* * * * * 1 votes
2567 replies to this topic
#2311 shorty ONLINE
shorty
  • 4,987 Thanks
  • 5,036 posts
Posted December 21, 2016 - 01:19 PM
Broke the tradition last night. Started prepping the snow equipment without any snow flying.
  • toppop52, holdenboy1960 and Gillis.jim have said thanks
#2312 bob jackson OFFLINE
bob jackson
  • 47 Thanks
  • 14 posts
Posted January 04, 2017 - 08:29 PM
  • KennyP, toppop52, holdenboy1960 and 1 other said thanks
#2313 shorty ONLINE
shorty
  • 4,987 Thanks
  • 5,036 posts
Posted January 04, 2017 - 09:18 PM
And finished a week and a half later. Still with no snow.
  • KennyP and holdenboy1960 have said thanks
#2314 Greasy6020 ONLINE
Greasy6020
  • 1,308 Thanks
  • 1,273 posts
Posted January 05, 2017 - 02:44 AM
Slid out the hubs on the roper rt16 a while ago, put the snowblower lift mechanism on today... tomorrow I'll finish with putting the snowblower on
#2315 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted January 05, 2017 - 10:10 AM
Replaced the toggle switch for my winch on my snow plow, maybe just in time, supposed to be getting 2-3 " today.
#2316 toppop52 OFFLINE
toppop52
  • 4,910 Thanks
  • 4,564 posts
Posted January 05, 2017 - 11:12 AM
Topped off the hydro and worked on my rear blade plans.
#2317 wbakunis OFFLINE
wbakunis
  • 219 Thanks
  • 190 posts
Posted January 05, 2017 - 12:50 PM
Put new rear tires and tubes on "Bob" the Wonderboy 450
  • limebuzz, toppop52 and holdenboy1960 have said thanks
#2318 Greasy6020 ONLINE
Greasy6020
  • 1,308 Thanks
  • 1,273 posts
Posted January 05, 2017 - 04:40 PM
Finished putting the snowblower on the roper
#2319 MiCarl ONLINE
MiCarl
  • 1,834 Thanks
  • 992 posts
Posted January 06, 2017 - 11:54 AM
Several day project.
Doing maintenance on the Speedex 1631. Seemed to be leaking some oil from the output shaft on the transmission so I yanked it and got a new seal to put in.
Noticed the chain and transmission sprocket are well worn (transmission - > differential on this tractor is chain drive). McMaster has the chain and transmission sprocket on the shelf so I ordered those. I'm sure the differential sprocket has some wear too, but because it is so much larger not enough wear to be noticeable. Since replacing that would require some machining I'm leaving it alone. Hopefully the new chain and transmission sprocket will extend the life a LONG time.
I also ordered replacement brake pads for it (it's got a disc brake). The way the caliper mounts part of the pad is off the edge of the rotor and they wear funny. I was planning to shim the mount on reinstall but I noticed this morning that the mount bracket leans away from the rotor. I presume it came from the factory that way because there is really no way to bend it accidentally. I've got to decide whether to heat and bend the bracket or just shim the caliper.
Edited by MiCarl, January 06, 2017 - 02:27 PM.
#2320 shorty ONLINE
shorty
  • 4,987 Thanks
  • 5,036 posts
Posted January 06, 2017 - 04:51 PM
Tried to get a rough running Tecumseh to run smooth. Once again it got the best of me and I decided to wait for a warmer day.
#2321 toppop52 OFFLINE
toppop52
  • 4,910 Thanks
  • 4,564 posts
Posted January 06, 2017 - 11:02 PM
Worked on my front sleeve hitc, got it fitted up, just need to ream two frame holes to the pin size, and figure how I want to power it.
  • limebuzz, KennyP and backwoods have said thanks
#2322 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 08, 2017 - 09:44 PM
Starter has been squealing o the k series 16hp Kohler on the c160 snow blower rig. Hard to start too.
Pulled the starter and cleaned the commutator, oiled the bushings and used a center punch to swell the bushing on the bendix end.
Not a permanent fix, but a stop gap. Also set the points. Starts easier. They must've been at 25 or 30 thou
Yesterday, we pulled the rear end out of a b112 to replace the one in mine.
I horse traded for it and will be delivering the rest to its owner soon.
All this was in the garage. It was -2 in there yesterday morning... thank goodness for the torpedo heater. Got it up to 20.
  • limebuzz, KennyP, toppop52 and 1 other said thanks
#2323 Kster526 OFFLINE
Kster526
  • 772 Thanks
  • 511 posts
Posted January 09, 2017 - 07:49 AM
Installed the newly rebuilt generator/starter in the  67 JD RF 112  after having it rebuilt.  The first time that the tractor has been all together and in running condition since I purchased it 4 years ago.  Many issues had surrounded it when I bought it. I got real tired of constant problems,spending money and time on it so it was shun to the shed for two years.
  • limebuzz, MH81, backwoods and 1 other said thanks
#2324 Kster526 OFFLINE
Kster526
  • 772 Thanks
  • 511 posts
Posted January 15, 2017 - 04:08 PM
Continued working on the 67 RF 112 today. Painted the back wheels but may be rearranging wheels
With another RF and putting the tiller on back of this one Insted of the 110 it's on now.
It's the first time I used the TSC brand and the color called "New John Deere Yellow"
The colors matches very well with Mother Deere's and is much cheaper.
  • sacsr, MFDAC and holdenboy1960 have said thanks
#2325 shorty ONLINE
shorty
  • 4,987 Thanks
  • 5,036 posts
Posted January 21, 2017 - 08:40 PM
Helped my nephew with his Gravely 524 today. Had little to no spark. A bit of tweaking to the points and it drove away from us. Guess it was still in gear. Had a happy nephew then. He had been working on it for a bit.
