* * * * * 1 votes
2429 replies to this topic
#31 coldone OFFLINE
coldone
  • 1,643 Thanks
  • 1,677 posts
Posted November 13, 2010 - 07:47 AM
I made a clean spot on the L8 today. I had finished converting the L to an L8 and wanted to fix a few minor problems while I had it in the shop. There appeared to be a leak in the gas tank. It was on the left hand side and the OP had caked on the epoxy to try and stop it. I pulled the tank and tried to get the epoxy off so I could see the leak. I tried chipping it off and got frustrated so i grabbed the side grinder with a wire brush on it. Well I got the epoxy off, and the paint too. There was no way to match new paint to the old so I had to go ahead and strip the rest of the tank and paint it. I figured it would look even more crappy to put a freshly painted tank onto the old paint fan shroud, so i pulled all the sheet metal, clean and painted it too. My 5 minute job turned into half a day and I still have to put it back together.
So becareful of making a clean spot!
  • janiecv16 said thank you
#32 caseguy OFFLINE
Posted November 13, 2010 - 08:22 AM
...My 5 minute job turned into half a day and I still have to put it back together...So becareful of making a clean spot!
You sound a lot like me LOL! I've done that myself a few times. Makes you think twice about starting something that could get too "involved"! Sounds like you had fun though!
#33 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted November 14, 2010 - 09:11 PM
Replace the stained and unusable hydro fluid check line and put my E-Bay light brackets on:pIMG00309-20101114-2041.jpg
#34 MH81 ONLINE
  • 28,824 Thanks
  • 29,246 posts
Posted November 14, 2010 - 11:04 PM
Not to a tractor, but to the workspace. Swept, and finished prep work for Ryan's Tractor to come in... last item to do is Build another bench on a "found" wall. Never to many flatspots when I'm around. LOL
#35 Chuck_050382 OFFLINE
Chuck_050382
  • 273 Thanks
  • 1,498 posts
Posted November 15, 2010 - 08:48 AM
Sat morning before I could go to the plow day I swapped my loaded and chained turfs on the LGT 165 that I was plowing with.
#36 scout girl OFFLINE
scout girl
  • 8 Thanks
  • 18 posts
Posted November 15, 2010 - 11:02 AM
I finished getting the engine back in the 1250 and took it up and down the driveway a few times. It is amazing how much quieter it is when the muffler doesn't have a second hole in it the size of a baseball. And the new engine mounts really took the shakes and hard rattles out of it.
I also picked up a snow blade for it that needs a little bit of attention.
#37 grand OFFLINE
grand
  • 1,790 Thanks
  • 1,944 posts
Posted November 17, 2010 - 06:03 PM
The wife and I went to the hardware store to get some paint for the trim around the front door. While we were there I picked up a can of SeaFoam to treat the gas in the tractors. As soon as we got home I put some in the gas tanks of all eight tractors. Some of the fellows swear by it so we might as well try it.
#38 olcowhand ONLINE
  • 37,171 Thanks
  • 30,204 posts
Posted November 18, 2010 - 09:05 PM
I built this vari-speed control handle for my Bush Hog V4-6 out of an implement lift handle from an Allis 410 garden tractor.
  • JRJ said thank you
#39 Tinkerer OFFLINE
Tinkerer
  • 18 Thanks
  • 200 posts
Posted November 18, 2010 - 09:35 PM
Today was modification day. When I received my Bolens 1600H with mower deck and bagger I was missing a set of critical pulleys. Today I added an engine to the mower deck to run the blower for the bagger. I received a 6 Hp motor from pressure washer the other day. The motor ran fine and so I decided to attach the motor to my mower deck and run the blower so that I could pick up leaves. It took me about 3 hours to engineer how I was going to attach it, find a pulley that would fit on the motor and find a short belt. I had all the pieces around from other pieces of equipment that people had given me and the belt was saved from an old treadmill I disassembled years ago. After getting the motor where I wanted and mounted, I gave it a test run. This first test run didn't last long as one of the motor mount bolts loosened up. I changed this bolt out for a different one that wouldn't come loose. The next test run went well. I used my neighbors yard that was covered with leaves and did some lawn cleanup. I have decided after mounting the mower that I will have to design and fabricate the bolt I need to hold the pulleys on this winter as the motor makes the mower deck a little to heavy on one side and therefore wants to dig into the lawn. Here are a couple of pictures with the motor mounted to the mower deck.1118101559a.jpg
#40 massey driver ONLINE
massey driver
  • 1,202 Thanks
  • 1,488 posts
Posted November 18, 2010 - 09:38 PM
[ATTACH=CONFIG]7212[/ATTACH][ATTACH=CONFIG]7213[/ATTACH]
Looks like it's made to fit and work.If you wouldn't have said what It was I'd have figured it came from new like that.BTW I see I'am not the only one who salvages stuff from other machines to make work on the ones that we fix up.Larry
#41 Bolens 1000 ONLINE
  • 13,605 Thanks
  • 17,557 posts
Posted November 18, 2010 - 09:54 PM
Today was modification day. When I received my Bolens 1600H with mower deck and bagger I was missing a set of critical pulleys. Today I added an engine to the mower deck to run the blower for the bagger. I received a 6 Hp motor from pressure washer the other day. The motor ran fine and so I decided to attach the motor to my mower deck and run the blower so that I could pick up leaves. It took me about 3 hours to engineer how I was going to attach it, find a pulley that would fit on the motor and find a short belt. I had all the pieces around from other pieces of equipment that people had given me and the belt was saved from an old treadmill I disassembled years ago. After getting the motor where I wanted and mounted, I gave it a test run. This first test run didn't last long as one of the motor mount bolts loosened up. I changed this bolt out for a different one that wouldn't come loose. The next test run went well. I used my neighbors yard that was covered with leaves and did some lawn cleanup. I have decided after mounting the mower that I will have to design and fabricate the bolt I need to hold the pulleys on this winter as the motor makes the mower deck a little to heavy on one side and therefore wants to dig into the lawn. Here are a couple of pictures with the motor mounted to the mower deck.[ATTACH=CONFIG]7214[/ATTACH][ATTACH=CONFIG]7215[/ATTACH][ATTACH=CONFIG]7216[/ATTACH]
Very Nice Fabrication :thumbs:
#42 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted November 18, 2010 - 10:23 PM
Got to turn a wrench on the JD430 I picked up a few weeks ago. Won a seat off e-bay, it has a rip on one side, but MUCH better than what was on it.
#43 Tinkerer OFFLINE
Tinkerer
  • 18 Thanks
  • 200 posts
Posted November 19, 2010 - 08:35 PM
Today I exchanged the 8.5 inch wide tires on my 1969 Bolens 1220 for the studded 10.5 inch wide tires on my 1973 Bolens G14 parts machine. I then removed the mower for the season and mounted the 38 inch snow blower. I need to change the oil to the winter formula and come up with some weight for the back of the 1220 before snow flies but that will have to be next week sometime.
Jonathan
#44 Bolens 1000 ONLINE
  • 13,605 Thanks
  • 17,557 posts
Posted November 19, 2010 - 08:37 PM
Jonathan
Lets see some pics of it! :D
#45 olcowhand ONLINE
  • 37,171 Thanks
  • 30,204 posts
Posted November 19, 2010 - 08:53 PM
[ATTACH=CONFIG]7218[/ATTACH][ATTACH=CONFIG]7217[/ATTACH]
Looks so much better Fred! Just think how good it would look repainted.......RED!:bigrofl:
