* * * * * 1 votes
2492 replies to this topic
#2341 toppop52 OFFLINE
toppop52
  • 4,566 Thanks
  • 4,282 posts
Posted January 31, 2017 - 11:11 AM
This post is more like "what did you do FOR your tractor today"---LOL! I finally started getting rid of some junk like an old refrigerator that was a paint storage cabinet so I could move a particle board cabinet where it was. There was one more old computer hutch beside it that I had junk stored in that had to go too, so more crap for a dump run. That opened up a hole big enough where the 12G can park by the shop wall instead of in front of my welding table. I know some of the junk going to the dump will be needed soon as it's unloaded but it has to go! I need the room!
DAC
If you need more room, call me, I'll come move the Blazer for you! :D
  • MFDAC and holdenboy1960 have said thanks
#2342 MFDAC OFFLINE
MFDAC
  • 2,785 Thanks
  • 1,418 posts
Posted January 31, 2017 - 08:34 PM
Ahh you wouldn't want it---it's a GMC Jimmy not a Blazer---LOL! It's got twice as many headlights as a Blazer! I forgot to say last night to that I found "Billy Big mouth Bass" in that computer hutch that had to be disposed of! There was a thread somewhere on this forum  a while back where that subject came up and "Bones" was all I could find then. I guess there needs to be some space on the wall made to hang these wonderful mounts!
DAC
  • KennyP, toppop52 and holdenboy1960 have said thanks
#2343 bob jackson OFFLINE
bob jackson
  • 47 Thanks
  • 14 posts
Posted January 31, 2017 - 09:36 PM
i have one of those fish, grandkids never get tired of , take me to the river.
#2344 bob jackson OFFLINE
bob jackson
  • 47 Thanks
  • 14 posts
Posted January 31, 2017 - 09:38 PM
put some decals on the jake today but they went on well. love the quality and color. thanks texas.jake2 003.JPG
  • MFDAC, Jazz and holdenboy1960 have said thanks
#2345 toppop52 OFFLINE
toppop52
  • 4,566 Thanks
  • 4,282 posts
Posted January 31, 2017 - 09:56 PM
DAC
I actually thought about it being Jimmy before I posted, I like that front better anyway!
#2346 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted February 06, 2017 - 10:49 PM
Finished plumbing the 3 point on the 69 Case 444. It's all ready to turn some dirt now. I broke one line so it's plugged up until I get to rural king and grab another. That's ok though, 3 point is good. That line was for the mid lift.
Then proceeded to work on the Massey 214gtx. I had some wiring to do. PO decided to get a little crazy with the wire snips when the pto switch quit. Got it all repaired and ready to connect the new switch in when it shows up. Unfortunately the 2 connectors were nowhere to be found. Will just use spade terminals. I've studied the wiring diagram pretty hard and now know what every wire you see is. My head hurts haha.
  • limebuzz, KennyP, holdenboy1960 and 1 other said thanks
#2347 skyrydr2 OFFLINE
  • 3,814 Thanks
  • 3,361 posts
Posted February 10, 2017 - 07:29 AM
HAVING A STROKE! Last night and yesterday we got snow!3"an hour!I'm thinking I got this in the bag.... NOT! Get home.. dragging bottom on my 2016 Silverado in the snow...
Anyways tractor fires right up and off we go.. slow because the stuff is deep! Get the front of the garage opened up no problem.. just turn to head down the drive and ... nothing.. engine running tractor driving but no blower.. hmmm belt failed or came off?? NOPE.. MUCH WORSE... PTO CAME OFF SHAFT AND ALL... oh no! Now What Im thinking? Seems the metal failed on the crank adapter. Well pull it in the shed crank up the heat and take it apart. No way to fix this at home.. so back to work I go...at 70mph no traffic..just snow.. that new Chevy is AWSOME! Get to work,1 hour later i have the shaft adapter all fixed better than before and head home... you guessed it.. 70mph. Yup get it on in a rush and it wont even turn..doh.. take it back apart to see why.. reassemble methodically this time.. and success! It actually runs truer than before! Whew! Finished the drive at 7pm last night... I'm beat today from stressing out over this .. but I fixed it and finished the job at hand.. dang.I hate when things go bad at the worst possible times..
  • jhn9840, KennyP, EricR and 1 other said thanks
#2348 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,369 Thanks
  • 4,079 posts
Posted February 10, 2017 - 07:40 PM
Sounds like the time BMP blew a belt and ripped the wires out of the PTO, After doing surgery with a dermal and JB I was able to fix it.
I wasn't pressed like you were, I had backup mowers.
Good job on the repair, Better than new is always good!
