* * * * * 1 votes
2595 replies to this topic
#2506 SimplyRad OFFLINE
SimplyRad
  • 1,100 Thanks
  • 839 posts
Posted August 27, 2017 - 10:11 AM
Washed the JD 100, getting ready for our Labor Day show,  West Liberty Ohio.
Found a mouse nest under the tin, took off the hood and tin and cleaned out the nest.
Luckily their was no wires chewed,  drained the fuel and put in new fuel filter.  Started right up.
I must have a serious talk with my barn cat, she is in charge of rodent control !!
Need more info on the show, directions, dates.
  • toppop52 said thank you
#2507 Greasy6020 ONLINE
Greasy6020
  • 1,476 Thanks
  • 1,399 posts
Posted August 29, 2017 - 12:49 AM
Redid motor mounts on the moto mower with my sister... one dropped out, stepmom found the washer in the driveway.
Probably taught her some more of my grasp of the English language, the air musta been blue.
Also did an oil change on the roper rt16
Edited by Greasy6020, August 29, 2017 - 12:56 AM.
#2508 toppop52 ONLINE
toppop52
  • 5,253 Thanks
  • 4,757 posts
Posted August 29, 2017 - 12:39 PM
Mounted my sleeve hitch on the CC1864, still looking for an actuator.
#2509 lrhredjb OFFLINE
lrhredjb
  • 697 Thanks
  • 569 posts
Posted September 01, 2017 - 08:50 AM
Mounted my new/used seat I got at Portland show for $15 on my CC 106. It's in great shape and the back is higher than the old seat, also thicker padding. Bolt pattern also matched perfectly. My old seat was a cover type thing that kept sliding off when I mowed.
  • KennyP, toppop52 and Mark 149 J. have said thanks
#2510 John Arsenault ONLINE
John Arsenault
  • 2,565 Thanks
  • 1,212 posts
Posted September 01, 2017 - 07:48 PM
Well I successfully fit a new engine in my 1968 Sears SS12 Hydro, although its not exactly a 68 anymore because of the engine swap and then the needing to swap out front grill and hood with a 69 I had so that I could accommodate the air cleaner, Id say the swap went pretty good. The hardest part for me was cutting into this old survivor but I was running out of Tecumseh parts, fining many parts were no longer available. I need this tractor for mowing and snow blowing so plan to use it many more years so sprung for a new engine.
The reason I used the 69 grill is because I had to cut it away to fit the engine and did not want to cut the 68 grill up, plus the 69 fit perfect for this engine I think by taking both sides of the grill off it now has a pretty cool look, but all in all I don't care to much because after all its all about blowing snow for this tractor.
No cutting needed to this side of the grill can fit my pinky in between the exhaust and the grill.
I could not think of a better place for the exhaust to exit. With the hood shout you can't get burned by this one.
Sorry Tecumseh but it was not practical for me to hold on to your well built steed of an engine, now lets see if the Subaru will have the life it needs to wear out this Sears hydro rear end...lol
  • jhn9840, CRFarnsworth, toppop52 and 2 others have said thanks
#2511 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted September 01, 2017 - 10:18 PM
I like it! Keeps it going much longer. I wonder if the engineers expected their creations to last this long.
  • toppop52 and John Arsenault have said thanks
#2512 John Arsenault ONLINE
John Arsenault
  • 2,565 Thanks
  • 1,212 posts
Posted September 04, 2017 - 05:56 AM
I just hope this engine can wear this tractor out. The tecumseh tried for 50 years.
#2513 lrhredjb OFFLINE
lrhredjb
  • 697 Thanks
  • 569 posts
Posted September 08, 2017 - 02:35 PM
I put a tube in the leaky front tire of my CC. Had to pump it up every time I needed to mow. Even though it's only an 8'' wheel I got quite a workout putting the tire back on. I used the trick one of the members posted about using the vise grip pliers on one side of the rim when installing. Time for a brown pop break!
  • KennyP and toppop52 have said thanks
#2514 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 08, 2017 - 02:50 PM
I probably made that post! Do it often when putting tires on the rims. My wheel holder makes a bunch of difference!
#2515 lrhredjb OFFLINE
lrhredjb
  • 697 Thanks
  • 569 posts
Posted September 08, 2017 - 04:52 PM
After tubing the leaky front wheel I got out my IH #2 cart and washed it. Then took my grandaughter for a ride in the yard. She was fascinated with the tools I had out for the work. She is 21 months old.
  • limebuzz, KennyP, toppop52 and 1 other said thanks
#2516 dualresponse1731 OFFLINE
dualresponse1731
  • 255 Thanks
  • 175 posts
Posted September 10, 2017 - 11:06 AM
Inspired by the "how do you like your tractor?" thread- I got off my butt and washed mine! Usually I just hit it with a leaf blower after mowing  to clean the grass off it. Maybe about twice a year I get out and wash it. I don't like water in the deck.
Standing back about 15 feet makes all the scratches go away!  :D
  • KennyP, toppop52 and pryan05 have said thanks
#2517 toppop52 ONLINE
toppop52
  • 5,253 Thanks
  • 4,757 posts
Posted September 10, 2017 - 12:14 PM
Discovered that the front blade mount on the 1864 had one nut out of three, and it was loose. I fixed that and tightened up a bunch of stuff that was loose.
#2518 Greasy6020 ONLINE
Greasy6020
  • 1,476 Thanks
  • 1,399 posts
Posted September 10, 2017 - 10:31 PM
Well, I gotta go about 7.5 feet away, looks showroom condition, no scratches!
Hehehe maybe that's why I have glasses🤦🏻‍♂️
  • toppop52 and dualresponse1731 have said thanks
#2519 Greasy6020 ONLINE
Greasy6020
  • 1,476 Thanks
  • 1,399 posts
Posted September 10, 2017 - 10:33 PM
Broke the seat on the roper rt16. Cussed at the roper and Then I made sure it was broke.
Pillaged the seat from the sears crapsman and installed on the roper. That seat is a bunch stiffer...
#2520 wbakunis OFFLINE
wbakunis
  • 219 Thanks
  • 190 posts
Posted September 15, 2017 - 06:30 PM
Used "Bar Keepers Friend" cleaner on the B10 & Wonderboy.
