* * * * * 1 votes
2584 replies to this topic
#646 coopduc OFFLINE
coopduc
  • 27 posts
Posted July 12, 2011 - 10:08 PM
Changed the engine oil and hyrdo fluid. Maybe shouldn't admit it, but I bypassed the seat interlock switch.
#647 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted July 17, 2011 - 05:17 PM
the 318 got a carb cleanin fuel filter air filter plugs and wires . then it got hot (out side not the 318 )
#648 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 19, 2011 - 12:28 PM
Changed the primary PTO belt on My Murray mower deck and remounted the mower.
Did a test run and it's working beautifully again.
#649 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted July 21, 2011 - 10:44 AM
I had a chance to get the little Troy-bilt back in the shop this morning and change out the fuel line and filter. I had to remove the mower deck, seat pan and gas tank to get to the fuel line. This is going to make a good mower for our plant, with the foot hydro. It runs like a new machine, I don't think it has very many hours on it, 100.00 was a bargain.
Edited by Texas Deere and Horse, July 21, 2011 - 02:24 PM.
#650 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted July 21, 2011 - 01:50 PM
Just about anything you can get that you can do work with while you ride on it for $100 is good. From the pictures what you got is great. Glad it's turning into a work horse.
#651 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted July 21, 2011 - 02:23 PM
Thanks Ronnie..
#652 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted July 25, 2011 - 10:02 AM
Worked on the weed-eater Saturday and got it running good, it needed the spark plug cleaned and re gaped, now I can use the pole saw attachment and get some of these trees trimmed.
#653 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 28, 2011 - 01:41 PM
Too hot to do much! But I did take the Murray and trailer out to the garden and pull 60 lbs of onions, haul them to the garage to dry.
#654 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 28, 2011 - 03:33 PM
i romped on the wheel horse a bit. those 211-5's have a good front axle for off roading. its like independent front axles or something. not sure but i love it.
#655 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted July 30, 2011 - 08:59 PM
Painted the tank, frame, pump housing, and fly wheel for the #20 Air Compressor, painted the fiberglass fenders for the '63, and primed two sets of front and rear rims. Sun was hot, but the limited breeze kept me going. Tomorrow I'll apply a top coat of yellow to the rims, and mount a set of tires on the set of rims I painted last week.
#656 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted August 02, 2011 - 08:38 AM
started working on a shop build tow behind mower.
http://gardentractor...8076/#post84504
#657 KennyP OFFLINE
  • 37,393 Thanks
  • 45,448 posts
Posted August 07, 2011 - 03:01 PM
Worked on the 'new to me' JD 68. Had to pull the carb and clean out the old gas residue. Changed the plug, it started firing, then quit. Checked out what parts are needed to get it mowing again.
#658 NUTNDUN ONLINE
  • 10,336 Thanks
Posted August 07, 2011 - 03:46 PM
I got the carb kit put on the Bush Hog D4-7 and got it running pretty decent. I also worked on another guy's Wheel Horse Commando 800, the governor wasn't setup right and it would only go to about half throttle. I got that fixed in about 1/2 an hour and it does good now.
#659 olcowhand OFFLINE
  • 40,329 Thanks
  • 31,166 posts
Posted August 07, 2011 - 03:47 PM
Tubed a rear tire on the Allis 720 yesterday. Today I hooked up it's choke cable & ran a new starter solenoid wire.
#660 JDBrian ONLINE
  • 9,601 Thanks
Posted August 07, 2011 - 04:06 PM
I have been trying to get the 314 back together. The console was rusted bad on one side. It was also crooked so I straightened it when I was repairing the rust damage. Now when I go to attach the engine side covers they don't want to fit. And the front grill is also giving me trouble. I have been adjusting the location of the hood mount bracket to get the covers and the hood to all fit together. The front grill seems too close to the muffler. There is only about 1/2 inch between the muffler and the plastic mounting studs for the JD logo on the grill. I'll figure it out eventually but if anyone has any suggestions I'd like to hear them.
