* * * * * 1 votes
2460 replies to this topic
#631 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted July 02, 2011 - 10:25 PM
finished putting the rest of the decals on the 400 today and it sure looks better . worked on the front blade some you guys are going to like it . its 60" wide 24" tall with a 4" deep deflection, bend , radius . the blade was 55$ to have it sheered and rolled and the cutting edge isn't finished yet its some hardened steel they have to cut with the plasma cutter . there also going to cut the square holes for flush mount bolts .
#632 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 05, 2011 - 12:04 PM
Replaced the fuel Shutoff solenoid and wires to it on my Murray Yard King 22 hp 52" mower model 5216X089A, yesterday. It leaked gas and caught fire some time back and burnt the connector and shut down before I got it out. Got the parts last Wednesday. Then I had nothing for power to switch or solenoid.
I found a schematic today and found there is a 15 amp fuse between the ammeter and switch.
I'm betting that is blown and will check it out when I get home tonight.
#633 KennyP OFFLINE
  • 32,709 Thanks
  • 42,317 posts
Posted July 05, 2011 - 05:09 PM
Dusted off the Ford yesterday and took a little drive. It needed limbered up.
#634 bartman19b OFFLINE
bartman19b
  • 8 posts
Posted July 07, 2011 - 05:06 AM
Finished tearing the motor down and clean everything up so that when the parts come in today it's all ready to get put together
#635 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted July 07, 2011 - 08:29 AM
Pulled the deck off my Snapper 1600, cleaned up under the shields and installed new blades.
#636 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 07, 2011 - 09:36 PM
went back to the drawing board on the Murray, it would not run after I replaced the fuse.
Had to take the carb back down and change the location of the jet in the bowl so it was 90 degrees from the float hinge.
Then gave it a shot of starting fluid and now it's running fine.
#637 IamSherwood OFFLINE
  • 8,384 Thanks
Posted July 07, 2011 - 09:40 PM
Looked at it. That's all I had time for.
#638 jahkeymo3 OFFLINE
jahkeymo3
  • 14 posts
Posted July 08, 2011 - 09:39 AM
Dropped four speed peerless for a good cleaning. The shifter linkage needs fixed....
#639 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted July 08, 2011 - 10:21 PM
Pulled the carb. off the MF14 and gave it a good cleaning. Battery had gone down so I'm giving it a good slow charge over night.
#640 lsmith2610 OFFLINE
lsmith2610
  • 6 posts
Posted July 08, 2011 - 10:43 PM
New member folks. As for today i turned the pressure washer on my JD316. It was on it way to the salvage yard when I bought it.The onan runs great , But the steering has alot of slack any suggestions
#641 caseguy OFFLINE
Posted July 09, 2011 - 09:09 PM
I got a little bit of shop tim this afternoon and spent it working on the K90 that I'm hoping will end up in the RJ-58. It doesn't look good for the coil in this thing though. The insulation is badly cracked and the windings appear to be corroded significantly. On the up-side, I drained the oil out of it and it looks almost new!
#642 olcowhand OFFLINE
  • 37,434 Thanks
  • 30,270 posts
Posted July 09, 2011 - 09:14 PM
Got an oil pickup tube builkt for my CCKB engine that goes on my Allis 720. Oil pan on, engine buttoned up. Just the bolt on goodies left!
#643 KennyP OFFLINE
  • 32,709 Thanks
  • 42,317 posts
Posted July 10, 2011 - 01:29 PM
Reworked my Tow Hitch, cut 3 1/2" out of it and it works great. Got the Cub about 6" off the ground and worked fine.
I'm a happy tractor nut.
#644 olcowhand OFFLINE
  • 37,434 Thanks
  • 30,270 posts
Posted July 10, 2011 - 02:19 PM
Got my Allis 720 CCKB engine finished! Can't turn it over to check oil pressure yet, as I forgot to pick up an oil filter!!
#645 drbish OFFLINE
drbish
    Collecter
  • 1,401 Thanks
  • 1,263 posts
Posted July 10, 2011 - 04:22 PM
got my cub cadet original fired up today,after cleaning carb,would only go in 1st and reverse,i guess since it had sat so long the 2nd and third shifting linkage inside the gear boxwas stuck took shifter off and and loosened it up with a hammer and block of wood.Drove it around the neighboorhood,next willbe changing the fluids and rebuiding the carb.The kohler sounds good and does not smoke,this is the first kohler i have had ,suprised at the power it puts out
