* * * * * 1 votes
2632 replies to this topic
#2251 Xrperry ONLINE
Xrperry
  • 1,206 Thanks
  • 844 posts
Posted September 06, 2016 - 07:05 PM
I put the blade on the front of my Sears super 12 hydro and built a pair of running boards for my Montgomery wards 16 . It was missing the foot rests. this poor thing only pulls a garden cart so i dont see buying footrests for it. me and my friend took a couple pieces of catwalk? drilled holes thru the ends, run a piece of 1/2 rod all the way thru,made a few spacers, drilled out a piece of pipe to slip over pegs on tractor, welded it. all it takes to get the running boards off is to pull a cotter pin, pull out the rod and it all comes apart. didnt have to modify tractor
Edited by Xrperry, September 06, 2016 - 08:01 PM.
  • KennyP, holdenboy1960 and MrMarty51 have said thanks
#2252 MiCarl ONLINE
MiCarl
  • 2,219 Thanks
  • 1,129 posts
Posted September 06, 2016 - 08:39 PM
Nice job on the running boards.
Only problem is you made them so purdy now you have to paint the tractor.
  • holdenboy1960, MrMarty51 and Xrperry have said thanks
#2253 Xrperry ONLINE
Xrperry
  • 1,206 Thanks
  • 844 posts
Posted September 06, 2016 - 08:56 PM
thanks micarl. yea it could use some paint all right. or some dirt on running boards lol.
  • KennyP and holdenboy1960 have said thanks
#2254 SimplyRad ONLINE
SimplyRad
  • 1,369 Thanks
  • 981 posts
Posted September 07, 2016 - 10:43 AM
I bought a set of Craftsman wheel eights for $92.00. Thought I could sneak them on without the wife knowing but she is a smart cookie.
  • holdenboy1960 and MrMarty51 have said thanks
#2255 toppop52 OFFLINE
toppop52
  • 5,594 Thanks
  • 4,940 posts
Posted September 07, 2016 - 04:12 PM
Looked at it as I walked past!
  • holdenboy1960, MrMarty51 and MGP59DB have said thanks
#2256 MrMarty51 OFFLINE
MrMarty51
  • 141 Thanks
  • 105 posts
Posted September 30, 2016 - 07:41 AM
I have not been doing anything to the tractors. Instead I`ve been remodeling My dads old radio repair shop to store the tractors in, and the motorcicles too.
The walls were sagging and the floor was not, ro, the door would open only about 1/3 of the way. I jacked up the building, sawed out the old floor then jacked it up some more, made stilts from 2X8s and screwed them onto the corners and set the shed down onto them. Set up form boards and poured in a concrete floor, set the shed back down and bolted it into place. The door was then sawed out to make it into a 6 footer.
I had to remove the side boards so the finishers could get in there with the fresnos to do the finishing. The shed on the stilts with the concrete.
The bigger doors.
And one side finished. Except for the broken window. I got new glass cut for that yesterday.
  • Alc, KennyP, toppop52 and 2 others have said thanks
#2257 MrMarty51 OFFLINE
MrMarty51
  • 141 Thanks
  • 105 posts
Posted September 30, 2016 - 07:44 AM
OH, honest, the concrete finisher, standing behind the tree, honest, He is not doing what it appears like He might be doing. :rolling:  :rolling:  :rolling:
  • Alc, toppop52 and holdenboy1960 have said thanks
#2258 Greasy6020 OFFLINE
Greasy6020
  • 1,677 Thanks
  • 1,521 posts
Posted September 30, 2016 - 08:10 AM
Sure, sure he's not taking a leak...
#2259 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted September 30, 2016 - 08:53 AM
home made Tractor striped the 2nd reduction 2' pulley center out, the shaft lock studs must have come loose and the keyway tore the inner section out the pulley out
so i went too & replaced the 2nd reduction with sprockets and chain                     20160915_141839.jpg 20160915_141912.jpg
i also went to different sizes to get a little more reduction which worked out well ,
went from 10" pulley upto 11.1/2 " sprocket & 2 " pulley down to 1,3/4 sprocket
also made the chain tension unit manual adjust ,i am surprised how quiet the chain is when running
Shane
  • Alc, KennyP and MrMarty51 have said thanks
#2260 toppop52 OFFLINE
toppop52
  • 5,594 Thanks
  • 4,940 posts
Posted September 30, 2016 - 08:58 AM
Didn't do it today, but I welded the last brackets to the actuator powered sleeve hitch and bolted them to the frame of the tractor, just to make me feel better.
#2261 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted September 30, 2016 - 09:44 AM
M T D 2001 13 / 38 gold series maintenance , had the machine for approx 11 yrs now which has worked hard with very little maintenance
 i was down to 2 speeds in the forward & reverse system belts buggered , this is a pic of the donor machine  20160922_220007.jpg a MTD 1999 model regular 12/36 really good drive belts and good usable parts
changed both sets of steer linkage rods , & the 3 belts including the cutter drive belt , the drive belt pins & plate that stops the belt coming off the Engine pulley ,2 springs and the center variable pulley set , tightened the muffler bolts as it was loose
also replaced the plastic king pin bushes with full length steel type i made , and changed the bottom plastic bush on the steering wheel shaft ( down at the cog end ) i greased every part as required as i replaced them
changed RH king pin and tire & rim also as the bearings were done for on mine and tire was worn out to                               20160927_135800.jpg some of the parts i removed
and this is it finished and all cleaned and tidy except the hood i refitted that afterwards
Shane
  • Alc, KennyP, toppop52 and 1 other said thanks
#2262 MrMarty51 OFFLINE
MrMarty51
  • 141 Thanks
  • 105 posts
Posted September 30, 2016 - 05:59 PM
Finished the west end wall and the north side wall. Installed the new windows, new glass anyways.
Collected most of the tools and hauled them to the garage. Vacuumed the floor and run the tractors to their new home.
#2263 jhn9840 ONLINE
jhn9840
  • 483 Thanks
  • 411 posts
Posted September 30, 2016 - 09:41 PM
Nice size storage area. Can't beat that any day.
jhn9840
John
#2264 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted October 02, 2016 - 12:46 AM
the storage shed came up realy nice , job well done
Shane
#2265 MiCarl ONLINE
MiCarl
  • 2,219 Thanks
  • 1,129 posts
Posted October 02, 2016 - 03:45 PM
Finally bit the bullet and put some wheel weights on the rear.  I acquired a pair of Cross Creek 40lb weights made to fit a 16" front wheel.
The notches for the tire valve are in the wrong place for my wheels so I mounted on the inside.  The left one just clears the bull gear housing.
  • limebuzz, Alc, KennyP and 2 others have said thanks
