* * * * * 1 votes
2492 replies to this topic
#2416 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted April 17, 2017 - 02:59 PM
:tmi:.
:bigrofl:
You beat me to it. Hahaha!!!
Just finished up the build of a front weight bracket. At the first plow day I took it to, the frontend spent the whole time in the air. That was with a 10" plow and I want to hook the 12 to the 3 point.
This
Plus this
Equals this
I think 2 of these should keep it grounded. Not bad for a deck bracket repurpose.
Eric
  • KennyP, MFDAC, Kster526 and 1 other said thanks
#2417 Kster526 OFFLINE
Kster526
  • 590 Thanks
  • 369 posts
Posted April 17, 2017 - 03:10 PM
Well today I tore the carb off the restored 208 as she had a little dirt problem.
Installed an inline filter and shut off in line under the tractor where the fuel line
runs which will also help with Winter storage and act as an anti theft device.
The carb is no longer nicely painted black to match the engine but she runs better
#2418 KennyP ONLINE
  • 34,189 Thanks
  • 43,310 posts
Posted April 17, 2017 - 05:41 PM
This
Plus this
Equals this
Eric
It helps to be able to steer while plowing!
  • dropped82 said thank you
#2419 MH81 OFFLINE
  • 29,899 Thanks
  • 29,726 posts
Posted April 18, 2017 - 03:37 AM
Figured out why drive belt was slipping occasionally on Moms older mower. Idler on belt clutching sticking + belt worn and longer than it should be + Murphy's law= intermittent reduction in power to the point it wouldn't climb a hill.
Replaced bad idler with one from something else (modifications needed) and will be ordering new belt tomorrow nite.
  • MFDAC and toppop52 have said thanks
#2420 KennyP ONLINE
  • 34,189 Thanks
  • 43,310 posts
Posted April 18, 2017 - 02:20 PM
I awoke the Allis 416S from it's slumber. Washed the top of the deck off and greased her up for future duties. It's running sweet as I could feel the exhaust hitting me 15' away at idle!
  • MFDAC and Mark 149 J. have said thanks
#2421 SimplyRad OFFLINE
SimplyRad
  • 724 Thanks
  • 595 posts
Posted April 19, 2017 - 07:52 AM
Not my tractor but my ZT 2242. I have a few wet spots in the yard that I seem to always get stuck in so I went to my favorite tire dealer and got a pair of ags for it.
I also swapped mower decks on my 7112. Had the deck that is set as high it will go and put on one set at a normal height.
#2422 toppop52 OFFLINE
toppop52
  • 4,566 Thanks
  • 4,282 posts
Posted April 19, 2017 - 09:08 AM
attachicon.gifDSC_0175.JPG attachicon.gifDSC_0177.JPG attachicon.gifDSC_0178.JPG
Let me know how the AGW work on the ZTR.
#2423 SimplyRad OFFLINE
SimplyRad
  • 724 Thanks
  • 595 posts
Posted April 19, 2017 - 09:11 AM
I mowed with it after installing and it ran great. Didn't have any trouble knowing where I had mowed on short grass.
  • toppop52 said thank you
#2424 TAHOE ONLINE
TAHOE
  • 7,596 Thanks
  • 5,516 posts
Posted April 19, 2017 - 12:01 PM
We have a set of ags on the Grasshopper at the church, it's a must or we would end up in the pond. Doesn't leave any marks on the lawn unless you hammer down or spin it around.
#2425 SimplyRad OFFLINE
SimplyRad
  • 724 Thanks
  • 595 posts
Posted April 20, 2017 - 10:36 AM
I got my starter for my Simplicity chipper/shredder made yesterday and it works. Used a socket and a 1/2" carriage bolt and nut. Ground the head down to fit inside the socket, add the nut and lock washer, chuck in drill and start the engine.
  • limebuzz, Alc, KennyP and 2 others have said thanks
#2426 Alc ONLINE
  • 6,310 Thanks
  • 7,150 posts
Posted April 21, 2017 - 07:45 AM
Years ago I needed a valve for the outriggers on the Pippin Backhoe mounted on the Ford 3400 , the only one I had ( free lol)  was a 3 spool with no pressure relief in it , it was OK if you were VERY CARFUL when using the outriggers but since this tractor  is heading to my son's house and a good change he'll use it I didn't want to take a chance him deadheading the pump and breaking something . I installing a 4 spool valve with relief in it . the 2 outside spools with be for the outriggers , I put a detent on one of the middle spools with plans of running quick couplers off that , the other could be used if I ever build a hydraulic thumb  .
  • KennyP, MFDAC, toppop52 and 1 other said thanks
#2427 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,487 Thanks
  • 915 posts
Posted April 23, 2017 - 06:36 PM
I put a new seat on the Cub 1811 today.  I found the seat at our local supply store the other day while walking around with my kids.  I was very surprised to see it there and the price was even reasonable at $70.  I also adjusted the high and low idle screws on the carb.  The high was a little rich and the low was to lean and would die.  She runs good now!
I went a little crazy with the camera so here are a bunch more pictures include some with my dogs!
20170423_160156.jpg 20170423_160211.jpg 20170423_160230.jpg 20170423_160243.jpg 20170423_160947.jpg 20170423_160958.jpg 20170423_161048.jpg 20170423_161057.jpg
I've only owned this tractor for 8 months and I really enjoy it!
  • KennyP, Newpaws493 and dropped82 have said thanks
#2428 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted April 23, 2017 - 09:53 PM
attachicon.gif20170423_160156.jpgattachicon.gif20170423_160211.jpgattachicon.gif20170423_160230.jpgattachicon.gif20170423_160243.jpgattachicon.gif20170423_160947.jpgattachicon.gif20170423_160958.jpgattachicon.gif20170423_161048.jpgattachicon.gif20170423_161057.jpg
Is there a brand on that seat? Matches my Massey 214gtx exactly and it needs one.
Eric
  • Mark 149 J. said thank you
#2429 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,487 Thanks
  • 915 posts
Posted April 23, 2017 - 09:59 PM
Eric
No brand label on the seat.  All it had was a price sticker.
#2430 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,487 Thanks
  • 915 posts
Posted April 23, 2017 - 10:02 PM
The paint job on the Ford looks good.  Hopefully the tractor will return back to you with everything in order!
