* * * * * 1 votes
2567 replies to this topic
#2296 MGP59DB OFFLINE
MGP59DB
  • 1,563 Thanks
  • 734 posts
Posted November 05, 2016 - 06:25 PM
I did some garage rearranging to get ready for winter , got Rusty's blade put on, found the chains , and ran the twins a little bit . :D
/\ They just look sooo Sexy :smilewink:  :thumbs:
Edited by MGP59DB, November 05, 2016 - 06:29 PM.
  • Bolens 1000 and holdenboy1960 have said thanks
#2297 KennyP ONLINE
  • 36,553 Thanks
  • 44,992 posts
Posted November 13, 2016 - 02:42 PM
While at the show last month I had two issues. I forgot the flags were sticking up and backed under the canopy. Broke both the wooden staffs on them. Went to Ace Hardware today and found some 5/16" by 36" aluminum rod. Cut it in two and rubber cemented the flags to that. I may bend them, but not break! Also, my caution light would not stay on it's mount, so I took some 1/2" strap and made a piece to keep it up there. Also gave me a place to put a small bungee over the top of it.
  • MFDAC, holdenboy1960 and Gillis.jim have said thanks
#2298 MFDAC ONLINE
MFDAC
  • 3,025 Thanks
  • 1,525 posts
Posted November 13, 2016 - 10:05 PM
It may not be needed as that was probably a rare circumstance breaking those flags off, Kenny, but maybe a local junkyard has some old truck and car radio antenna springs? Just a thought.
DAC
  • KennyP and holdenboy1960 have said thanks
#2299 MFDAC ONLINE
MFDAC
  • 3,025 Thanks
  • 1,525 posts
Posted November 13, 2016 - 10:20 PM
I finally accepted the fact that winter weather could happen any day and the forecast is saying possibly 4-6" Thursday afternoon and night with high winds. The 12G is now ready to start it's second winter of snow removal. I changed the gear lube, greased all the zirks, reversed the rear wheels, put the weights and chains on and mounted the blade this afternoon. The engine oil got changed a week or so ago.
Bring it on old man winter---we're ready again!
DAC
Edited by MFDAC, November 13, 2016 - 10:20 PM.
  • limebuzz, KennyP, holdenboy1960 and 1 other said thanks
#2300 KennyP ONLINE
  • 36,553 Thanks
  • 44,992 posts
Posted November 14, 2016 - 05:13 AM
DAC
I broke them backing under the canopy. Didn't realize they were that high. Going forward they were fine. Might be different with the aluminum rod!
  • MFDAC said thank you
#2301 toppop52 OFFLINE
toppop52
  • 4,910 Thanks
  • 4,564 posts
Posted November 14, 2016 - 11:22 AM
The tractor may get ready for winter, but not me!
  • Alc, KennyP, MFDAC and 2 others have said thanks
#2302 KennyP ONLINE
  • 36,553 Thanks
  • 44,992 posts
Posted November 14, 2016 - 12:01 PM
Amen to that!
  • toppop52 said thank you
#2303 Greasy6020 ONLINE
Greasy6020
  • 1,308 Thanks
  • 1,273 posts
Posted November 29, 2016 - 11:43 AM
the other day i put the jd 300 to sleep for the winter, and gave dad his battery back... also stole the battery from the craftsman, brought inside.
decided to find out if the roper/sears/moto mower would start in the cold and snow. cranks for a good 5 seconds, started right up.
#2304 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted November 29, 2016 - 08:17 PM
Tried to fix the intermittent spark problem on my snowblower and made it worse.
I'm going to give it another try tomorrow night when I can take it up and put it in the garage
#2305 switchman OFFLINE
switchman
  • 3 Thanks
  • 5 posts
Posted December 01, 2016 - 06:15 AM
yesterday put new bushings in front axle pivot on jacobsen 1650,made a big improvment in steering play.
  • KennyP and Gillis.jim have said thanks
#2306 toppop52 OFFLINE
toppop52
  • 4,910 Thanks
  • 4,564 posts
Posted December 01, 2016 - 12:29 PM
Started measuring for the front lift I'm going to build for the CC 3208.
  • Gillis.jim said thank you
#2307 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted December 09, 2016 - 09:28 AM
Finally tracked down the spark issue last nite on the snowblower.
I still don't know what I did to fix it, but it runs now.
#2308 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted December 09, 2016 - 12:18 PM
Took my winch mount into work so I could use the 4' pipe wrench and the big ole vise to straighten it out and re-weld. I misjudged one of my big corner fence posts back in the summer and caught it with the corner of my dump bucket. didn't seem that hard of a hit, but my gut jammed the steering wheel and I bent the lower arm mounts for the bucket/snow blade. Got'em all bent back close to original and welded up at work, snow is starting to fly :boo_hoo: :boo_hoo: :boo_hoo:
  • KennyP and toppop52 have said thanks
#2309 pryan05 OFFLINE
pryan05
    LGT
  • 596 Thanks
  • 330 posts
Posted December 15, 2016 - 04:31 PM
Chained up my LGT 145 and added oil to the differential as is has a slow leak.  Ready for the big snow falls.
#2310 WoodyChuck OFFLINE
WoodyChuck
  • 34 Thanks
  • 53 posts
Posted December 19, 2016 - 09:29 PM
Replaced the blade on a plow I got for my cub. Old bolts were half warn through I know I could have just flipped the old blade and used it again but I figured I might as well just start new
