* * * * * 1 votes
2586 replies to this topic
#2581 Greasy6020 ONLINE
Greasy6020
  • 1,383 Thanks
  • 1,343 posts
Posted January 09, 2018 - 04:57 PM
Got the pulleys figured out on the Sears lt11 and got the rear end in place. Had to move it forward to work with the original belt...
Just need to put tires back on then should be ready for the road
#2582 Greasy6020 ONLINE
Greasy6020
  • 1,383 Thanks
  • 1,343 posts
Posted January 10, 2018 - 09:13 PM
Hooked up the clutch after a test run (see the "what did you do with your tractor" thread) and then started swapping stock tires for atv tires off of a junk atv behind the school
Sears lt11 from the scrapyard needs some ignition work... For now I'll jump it at the starter
  • toppop52 said thank you
#2583 Greasy6020 ONLINE
Greasy6020
  • 1,383 Thanks
  • 1,343 posts
Posted January 11, 2018 - 04:03 PM
Cut up the stock rims to make some adapters to fit on some atv rims I "borrowed" from a junk atv behind the shop...
Gonna have some decent atv tires now!
#2584 mrmd OFFLINE
mrmd
  • 248 Thanks
  • 131 posts
Posted January 11, 2018 - 09:00 PM
Installed a winch on the back of my tractor so I don,t have to use the Armstrong method.
  • KennyP and toppop52 have said thanks
#2585 Greasy6020 ONLINE
Greasy6020
  • 1,383 Thanks
  • 1,343 posts
Posted January 12, 2018 - 11:23 PM
Did a brake job and put my ugly adapters and atv tires on the Sears lt11
#2586 Greasy6020 ONLINE
Greasy6020
  • 1,383 Thanks
  • 1,343 posts
Posted January 18, 2018 - 08:20 PM
Put a bicycle drive chain around the front left tire of the Sears lt11 so fix my understeer problem
  • Alc and toppop52 have said thanks
#2587 toppop52 ONLINE
toppop52
  • 5,038 Thanks
  • 4,644 posts
Posted Yesterday, 06:05 PM
Got my old Cub Cadet 1864 running, turned out to be a combo of cold, weak battery and flooding. Cleaned the plugs and they were firing fine, fuel pump was working, so put it together and it fired up with the charger and booster pack on it. I knew it was weak because it would fire when I let off the key, so I added the booster pack to the mix and it started right up.
Worked on the driveway a bit basically just to charge it and run it some.
  • EricR said thank you
