterday we got the cub 1015 running that i bought the same day as my 70 an the 123. it runs great just cant keep the deck belt on it
  • hatedge said thank you
#1428 twostep OFFLINE
twostep
    Rockstar
  • 1,969 Thanks
  • 2,528 posts
Posted April 28, 2013 - 12:21 PM
I got my new (to me) tiller. It is a Kubota FL850. It was a really good price and small PTO tillers are REALLY rare around here so I think I got pretty lucky. One of the stickers actually suggests that is is used with Kubota tractor models B7100, B6100, and B5100. The seller only had half of the shaft but gave me front half of a standard square type PTO shaft... so after a trip to TSC I had her going. I pulled the side cover off and adjusted the chaing a little. Also changed the gear box oil - it was pretty nasty. After shaft parts I'm into this thing for about $450. It will sure churn some dirt!
Edited by twostep, April 28, 2013 - 12:25 PM.
  • HowardsMF155 and hatedge have said thanks
#1429 hatedge OFFLINE
hatedge
  • 292 Thanks
  • 577 posts
Posted April 28, 2013 - 04:47 PM
WoW :) I think you DID get a decent deal. A lil grinding and sanding , a lil coat of paint and itll look like a million bucks. Me likes what ye got mate. Wish I could have one like yours too
  • twostep said thank you
#1430 MH81 OFFLINE
Posted April 28, 2013 - 05:31 PM
A few days before plow day, my GT5000 was surging and starting hard. Ryan and I cleaned the electric shutoff out and it started much better.
FFwd to plow day, the longer we went, the worse it got. Missing, loading up... Even flooded out... This time I pulled the whole carb off and did a thorough cleaning. Runs like it used to. Crapola in there somewhere.
#1431 qtrhrs86 OFFLINE
qtrhrs86
  • 10 Thanks
  • 28 posts
Posted April 29, 2013 - 03:39 PM
Changed the oil and filter in the 2182. Put the side panels back on.
#1432 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted April 29, 2013 - 08:20 PM
Replaced the drive belt on the charger 12. I also changed the plug and fuel filter. I need to change the oil and hydro fluid/filter soon. By the looks of the idler pulley someone has done a little maintainance.
Sent from my HTC One VX using Tapatalk 2
#1433 MH81 OFFLINE
Posted April 30, 2013 - 06:57 AM
Spent about two hours playing with the sickle. Got it apart and started taking stock on what I will need for the teeth.
#1434 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 30, 2013 - 01:21 PM
well since my hood was all glued back togeher i brought it home last night after class and just put it on a lil while ago. buffed the hood and the tins it looks like a new tractor almost. seams good to have the hood back on it.
#1435 Ron White OFFLINE
Ron White
  • 124 Thanks
  • 124 posts
Posted April 30, 2013 - 04:43 PM
This past Sunday I was involved in a little Deere trading so, I loaded up the 140 and had headed out for a rendezvous near half way between the two of us.
I will miss the 140 as it is my favorite style in the GT's but I came home with a larger tractor that I have been wanting for a while.  I don't have any good pictures yet but with this weekends upcoming plow day, I had to get the plow setup started  and then I will do the fine tuning in the field this weekend.
So here are a couple pix of me turning over two short furrows in my back yard  for a test !!
http://s871.photobuc.../430 plow setup
  • MH81, twostep, Watchdog and 1 other said thanks
#1436 Cat385B ONLINE
    HAZMAT CAT
  • 13,777 Thanks
  • 9,918 posts
Posted May 09, 2013 - 12:02 PM
Starting the assembly of the 48" deck for the Bolens G152, model #1349.
#1437 Cat385B ONLINE
    HAZMAT CAT
  • 13,777 Thanks
  • 9,918 posts
Posted May 10, 2013 - 09:03 AM
Finished.
  • MH81 and WNYTractorTinkerer have said thanks
#1438 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 10, 2013 - 10:18 AM
You did very well on that tiller!! Like you I found a small tiller nearly impossible to find in this area.
So I dropped the big bucks and bought a new one.
#1439 twostep OFFLINE
twostep
    Rockstar
  • 1,969 Thanks
  • 2,528 posts
Posted May 10, 2013 - 11:24 AM
I will miss the 140...
Don't you have like 20 of them though...
That 430 is a beast. I like the HD air filter you have on it.
#1440 IlovemyCub OFFLINE
IlovemyCub
  • 172 Thanks
  • 204 posts
Posted May 12, 2013 - 08:54 PM
Changed the oil in the Simplicity. It was in desperate need of a oil change.  :poke:
