* * * * * 1 votes
2376 replies to this topic
#661 THEMONSTERFERGIE OFFLINE
THEMONSTERFERGIE
  • 3 posts
Posted August 08, 2011 - 02:28 PM
I'll redo the painting of the tractor and draining the gearbox oil and filter change.
I received my stickers for the tractor (MAPLE HUNTER Decals Texas).
And finally change the front tires.
#662 dualsportklx OFFLINE
dualsportklx
  • 3 Thanks
  • 14 posts
Posted August 09, 2011 - 07:55 AM
spent last night cleaning, got back from tractor show in central pa. and we had rain the whole weekend. then had to haul home in the rain. what a mess. thinking about buying a enclosed trailer
#663 rbhoover OFFLINE
rbhoover
  • 10 posts
Posted August 10, 2011 - 08:06 PM
worked on getting it (JD 316) running again...
#664 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 11, 2011 - 04:49 PM
Fixed rear motor mounts on my Jd 312. Would have done more but Jd dealer didn't have all my parts. The hard part is that who owned my tractor before me welded plates over where mount would be front & back so I will have lots of work in near future.
#665 coopduc OFFLINE
coopduc
  • 27 posts
Posted August 12, 2011 - 08:14 PM
Put on a new sight tube on the trans of my Deere 318
#666 tinner OFFLINE
tinner
  • 502 Thanks
  • 1,561 posts
Posted August 13, 2011 - 05:42 PM
Haven't been able to do much the last couple of weeks, daughter and grandchildren were here from Cut & Shoot (near Houston). Thought I had a blown head gasket on the MF14 and the gasket came in the other day. Today I put in new points, carb. kit, condenser and replaced the blown head gasket. That thing was blown almost completely into around the #1 head bolt and blowing oil out the side of the engine. Noticed the piston had 030 stamped on it so I guess it's already been bored out 30 over. Whoever put the head on last, the PO or whoever he had work on it just snugged up the head bolts, they were all fairly loose. Torqued to 25 ft. lbs. and ran until the motor was good and hot then torqued to 30 ft. lbs. It now runs and sounds great.
#667 olcowhand ONLINE
  • 36,869 Thanks
  • 30,149 posts
Posted August 13, 2011 - 07:24 PM
Shot some paint on some Bush Hog D4-10 parts. Will be finished within a month now!
#668 Chuck_050382 OFFLINE
Chuck_050382
  • 271 Thanks
  • 1,498 posts
Posted August 15, 2011 - 08:21 AM
Saturday Pulled the deck off the new to me Cub 1210. but that was it, mowed with the jubilee and the 6 foot wood finish mower.
#669 olcowhand ONLINE
  • 36,869 Thanks
  • 30,149 posts
Posted August 15, 2011 - 10:34 AM
Yesterday installed the Bush Hog D4-10's headlights, rewired them also, from bulb back. Likely do nothing today, as it's silage time.
#670 olcowhand ONLINE
  • 36,869 Thanks
  • 30,149 posts
Posted August 15, 2011 - 09:06 PM
Got a little shop time this evening, so shot red paint on the 2 pieces I forgot about, the Delco starter/generator, and it's tensioner arm. Got new wires ran to the key switch also.
#671 xshooter OFFLINE
xshooter
  • 34 Thanks
  • 93 posts
Posted August 15, 2011 - 09:24 PM
Did a whole lot of painting today. First up was the wide rims for my 318 that I'm mounting 26x12x12 True Powers on. Next was the stock 318 rims that are getting 18x7x8 Multi tracs. Then it was on to 4 50# cast weights that I picked up on Saturday. Starting to get excited about getting it all put on the 318.
#672 Chuck_050382 OFFLINE
Chuck_050382
  • 271 Thanks
  • 1,498 posts
Posted August 16, 2011 - 07:48 AM
Did some cleaning on the cub and pushed it into the shop to try and get it going.
#673 grand OFFLINE
grand
  • 1,707 Thanks
  • 1,926 posts
Posted August 16, 2011 - 08:32 PM
I put the tool box and fenders back on the Bolens 800 to get it ready for the big tractor show,here in Dover,PA. I removed them this winter to make more clearance for the tire chains. All the tractors got some gas added to their tank and the oil checked. George wants to start hauling our tractors to the show tomorrow.
#674 n3pht OFFLINE
n3pht
  • 21 Thanks
  • 66 posts
Posted August 17, 2011 - 10:35 AM
Gas tank sprang a leak and tried to weld it up- not fun- every time I struck a bead I blew a hole in the darn thing, now I think I'm going to replace it.
Yes I did remove the gas and filled it with water and flushed it out Before I started to weld on it :)
Them there tanks are soldered together nice to find that out after the fact
Edited by n3pht, August 17, 2011 - 04:46 PM.
#675 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 17, 2011 - 10:54 PM
Got to put isolators back on drive shaft , new front motor mounts set motor back in place & started hooking everything up.
