* * * * * 1 votes
2496 replies to this topic
#601 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted June 13, 2011 - 07:24 AM
Yesterday I clean and re-organized the barn, and moved the LGT 145 to the shop to get it running again.
#602 greencoach47 OFFLINE
greencoach47
  • 8 Thanks
  • 85 posts
Posted June 13, 2011 - 09:34 AM
I spent 8 1/2 hours yesterday standing at a barrel and sandblasting parts for my MF10 restore, thankfull for the 6hp compressor that easily keep up with me.
#603 ad356 OFFLINE
ad356
  • 9 Thanks
  • 160 posts
Posted June 15, 2011 - 11:16 AM
mowed the lawn with the 147 worked on prepping the frame from the 124 for paint. getting that tractor ready for paint is allot of work. it stilll is surprising how much good metal is under that bad paint and rust.
#604 Bolens 1000 OFFLINE
  • 14,219 Thanks
  • 17,846 posts
Posted June 15, 2011 - 06:10 PM
Today I took the tiller off the Bolens 1050 and mowed some lawn with the Bolens 800
#605 KennyP OFFLINE
  • 34,226 Thanks
  • 43,339 posts
Posted June 19, 2011 - 05:38 PM
Stripped the deck I got from jpcubs so he can have the spindles back. Tried to break down one of the 8" wheels I got from him and broke the HF tire changer. Pulled the bolt head thru the bottom channel iron. Didn't know I was that strong. Made some 1/4" thick washers for those bolts, that should take care of that problem. Finally got it broke down and off the wheel. That sucker was stuck on there.
#606 loggerhenry OFFLINE
loggerhenry
  • 11 posts
Posted June 19, 2011 - 06:00 PM
picked up a JD 210 for $75. at a yardsale. brought it home and tinkered with it. i pulled it off of my trailer with my 582 IH. runs great now. just need to replace some broken parts and pieces.
#607 KennyP OFFLINE
  • 34,226 Thanks
  • 43,339 posts
Posted June 19, 2011 - 06:04 PM
Hope you got some pics pulling it off the trailer. LOL
#608 olcowhand ONLINE
  • 38,038 Thanks
  • 30,448 posts
Posted June 19, 2011 - 08:40 PM
Put a good coil & ballast resistor on my Bush Hog T-63, so she runs again. Put a battery into the Unico 15 & fired her up. Got the TJD powered Bush Hog JBI fired up, had a bad key switch. Ran the MF1010 a while, being she's sat idle for a while. Worked a bit on a fella's Case 224.....got the lift handle button working freely, checked the deck belt, & used grease needle to lube it's deck idler. Had a fun day!
#609 JDBrian OFFLINE
  • 9,596 Thanks
Posted June 20, 2011 - 09:59 AM
Started working on the 314 electrical wiring. Cleaned the ignition switch and male contacts and removed the female contacts from the connector and cleaned them. Lots of corrosion and dirt on the contacts. I need to rewire the safety interlocks for PTO , neutral switch and the seat switch is MIA so I need to buy or make one. One of the PO's disconnected all the interlocks. I'm also adding LED taillights.
#610 zr600 OFFLINE
zr600
  • 1 Thanks
  • 18 posts
Posted June 20, 2011 - 04:26 PM
Got my deck and new gator blades back on the deck today. But i need to get a bracket and new spring for the tensioner pulley.
#611 loggerhenry OFFLINE
loggerhenry
  • 11 posts
Posted June 21, 2011 - 04:47 PM
got sticker shocked for what JD gets for motormounts for a 210. $28.75 each...
#612 NUTNDUN OFFLINE
  • 10,299 Thanks
Posted June 21, 2011 - 04:49 PM
I am not doing anything with my tractors today. It is too stinkin hot out. I am going to a meeting though for the Dover show tonight if that counts :D
#613 KennyP OFFLINE
  • 34,226 Thanks
  • 43,339 posts
Posted June 21, 2011 - 05:45 PM
George, I feel the pain. By the time the weekend get here to work with the GT's, so many other household items have popped up, I ain't getting nowhere.
#614 MH81 OFFLINE
  • 29,909 Thanks
  • 29,736 posts
Posted June 22, 2011 - 11:17 AM
Yesterday was my last day of vacation, did a bunch of little household things I had hoped to accomplish, then tightened up the steering on the Sears 12. While I was under there, I noticed a leak on the rear end. Water had gotten in and raised the levels... looked like chocolate milk. Drain flush & Change. Then I adjusted the brakes on it & replaced the stretched springs on the belt tightener. Bunch of little maint items, but still felt good.
#615 JDBrian OFFLINE
  • 9,596 Thanks
Posted June 23, 2011 - 10:00 AM
Finished rewiring the 314 and changed out the wheel bearings in the front wheels. I had to kludge up a puller to get one off of each wheel. I was able to pound one out of each wheel then pulled the other one out. I probably could have done it with a bigger hammer but with the puller I didn't damage anything.
Edited by JDBrian, June 23, 2011 - 10:01 AM.
typo
