* * * * * 1 votes
2372 replies to this topic
#1366 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 5,605 Thanks
  • 3,668 posts
Posted April 01, 2013 - 08:31 PM
Pulled the engine back out of my JD314 K321 . Of course when I rebuilt it I cleaned everything real good and used new gaskets . Well  I have an oil leak , about 24 hrs per drop coming off left front corner of pan . I want  to say it is the pan gasket but just can't say positively , but don't  see any crack in the pan . There is no oil anywhere on the block itself . So i'm pondering .
larryd
How long sence the first rebuild? I did a B/S in 2009 (RED) and he developed a signifante oil seapage problem, so I replaced all the gaskets (and other parts) this year. No more seapages (so far).  I have a thread on here about the refurbish somewhere.
  • larryd said thank you
#1367 twostep OFFLINE
twostep
    Rockstar
  • 1,929 Thanks
  • 2,513 posts
Posted April 01, 2013 - 09:38 PM
Tonight I replaced a headlight... not glamorous but necessary.
#1368 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 01, 2013 - 10:30 PM
I  haven't done anythging but start it since I overhauled about 2 months ago. I don't even have the sheet metal back on it yet.
larryd
  • larrybl said thank you
#1369 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 5,605 Thanks
  • 3,668 posts
Posted April 02, 2013 - 06:27 PM
larryd
Ouch, all I can say is I hope it is a bad gasket. I used "Form-a-Gasket Sealant" on mine. I know it is a PITA to remove, but hopefully I won't have to do that for a long long while.
#1370 Cat385B ONLINE
    Therapy CAT
  • 12,540 Thanks
  • 9,289 posts
Posted April 03, 2013 - 06:39 PM
I added a tube hitch receiver to the G152.
#1371 michael.kitko OFFLINE
michael.kitko
  • 475 Thanks
  • 447 posts
Posted April 03, 2013 - 08:44 PM
Put on the three point hitch on the 140...now I realize I am gonna have to modify parts...
#1372 dropped82 ONLINE
dropped82
    Nut Case
  • 1,738 Thanks
  • 1,388 posts
Posted April 03, 2013 - 09:12 PM
This is more of a rant but involves working on a tractor. I've been working on this 222. Just trying to get things adjusted. I hooked the tach up and at half throttle the thing hits 3600. Lord only knows what full throttle does. I sure don't. So why does it seem I get the tractors that someone has screwed with the governors. It drives me crazy!!! Since its different from the K301 in my JD 112, I get to learn a whole new way to adjust this thing. If I had hair it would've been pulled out. Ok, I'm done now. Thanks for reading.
Eric
Sent from my XT897 using Tapatalk 2
Edited by dropped82, April 03, 2013 - 09:13 PM.
  • MH81, Newpaws493 and larryd have said thanks
#1373 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 04, 2013 - 05:58 AM
Dropped82 , I have the problem on my k321 Full throttle is about 5800 rpm
larryd
  • dropped82 said thank you
#1374 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted April 04, 2013 - 08:24 PM
Worked on the AC B112 tonight in hopes that I can get a little seat time over the weekend.
I finally got it running (after sitting for the winter, it's always ornery to wake up... but we convinced it.
Did a little carb cleaning, and a little tweaking. Running decent now.
Figured out that the charging circuit wasnt... cleaned the points in the regulator. Also adjusted the regulator so it will feed the battery a pretty constant 13.6.
Ever since I bought it, the clutch was temperamental if the varispeed was in "slow" . Almost couldnt clutch it at all. Managed to adjust the linkages so it would do what it should. Much safer.
Also stared at the tiller belt for a while to see if it was just a to short issue or what that was causing it to never fully disengage.
Found that a could of "Yankee Engineered" belt guides and the belt works as it should. The unit is much safer now.
  • twostep and larryd have said thanks
#1375 twostep OFFLINE
twostep
    Rockstar
  • 1,929 Thanks
  • 2,513 posts
Posted April 05, 2013 - 08:38 AM
I adjusted the tiller's carb a little. I put a new one on it and full throttle just isn't enough so I think I need to tweek the governer linkage a little.
Next I put the blow back on the kubota and turned the garnden back over. I plan to pick up a ton of sand tonight to mix in to the heavy clay that is spread throughout the newer garden area.
#1376 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 5,605 Thanks
  • 3,668 posts
Posted April 05, 2013 - 05:45 PM
I have had a rough week, and decided to relax a little before comming home, with a stop at Harbor Freight. I bought me a couple new toys to help with tuning the engines. Now I can set the Idle and Governed rpm's. Right now Idle is a little high, and governed a little low. Mostly due to the carb work last weekend.
  • dropped82, twostep and larryd have said thanks
#1377 backwoods ONLINE
backwoods
  • 2,441 Thanks
  • 2,719 posts
Posted April 05, 2013 - 08:35 PM
put the deck under the jd today and got the height adjusted so im ready for mowing season oh and i have a pic for yall as well
#1378 Cat385B ONLINE
    Therapy CAT
  • 12,540 Thanks
  • 9,289 posts
Posted April 06, 2013 - 03:28 PM
Put an ad on CL to sell the Homelite.
#1379 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted April 06, 2013 - 08:57 PM
Put the dash back on the 18/6 Sears. Managed to get it running and take a victory lap.
The hour meter started clicking away as soon as I turned on the key :D :thumbs:
I still have to see if I can get the PO to look for the air cleaner and some other little parts.
I also readjusted the vari drive and clutching for the Allis B112... Looking for that "Halfwayinbetween" spot, getting closer. Loosened the brake a little, was grabbing before clutching was fully engaged.
#1380 IHCubGuy ONLINE
IHCubGuy
  • 1,429 Thanks
  • 1,515 posts
Posted April 06, 2013 - 09:02 PM
Finished fabrication and did all my welding on my 3pt for on my 12H.  Got it painted tonite and will put it on tomorrow.  Only had gloss black paint on hand so thats what I used.  I think I'm getting cheap! :bigrofl:
  • MH81, HowardsMF155 and larryd have said thanks
