* * * * * 1 votes
2549 replies to this topic
#2476 MolonLabe ONLINE
MolonLabe
    Rust Wrangler
  • 536 Thanks
  • 305 posts
Posted June 14, 2017 - 08:27 AM
Replaced the front spindle and king pin bushings, all 8 of them on the 999. Instead of the factory nylon I used oilite bearings from Mcmaster-Carr. Less than half the price of the factory bushings. PN# 2938T26
  • EricR and toppop52 have said thanks
#2477 SimplyRad OFFLINE
SimplyRad
  • 863 Thanks
  • 688 posts
Posted June 14, 2017 - 08:59 AM
I added a trailer hitch to my 7112 so I can move my trailer.
  • toppop52 and pryan05 have said thanks
#2478 buckhvnter3 OFFLINE
buckhvnter3
  • 19 Thanks
  • 23 posts
Posted June 17, 2017 - 03:21 PM
Replaced the front axle assembly on my JD LT155. Had a lot of play at front axles. Originally had the welded steel axle and solid tie rods. Found a cast iron axle on ebay for 38bucks! Hard to pass it up. Also did a little fab. work on the tie rods and now they are adjustable to correct toe in! Great Day!
#2479 TAHOE OFFLINE
TAHOE
  • 7,740 Thanks
  • 5,580 posts
Posted June 18, 2017 - 12:13 PM
Made a clutch rod on my Sears suburban Saturday, it has been grinding gears for some time, new belt, islets and brake band and I could not get adjustment properly. I had either good shifting w/no brakes or brakes with grinding gears. I made this up with a piece of all thread, nuts and found bar. Got it on and adjusted, now I have no grinding and great braking.
  • jhn9840, KennyP, dropped82 and 2 others have said thanks
#2480 dtsh OFFLINE
dtsh
  • 221 Thanks
  • 143 posts
Posted June 24, 2017 - 09:53 PM
Pulled the deck off the Bolens H-16 because the last time I used it, the belt broke. Took the opportunity to clean the deck, make some minor repairs while I had it out and apart.
#2481 Greasy6020 OFFLINE
Greasy6020
  • 1,219 Thanks
  • 1,184 posts
Posted July 18, 2017 - 10:42 PM
Looked at it and apologized for leaving it outside.
Then thought about how good the roper rt16 would look with duals
  • pryan05 said thank you
#2482 wbakunis OFFLINE
wbakunis
  • 208 Thanks
  • 186 posts
Posted July 27, 2017 - 03:14 PM
Started putting the sears custom 6 back together.
Edited by wbakunis, July 27, 2017 - 03:14 PM.
  • CRFarnsworth and pryan05 have said thanks
#2483 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,325 Thanks
  • 1,994 posts
Posted July 27, 2017 - 08:23 PM
That's looking real nice.  :thumbs:      If you want more practice I have two XL10's that need done.  :D     Rick
  • wbakunis said thank you
#2484 toppop52 OFFLINE
toppop52
  • 4,725 Thanks
  • 4,447 posts
Posted July 29, 2017 - 10:30 AM
#2485 Greasy6020 OFFLINE
Greasy6020
  • 1,219 Thanks
  • 1,184 posts
Posted July 29, 2017 - 10:51 AM
Cooked em... that's no good!
  • KennyP and toppop52 have said thanks
#2486 toppop52 OFFLINE
toppop52
  • 4,725 Thanks
  • 4,447 posts
Posted July 29, 2017 - 06:26 PM
They are well done....for!
#2487 esbbent ONLINE
esbbent
  • 371 Thanks
  • 219 posts
Posted July 29, 2017 - 08:17 PM
Painted some MF red on parts for the 14 going thru restoration. The rest of the day spent working on a guys 8N ford that he just bought. Ignition tune up then ended up having to replace the fuel bowl shut off due to it being rusted shut. After I gas flowing it was pouring out of the carb, pulled the carb apart everything rusted up. First time i have ever seen green algae inside a carb. Ended up doing a full carb rebuild, tractor now runs. Tomorrow it will get and engine oil change.
  • KennyP and pryan05 have said thanks
#2488 Alc ONLINE
  • 6,437 Thanks
  • 7,242 posts
Posted July 30, 2017 - 06:01 AM
I had brought my son's White GT 2550H to my house this week because it just didn't to have the power and when the blade were engaged the whole thing just vibrated . I was hoping it was maybe a bad plug or , since it has 2 carbs maybe one needed cleaning but ,changing a plug didn't do anything and checking the exhaust temp..compression  confirm a dead cylinder . Pulled the valve cover off and saw the push rod off got me excited thinking it was just a adjuster that had backed off , nope valve was stuck open because the seat had come  off  . Tuff part was getting the keepers off . I made a tool but even after getting the seat close to going back in place you could only compress the spring just enough to get them out , I guess I should be honest here that my wife was helping me as I was having a hard time getting them off then after about 5 minutes she said to just use a screwdriver  and after being married 32 years I knew I had to at least try , which worked in just a few seconds lol
  • KennyP, MolonLabe, Mark 149 J. and 1 other said thanks
#2489 wbakunis OFFLINE
wbakunis
  • 208 Thanks
  • 186 posts
Posted July 31, 2017 - 04:46 PM
Thanks. If you were closer I would love to help with restoring your two XL10s. Those are my favorite sears tractors. Been trying to find another after I got rid of mine. :worshippy1:
  • toppop52 said thank you
#2490 MGP59DB OFFLINE
MGP59DB
  • 1,486 Thanks
  • 710 posts
Posted August 13, 2017 - 08:35 PM
Tore into my new acquisition , found a wiring issue and reset the gaps, cleaned the flywheels parts, got the spark HOT and fired it up :rocker2:
  • jhn9840, KennyP, toppop52 and 2 others have said thanks