  • skyrydr2 and holdenboy1960 have said thanks
#2349 holdenboy1960 OFFLINE
holdenboy1960
  • 1,747 Thanks
  • 939 posts
Posted February 11, 2017 - 09:33 AM
replaced a front tire tube on the JD Sabre also removed the hood from it as it kept unclipping itself and partially coming off
, replaced 2 front tires on the Rover rancher 2 ( using some old tires that's been stored for a long time in a shed , use them up to make room for other stuff )
, reset the chain tension on 2nd reduction before the g/box on the home made tractor , and checked all the tire pressures were right.
Shane
  • KennyP and MFDAC have said thanks
#2350 nitro OFFLINE
nitro
  • 170 Thanks
  • 113 posts
Posted February 12, 2017 - 05:00 PM
Washer fluid was on sale at TSC.  Bought two cases, so since it was still early I went ahead and mounted the 23/8.50/12 Deestones I got on Ebay from Cleveland a month ago ($100 for the pair).  My trusty Harbor Freight tire changer sat this one out, I pulled the anchors out of the floor dismounting tires from the Suburban last year and never replaced them yet, and I didn't want to wake the 1450 that is sitting over the holes.  I started in the trucking industry busting tires in Alaska in the snow, so I figured I'd just mount them by hand.  I did eventually get them mounted using vice grips, a pry bar and lots of Dawn (and a whole bag of cuss words), but not after I found out that I'm far past 25 all of a sudden.  Forgot to take pics of that part.
Once I found my lawn chair in the garage, I went ahead and loaded the ags (and I loaded the mechanic a little too).  Quick review of the 1/6 horse pump at Harbor Freight:  this one worked, for around $50, and I can use it for other stuff.  The adapter was something like eight bucks on Amazon and the washer fluid was two for $3.
I decided to mount the weights on the inside, but I can't remember why.  All carriage bolts at TSC are $2.19 a pound, so when you see "wheel weight bolts" for sale for $20 don't buy them.  They are standard 1/2" carriage bolts and are available in any length you want in increments of half an inch.  To mount these I needed 3.5" bolts, which took me two trips because I somehow lost the ability to do math these days.
Everybody's favorite question about tires deal with measurements.  I did not measure them, but I did eyeball them against the old Goodyear turfs that are probably original (taller) and the dirt tread type I run with the snow chains (shorter, also can't read the sidewall on the dirts anymore), so they are between what I've been running and should be fine for height.  they seem a little narrower but with 5.5 gallons each and some weights I expect them to bite just fine.  I had one gallon left from a dozen.  Once I get my sleeve hitch adapter from Jeff in PA and some tuneup parts from David Kirk we will be in business for plow days!  See yinz there.
  • jhn9840, limebuzz, KennyP and 3 others have said thanks
#2351 bbuckler ONLINE
bbuckler
  • 2,836 Thanks
  • 2,510 posts
Posted February 13, 2017 - 04:43 PM
Fixed the fuel leak on the wheelhorse with a new fuel tank bushing and some new fuel line. Also I added another washer and a troy bilt belt to the troy bilt tiller to see if that fixes the problem
#2352 Greasy6020 OFFLINE
Greasy6020
  • 1,036 Thanks
  • 983 posts
Posted February 14, 2017 - 08:02 PM
Changed a headlight on the roper rt16
#2353 wbakunis OFFLINE
wbakunis
  • 194 Thanks
  • 172 posts
Posted February 18, 2017 - 07:19 PM
Learning how to weld so I wanted to Replicate a light bar for the Allis B10. Got three Blazer c123 tractor lights and wired them up. I need more metal to make a better rear light bracket. Lights are hooked directly to the battery. I figured hooking them to the regulator would burn it out.
Edited by wbakunis, February 18, 2017 - 07:21 PM.
  • KennyP and toppop52 have said thanks
#2354 SimplyRad OFFLINE
SimplyRad
  • 724 Thanks
  • 595 posts
Posted February 19, 2017 - 11:39 AM
I got the arbor for the deck of my 3410 rebuilt and installed . Now just need to remove the snow thrower from my 7112 to try it out, 3410 isn't running at this time. The nut looks like someone has done some not so good work on it in the past. One thing I have found out is the older I get the harder it is to torque to high specs. Called for 140 ft lbs but I could only get about 125 or 130.
The corners are rounded just a little.
Some of the damage.
Still need to find some orange paint.
#2355 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,369 Thanks
  • 4,079 posts
Posted February 19, 2017 - 06:51 PM
Adjusted the lift assist spring on BOH. Plan on carrying the deck and blade in the show next weekend and that put's a lot of pressure on the lift lever. It was a bear, but got it done.
