* * * * * 1 votes
2585 replies to this topic
#1066 RoosterLew OFFLINE
RoosterLew
  • 82 Thanks
  • 139 posts
Posted July 02, 2012 - 10:17 AM
The WH 856 is coming along, first splash of paint on the tins, now waiting on parts.....hate that part!
#1067 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted July 03, 2012 - 10:27 PM
I guess it was "to the tractor"... I took off the JBjr to mow the lawn then put the JBjr. back on and took off the deck so's I can move firewood tomorrow. I didn't even break a sweat. :orangecool:
#1068 JDGuy445 OFFLINE
JDGuy445
  • 356 Thanks
  • 428 posts
Posted July 11, 2012 - 12:03 PM
Took off the fender deck and the fuel tank. Got aroun around to looking some more and found that the fuel sensor float was broken.
#1069 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted July 14, 2012 - 12:03 AM
put some diesel additive in the fuel, found the rear diff leak. Adjusted the 3pt let down so that it doesn' SLAM the mower down any more. Also got prices on a couple of parts... one being a selector valve for the hydraulics to divert the fluid to an aux impliment. $500 bucks... Looks like I'll just be tapping into the main HP line when it comes time for a FEL.
#1070 olcowhand ONLINE
  • 40,355 Thanks
  • 31,174 posts
Posted July 14, 2012 - 02:45 PM
Installed a tube in the deck spindle tire of my John Deere F935, and new starter solenoid on my Massey 1010.
#1071 grnspot110 OFFLINE
grnspot110
  • 4,103 Thanks
  • 2,622 posts
Posted July 15, 2012 - 04:49 PM
Not a tractor, but I used my 10 HP Troy-Bilt yesterday to chip 3 small branches. It sounded like it had a bearing going out or something! Today, I took the outer cover off the shredder housing & found a stick caught behind the hammer drum (for lack of better terminology). Sharpened the shredder blade while I was in there & put it back together. Sounds much better now! :D ~~ Lowell
#1072 bja105 OFFLINE
bja105
  • 196 Thanks
  • 191 posts
Posted July 16, 2012 - 09:38 PM
I went and bought the correct drive belt for my Ford 80, and installed it. There was no belt when I bought it last week. Adjusted the brake and clutch. I checked the oil, dark but there! It will be changed now that I know it runs. I learned how to shift the gears and did a few laps of the yard.
Here she is.
#1073 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted July 16, 2012 - 11:04 PM
That little ford looks fun!!!
All I did to mine was glance at it and wish I had some time to tinker on it.
#1074 Grumpy OFFLINE
Grumpy
  • 713 Thanks
  • 614 posts
Posted July 17, 2012 - 02:42 AM
Changed the oil ,cleaned the deck and put it in the barn.
Edited by Grumpy, July 17, 2012 - 03:00 AM.
#1075 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted July 18, 2012 - 07:18 AM
looked at the trap is sitting under wishing i had the parts to fix it
#1076 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted July 18, 2012 - 01:12 PM
Pulled the deck off the DLT 3000 to replace the belt which was worn out. Found one of the idler pulleys was also frozen and missing some of the ball bearings. Replaced the pulley with one from a deck in the not really junk pile. Then I power washed the deck and dried it with the leaf blower, oiled the bearings on the two idlers and put the deck back on. Ready to mow Friday since we got that inch of rain and the grass & weeds are green and growing again.
#1077 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted July 20, 2012 - 12:30 PM
2 days ago i painted the snow plow and if it stop sprinkling today im gonna go out and finish painting it
#1078 KennyP ONLINE
  • 37,463 Thanks
  • 45,484 posts
Posted July 20, 2012 - 12:48 PM
Let it sprinkle, might be a while before you get any more rain!
#1079 HowardsMF155 OFFLINE
  • 2,838 Thanks
  • 2,979 posts
Posted July 22, 2012 - 06:01 PM
Moved one step closer to finishing the engine installation on my "Dump Massey" today. I installed a new choke cable, cut it to length, and managed to secure it to the engine so that the choke lever moved correctly. I also dismounted the built in key switch from the engine and mounted it under the dash on the right side of the steering tower. Now I can stay in my seat through all the starting process.
#1080 olcowhand ONLINE
  • 40,355 Thanks
  • 31,174 posts
Posted July 22, 2012 - 06:17 PM
Got a stuck exhaust valve freed up in the Wisconsin TR10D out of a D4-10 Bush Hog.
