* * * * * 1 votes
2492 replies to this topic
#2326 Kster526 OFFLINE
Kster526
  • 590 Thanks
  • 369 posts
Posted January 21, 2017 - 09:03 PM
With the back wheels back on the 112 I had also threw a quick
coat on the fronts as they had been done before and just needed
some touching up.
Then to the slipping drive belt. After two hours of lubricating, adjusting trial and error decided
it's time for a set of new drive belts . So that's now tomorrow's chore. This has been
the never ending project since I bought it that's why it sat for two tears before I got back to it.
#2327 secondtry OFFLINE
secondtry
  • 1,112 Thanks
  • 920 posts
Posted January 21, 2017 - 09:26 PM
Last spring I went to the John Deere dealership  to buy new drive belts for my 112 and was really surprised  at how affordable they were. The old belts that came with the tractor were in terrible shape but still seemed to work fine. I was pushing dirt with the front blade when one disintegrated. I think I got lucky and the variator worked perfectly. Don
#2328 Kster526 OFFLINE
Kster526
  • 590 Thanks
  • 369 posts
Posted January 22, 2017 - 01:51 PM
Yes I could go on the flat but any incline with the extra weight of the tiller on
the back now made the drive. Let's just start slipping. Tried belt dressing and
several adjustment attempts but still didn't work. This thing has frustrated me since I bought
it but it's the closest to running and driving than ever. Just don't see to many for sale so
I really wanted to get it going. It's got new valves, cam, piston , points, coil, condenser
carbs been rebuilt and now new drive belts.
Luckily I live close to my parts and info supplier!and already had the belts here
I put them on today just need time to get the adjusted now.
#2329 Greasy6020 OFFLINE
Greasy6020
  • 1,036 Thanks
  • 983 posts
Posted January 22, 2017 - 01:59 PM
Tightened the hub set screws on the roper rt16...
Only found out they were loose because the rear tire slid in towards the tractor
#2330 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted January 24, 2017 - 02:24 PM
Moved a few machines out and got the 69 444 from the back. Tightened up a few hose clamps, bolted up the filled ags, and added the 3 point. When I get back from grabbing my kids, going to install new front wheel/tires. She's starting to look better.
Few pics of the ones I pulled out.
Eric
  • limebuzz, Alc, KennyP and 4 others have said thanks
#2331 Greasy6020 OFFLINE
Greasy6020
  • 1,036 Thanks
  • 983 posts
Posted January 24, 2017 - 04:24 PM
Same deal today...
#2332 MGP59DB OFFLINE
MGP59DB
  • 1,427 Thanks
  • 686 posts
Posted January 24, 2017 - 06:47 PM
I was wrenching on my Pick-up today , needed some new plugs and wires , trying to eliminate a periodic miss now and again.
I had to go into the garage for a tool , as busy as I was , I stopped and absorbed a little bit of 'Rusty' for a minute . :D
Made me think of the day I first rolled him out on his new shoes
We have come a long way !
  • KennyP, jpackard56, EricR and 2 others have said thanks
#2333 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted January 24, 2017 - 08:37 PM
That sir, is why we do what we do! Great pic, beautiful machine!
Eric
Sent from my iPad using Tapatalk
  • jpackard56, holdenboy1960 and MGP59DB have said thanks
#2334 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted January 24, 2017 - 10:58 PM
Maze some spacers for the axles and added some narrow front wheels and tires to my 69 444PK. Going to paint those rims once i get some tri rib tires for them soon. Only couple more things to do on her and it'll be ready to play.
Eric
PS: 1655 next to her makes the Case look kinda small haha.
Edited by dropped82, January 24, 2017 - 10:59 PM.
  • holdenboy1960 and MGP59DB have said thanks
#2335 TAHOE ONLINE
TAHOE
  • 7,596 Thanks
  • 5,516 posts
Posted January 25, 2017 - 07:33 AM
Yea like straighten that front drag link  :poke: :poke: :D
  • dropped82 said thank you
#2336 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,073 Thanks
  • 1,595 posts
Posted January 25, 2017 - 08:00 AM
That damage is before me. Looks like someone used it as a step.
Eric
#2337 holdenboy1960 OFFLINE
holdenboy1960
  • 1,747 Thanks
  • 939 posts
Posted January 27, 2017 - 08:09 AM
what i post here is over the last 8 weeks odd
home  made tractor bailed me would not start 20161006_130411.jpg striped the teeth of the plastic gear and was really hard to turn so i replaced it with a later model 1
20161006_130434.jpg this 1 is the replacement starter off a blown 13 hp engine i aquired
Shane
  • KennyP, jpackard56, dropped82 and 1 other said thanks
#2338 holdenboy1960 OFFLINE
holdenboy1960
  • 1,747 Thanks
  • 939 posts
Posted January 28, 2017 - 02:37 AM
another pre x/mas problem Rover Rancher 2 , idler shaft( counter shaft) in drive line started to collapse .  20161221_172338.jpg  20161221_172448.jpg
Nothing open to  get new bearings so up to the garden shed and raided the bearings container , found a couple good tidy bearings to replace  with ,
The bearing housing never had a grease nipple so i fitted the bottom bearing then filled the hub center with grease to lube the bottom bearing which works the hardest then reassembled .
Also few days later broke the main drive V belt on it & had to replace it too .
Shane
  • Alc, MFDAC, jpackard56 and 1 other said thanks
#2339 MFDAC OFFLINE
MFDAC
  • 2,785 Thanks
  • 1,418 posts
Posted January 30, 2017 - 10:37 PM
This post is more like "what did you do FOR your tractor today"---LOL! I finally started getting rid of some junk like an old refrigerator that was a paint storage cabinet so I could move a particle board cabinet where it was. There was one more old computer hutch beside it that I had junk stored in that had to go too, so more crap for a dump run. That opened up a hole big enough where the 12G can park by the shop wall instead of in front of my welding table. I know some of the junk going to the dump will be needed soon as it's unloaded but it has to go! I need the room!
DAC
  • limebuzz, KennyP, toppop52 and 1 other said thanks
#2340 nitro OFFLINE
nitro
  • 170 Thanks
  • 113 posts
Posted January 31, 2017 - 12:41 AM
Didn't do it TO a tractor yet, but I acquired a set of ags and a mold board plow recently. Gonna order the sleeve hitch soon. Finally going to make a plow day this year!
  • limebuzz, KennyP and holdenboy1960 have said thanks
