* * * * * 1 votes
2492 replies to this topic
#2431 Greasy6020 OFFLINE
Greasy6020
  • 1,036 Thanks
  • 983 posts
Posted April 25, 2017 - 06:22 PM
Stuck a new fuse in the roper rt16 so I have lights... probably gonna be hooking up the snowblower arse deep in snow and miserable weather.
  • toppop52 and 637Yeoman have said thanks
#2432 Greasy6020 OFFLINE
Greasy6020
  • 1,036 Thanks
  • 983 posts
Posted April 26, 2017 - 06:25 PM
Well I wasn't joking about miserable weather!
Have upwards of 1" of frozen rainy crap...
Busted the seat on the roper today, beating frozen crap off.
More in the "what did I I do with" thread...
  • 637Yeoman said thank you
#2433 MGP59DB OFFLINE
MGP59DB
  • 1,427 Thanks
  • 686 posts
Posted April 26, 2017 - 06:59 PM
I found a replacement idler pulley for the deck on Dusty the Hoveroni. :D
Just until I can get the original cast iron one machined to remove the old bearing and fit a replacement . So it can be kept it original.
I want to be able to use it for now .
  • Alc, CRFarnsworth, Newpaws493 and 2 others have said thanks
#2434 637Yeoman ONLINE
637Yeoman
  • 1,543 Thanks
  • 1,249 posts
Posted April 26, 2017 - 08:25 PM
Put a car coil on it, wired everything including switch
  • toppop52 and Mark 149 J. have said thanks
#2435 lrhredjb OFFLINE
lrhredjb
  • 465 Thanks
  • 419 posts
Posted April 27, 2017 - 11:10 AM
I like the "Jetsons" styling,very avant garde.
  • MGP59DB and 637Yeoman have said thanks
#2436 lrhredjb OFFLINE
lrhredjb
  • 465 Thanks
  • 419 posts
Posted April 27, 2017 - 11:12 AM
You beat me to it. Hahaha!!!
Just finished up the build of a front weight bracket. At the first plow day I took it to, the frontend spent the whole time in the air. That was with a 10" plow and I want to hook the 12 to the 3 point.
This
Plus this
Equals this
I think 2 of these should keep it grounded. Not bad for a deck bracket repurpose.
Eric
Now I know what to do with all those old brake rotors sitting around.
  • dropped82 said thank you
#2437 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted April 27, 2017 - 10:37 PM
Started on repairing the Deere 420 wiring tonight. It decided to short out and meltdown on me. Luckily I hoard, I mean save things. Keeping an old harness gave me the prongs and wire pigtails I needed to make this repair easier. I also did some improvements where I see issues. Heavier wire for the charging system and pto clutch. I might even add a relay in the pto system to ensure it gets good power.
  • Newpaws493, 637Yeoman and Mark 149 J. have said thanks
#2438 toppop52 OFFLINE
toppop52
  • 4,566 Thanks
  • 4,282 posts
Posted April 28, 2017 - 08:35 PM
I worked on my combo garbage can lift/wagon tongue hitch. Works better now, for the wagon pulling.
#2439 Alc ONLINE
  • 6,310 Thanks
  • 7,150 posts
Posted May 04, 2017 - 05:39 AM
My son and I replaced a front tire on his White 2550GT , to most of you members working with you kid doing mechanical things is pretty common but my son ( 27)  was never interested in things like that until he now needs to do it himself or PAY SOMEONE !!!!!    and he's cheap lol   The old tire came off easy but the new tire that came yesterday had packing tape wrapped around and deformed  it pretty good and the bead wouldn't seat  We tried the normal stuff , removed the valve stem , plenty of soap to try sealing the bead , then rope around it , still no good . Then I took the quick fitting out of the tire chuck , wrapped a ratchet binder twice around the tire and when ready stuck the quick fitting into the hose for an unrestricted air flow ,  that did it , bead seated , stuck my finger on the valve stem until I could put the core back . Kind of glad he learned a little more things
  • KennyP, toppop52, 637Yeoman and 1 other said thanks
#2440 glenford7502 OFFLINE
glenford7502
  • 88 Thanks
  • 70 posts
Posted May 06, 2017 - 03:43 AM
Tahoe it's a four bolt spindle off some sort of implement not real sure. Should work ok I hope. Still haven't finished it been pondering the steering. I want it to steer as sharp as I can. This tractor mainly is used around the yard and for moving dead mowers or what ever the three point will pick up. Does see some dirt work now that I weighted the back. It's about unstoppable with 110lb a side. Cross your fingers I might fiddle with it this weekend.
#2441 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted May 06, 2017 - 06:02 PM
Bad day mowing!!! After rewiring the 420 and getting it all in tip top shape, this happened. Clearly not my year with this thing. It was starting to put out a smell last year so I guess it was coming. I tried to stay on too of the adjustments. Oh well, it's only money right!!! Plus I need to hunt for another jackshaft pulley. It's showing signs of being loose.
  • toppop52 said thank you
#2442 TAHOE ONLINE
TAHOE
  • 7,596 Thanks
  • 5,516 posts
Posted May 06, 2017 - 08:43 PM
Removed winch mount for mower duty. As I was lubing up the spindles, I found a crack in the deck. Grabbed the flux core welder, hopefully fixed it. Cut the garden area, both goat pens and started on the field, the little MTD would not have touched it.
#2443 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,369 Thanks
  • 4,079 posts
Posted May 06, 2017 - 08:50 PM
Nice catch! One day I might get a flux core welder instead of farming out my welding needs.
  • TAHOE said thank you
#2444 MH81 OFFLINE
  • 29,899 Thanks
  • 29,726 posts
Posted May 06, 2017 - 09:40 PM
Got it muddy ☺️
#2445 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted May 07, 2017 - 12:42 AM
No after pics?
