* * * * * 1 votes
2586 replies to this topic
#2551 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted October 28, 2017 - 07:18 PM
Today I got the Bolens 18148 two stage snowblower mounted to my Bolens/Iseki G152. It was an easy retrofit. The mounting ears on the tractor had to get squeezed in 1/2". The pin for bottom of the lift cylinder has a spot built into the frame of the blower already.
The hydraulic connections on my Iseki are not compatible with the blower. Not to mention 3 out of 4 of my hoses have no rubber coating left on them, so they kink easy. Ordered all new hoses and the necessary connections, I hope.
The blower spun up fine, but the lift cylinder needs some help. I do not have the helper springs yet. Working on a counterweight box now.
Tomorrow, figure out why the glow plugs went on siesta.
Edited by Cat385B, October 28, 2017 - 07:20 PM.
  • KennyP, toppop52, dualresponse1731 and 1 other said thanks
#2552 wbakunis OFFLINE
wbakunis
  • 219 Thanks
  • 190 posts
Posted October 31, 2017 - 04:37 PM
Was given these two 2010 LandLords. Stripped them down. Today I started to put one good tractor together.
  • KennyP, EricR and dualresponse1731 have said thanks
#2553 wbakunis OFFLINE
wbakunis
  • 219 Thanks
  • 190 posts
Posted November 07, 2017 - 06:02 PM
New rear tires for the b10. Nanco Super Lugs. They're quite nice.
Edited by wbakunis, November 07, 2017 - 06:03 PM.
  • KennyP, dualresponse1731 and pryan05 have said thanks
#2554 John Arsenault ONLINE
John Arsenault
  • 2,425 Thanks
  • 1,167 posts
Posted November 07, 2017 - 06:28 PM
I welded a trailer tongue to the back of the tank I use for a ballast so I can pull a trailer while I have the ballast on.
10 minutes and a piece of scrap metal, makes life much easier. Mission accomplished.
  • KennyP, MFDAC, EricR and 3 others have said thanks
#2555 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted November 18, 2017 - 10:35 PM
Per post #2551 above, I got the heaviest springs I could find at the hardware store, and some turnbuckles. She now lifts up about 4" or so. The glow plug issue was a wire out of a spade connector.
New hoses from Surplus Center, the quick connects to the chute swivel were purchased from Grainger.
Weight box is about 400 pounds. With the blower and weight box, this is probably pushing a ton. 7&1/2 hp per thousand pounds. I am not going to do well at the drag strip.
This combo is working great, it's scaring all the snow away. So, if it isn't getting used I might as well wash and wax it. The most important tool for waxing a two stage blower is lots of patience.
Next up is an electric actuator for the chute tip control.
Edited by Cat385B, November 18, 2017 - 10:47 PM.
  • limebuzz, KennyP, toppop52 and 2 others have said thanks
#2556 John Arsenault ONLINE
John Arsenault
  • 2,425 Thanks
  • 1,167 posts
Posted November 19, 2017 - 04:58 PM
I took the engine that I had in this thing
And put it into this thing.
  • limebuzz, KennyP, Z71 Sierra and 1 other said thanks
#2557 KennyP ONLINE
  • 37,560 Thanks
  • 45,538 posts
Posted November 19, 2017 - 05:47 PM
Nice looking 'thing'!
#2558 pryan05 OFFLINE
pryan05
    LGT
  • 618 Thanks
  • 342 posts
Posted November 20, 2017 - 08:37 PM
After moving some snow to make a skating rink I was backing the Ford into the garage when the blower suddenly dropped and would not move up any more.  After cycling the actuator a few time the culprit just fell right off.  Ends up that the pivot shaft that the hydraulic cylinder is connected to had one of the arms break of.  It was a pain to get out... seized... the cylinder pin needed to be cut off the frame it was... seized.  The 3/4" mounting pin would not budge with my 20 ton press.  I drilled it out 1/2" and knocked it out with an air hammer.  Welded a new pin on the tractor frame and welded the rocker shaft back together.  It still needs to be all put back together.
  • limebuzz, KennyP and John Arsenault have said thanks
#2559 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted November 23, 2017 - 09:58 PM
I was a bit worried about the blower not lifting all the way up. I think there would of been issues when it filled up with snow. I picked up 2 more springs and installed them. They are more of angle, but now the blower lifts all the way up with the tractor at an idle.
#2560 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted November 23, 2017 - 10:14 PM
Installed the blower for a local parade.
#2561 Greasy6020 OFFLINE
Greasy6020
  • 1,383 Thanks
  • 1,343 posts
Posted November 25, 2017 - 08:27 PM
Did an embarrassing wiring job for a hokey looking light bar and tail lights on the Moto mower
#2562 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted November 25, 2017 - 08:43 PM
I felt like I was working on Apollo 13 with the power (Amp) management trying to erk every amp from the Roper for the Trailer Parade Float.
  • Alc, KennyP, toppop52 and 3 others have said thanks
#2563 Z71 Sierra ONLINE
Z71 Sierra
  • 162 Thanks
  • 96 posts
Posted November 26, 2017 - 05:06 PM
  • Mark 149 J. said thank you
#2564 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted November 27, 2017 - 04:55 PM
Lost a rod to the battery holder on the 16/6 so I made a new one with the rod bender I made yesterday . Meant to work on the 110 today just didn't get around do it.
  • toppop52 said thank you
#2565 MFDAC OFFLINE
MFDAC
  • 3,162 Thanks
  • 1,571 posts
Posted December 03, 2017 - 08:40 PM
I've had nothing to report for a long time but it sounds like we may get a mini-blizzard tomorrow. I figured it was time to get the MF12G ready to push some snow.
I pulled off the mower deck, reversed the rear wheels, installed the blade and chains. Greased the zirks and aired up the tires. Now I hope it won't be needed---LOL!
I also wanted to check and see if pics are still loading ok on the site so that's why I posted so many.
DAC
  • limebuzz and KennyP have said thanks
