* * * * * 1 votes
2323 replies to this topic
#481 MH81 ONLINE
  • 27,985 Thanks
  • 28,942 posts
Posted April 29, 2011 - 05:14 PM
Going out to load up & take a few over to Plow Day.
#482 wvbuzzmaster ONLINE
  • 4,496 Thanks
  • 7,345 posts
Posted April 29, 2011 - 07:42 PM
I worked my ass off today to get the Caterpillar wired up for the big event. It is partially cobbled, not all of the way painted, but usable. Then I loaded them all up twice (tetris error the first time because the 444 wouldn't start so I loaded the others first).
Also: I would like to thank Alan for the use of his phone booth to pull this all off today, and Steve, it is your turn lol.
#483 KennyP ONLINE
  • 29,423 Thanks
  • 40,411 posts
Posted April 30, 2011 - 05:42 PM
Put the hood and side panels back on the Ford after re torquing the head. Got GTV/16 up where I could get the starter and fuel pump put on. Started it and let it run a while.
#484 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted April 30, 2011 - 05:53 PM
getting it ready for primer and pant . it should look new tomorrow .
#485 matts OFFLINE
matts
  • 48 Thanks
  • 166 posts
Posted April 30, 2011 - 06:09 PM
I fixed the rat nest that was the hacked up wiring on my 140. It started out as putting the tail lights on. Ended up as 50% rewiring the tractor. If people cant do something right, why do they bother doing it? Just leave it alone.
#486 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted May 01, 2011 - 07:29 PM
Finished the brackets to mount the blade without having to remove the deck. Tacked them on to make sure the fit is ok and will finish the welding soon.
#487 olcowhand OFFLINE
  • 36,191 Thanks
  • 29,974 posts
Posted May 01, 2011 - 07:45 PM
[ATTACH=CONFIG]14115[/ATTACH]
And he got the coolant leak repaired too. I showed him how to braze. Fred's new to acet. torch.
#488 olcowhand OFFLINE
  • 36,191 Thanks
  • 29,974 posts
Posted May 01, 2011 - 07:48 PM
I did some more on FIL's Onan today. All back together, & machined a spacer for the pto clutch. Will bench run later this week.
#489 Bolens 1000 OFFLINE
  • 12,923 Thanks
  • 17,296 posts
Posted May 01, 2011 - 07:50 PM
I replaced the drive belts on my Bolens 1050 after a long day of tilling the garden.
#490 matts OFFLINE
matts
  • 48 Thanks
  • 166 posts
Posted May 02, 2011 - 09:23 AM
Im about to go out and rebuild the carb on the JD285. Then I will reinstall the headlights, and get it all together. May tear the deck apart for the rebuild.
#491 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted May 02, 2011 - 04:49 PM
I forgot about that, I could start a new tread with all the help he has given me--- What did Daniel do to my tractor today :smilewink:
He made it look easy, no telling what kind of mess I'll make when I give it my first try :(
#492 Sparky OFFLINE
Sparky
  • 1,295 Thanks
  • 1,892 posts
Posted May 02, 2011 - 05:25 PM
Moved my E16 " bicentennial " into the empty spot where Casey's used to be.
#493 ducky OFFLINE
  • 1,823 Thanks
  • 3,992 posts
Posted May 02, 2011 - 06:15 PM
Loaded the snapper 1650 up so Lil Bro could try to work some garden Ground.
#494 matts OFFLINE
matts
  • 48 Thanks
  • 166 posts
Posted May 02, 2011 - 07:10 PM
Well I was right. I redid the carb on the 285. Then tore the deck down and ordered the bearings for it. Cheap too, if you need JD bearings let me know. $5 each. After the 285 was as done as it can be I went to the 140. I was told that the tires had to be skinny due to the smaller deck. Obviously somone either didnt want the tires I got, or didnt know they were dead wrong. The 10.5 tires went on with plenty of room to spare. Im glad I didnt buy new 8.5s based on the wrong info I was given. After the tire change, I decided to correctly install the head lights on the 140. Maybe in a another month I will have undone all the stuff on the 140 that isny right.
#495 Tinkerer OFFLINE
Tinkerer
  • 18 Thanks
  • 200 posts
Posted May 02, 2011 - 09:02 PM
I installed the new air filter and tested the voltage regulator/rectifier on the Sears SS12. The voltage regulator is putting out voltage but backwards from the way it is suppose to be. I guess I will be replacing that soon. I also installed the sickle bar mower and cut a couple of bushes.0502112054.jpg I don't know of any 'garden tractor' manufacturer that manufactures or sells this implement option.
