* * * * * 1 votes
2323 replies to this topic
#856 Chuck_050382 OFFLINE
Chuck_050382
  • 268 Thanks
  • 1,498 posts
Posted January 03, 2012 - 10:26 AM
The stack on my Ford LGT 165 had cracked and broke off back when I plowed the garden under this fall. I finally got a chance to fix it. I added a support going from the pipe back to the muffler. When Olcowhand built this exhaust he braced the muffler to the block to hold the weight of the exhaust. After fixing the exhaust I put the snow blade on and put the rear weights on.
#857 cookiemonster OFFLINE
cookiemonster
  • 406 Thanks
  • 1,274 posts
Posted January 03, 2012 - 01:36 PM
Good job. So what you're saying is that the last fix supported the muffler okay, but the pipe coming out is what failed this time?
I wouldn't think there's much weight to support there, but the facts are the facts.... and more bracing is always better.
#858 Chuck_050382 OFFLINE
Chuck_050382
  • 268 Thanks
  • 1,498 posts
Posted January 03, 2012 - 02:28 PM
The pipe coming out failed just inside the side panel, the bracing is to help support the vertical section.
here is a view of the stack,
#859 Simplicity Saver OFFLINE
Simplicity Saver
  • 3 Thanks
  • 14 posts
Posted January 04, 2012 - 02:41 AM
does working with the vinyl guy on the reproduction decals for the yoeman count?
#860 Saltydawg OFFLINE
Saltydawg
  • 3 Thanks
  • 34 posts
Posted January 06, 2012 - 04:26 PM
Got to hear my 109 run for the first time today. Put the newly built wiring harness on it,head gasket,and a tune-up. hook my Harley battery(I ain't bought a battery for it yet) to it. IT'S ALIVE!!!!!!
#861 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted January 07, 2012 - 06:20 AM
Here's what I did to my M12 today----------------
#862 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted January 07, 2012 - 09:17 PM
With no snow and 63 degrees!!!, I installed lug nuts on the rear wheels of my 518xi.
#863 Cvans OFFLINE
  • 4,738 Thanks
  • 5,184 posts
Posted January 07, 2012 - 09:45 PM
I've been wanting to convert my CC 129 to hydro lift so today was the day to start. Tore down the 129, a 149, and a 1450. I took the lift parts out of the 1450 and installed in the 129. Monday I will install the the Hydro rear end out of the 149 into the 129 and I should be good to go. Darned tiller can get heavy after lifting it manually many times a day. This should make life very nice come this spring.
Edited by Cvans, January 08, 2012 - 07:12 AM.
#864 Nonyab OFFLINE
Nonyab
  • 1 Thanks
  • 16 posts
Posted January 09, 2012 - 06:56 PM
New member. Just given an '86 CC Hydro 1811. It's complete, in pretty fair shape so considering restoration hobby. Put it in the shop today to get it running right and see what I got.
#865 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted January 12, 2012 - 07:05 AM
Another small step. Man that sucker is heavy.
#866 Nonyab OFFLINE
Nonyab
  • 1 Thanks
  • 16 posts
Posted January 12, 2012 - 03:39 PM
Got the 1811 running today by doing a "short" clean job on the carb float needle. Dropped the mower deck and rode it around the neighborhood for awhile. Runs pretty good. Attached some pics my free tractor. Have all the cowling and good mower deck also, so not a bad deal.
#867 KennyP OFFLINE
  • 29,404 Thanks
  • 40,398 posts
Posted January 17, 2012 - 03:03 AM
I put the other wheel weight on the Ford today. Cut the sleeve hitch apart and rewelded it back level. It had a bad twist in it. Sanded the grille section for the GTV/16 and got one coat of the Metallic Charcoal on it. I was going to try to bend the 3-point lower arms for the GTV/16, but my little 4" vise just isn't big enough to hold them. Had one cherry red, but the swivel lock wouldn't hold the vise from turning when I tried to bend the 3/8" X 2" bar. Have to do something different.
#868 mjodrey OFFLINE
  • 2,345 Thanks
Posted January 17, 2012 - 05:12 AM
Sounds like you were busy.
#869 cookiemonster OFFLINE
cookiemonster
  • 406 Thanks
  • 1,274 posts
Posted January 17, 2012 - 01:30 PM
Sounds like you have one of the vise's that swivel. I have a sears one and I got tired of it spinning when I didn't want it to... So I just welded it solid and have been much happier with it since.
#870 Saltydawg OFFLINE
Saltydawg
  • 3 Thanks
  • 34 posts
Posted January 18, 2012 - 10:36 AM
Not today, but yesterday. Sanding,sanding,sanding,and more sanding........got no more fingerprints left I been sanding so much! Oh! I welded a new bottom into the battery box also.
