* * * * * 1 votes
2549 replies to this topic
#2221 Derby89r OFFLINE
Derby89r
  • 50 Thanks
  • 18 posts
Posted July 22, 2016 - 11:15 PM
Wored on my craftsman today. New drive belt and battery. Kept throwing the drive belt. Took the transaxle out and discovered the pulley wobbled. Took it off and the keyway and half moon key were badly worn. Tomorrow trip to the local garden equipment store for a new one. Then hopefully put this machine to work.
#2222 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted July 23, 2016 - 05:34 AM
Made a quick removal lift out weight rack for the home made tractor
weights are 65 lbs center mounted , just wanted a quick easy setup for the moment & can get another weight on either side if needed
Shane
  • MH81, KennyP, toppop52 and 1 other said thanks
#2223 lrhredjb ONLINE
lrhredjb
  • 559 Thanks
  • 487 posts
Posted July 25, 2016 - 12:52 PM
Last Friday I pulled the 42'' deck off my CC106 and pulled the blades, went over both sides of the blades with a heavy wire cup brush in the angle grinder to clean of the caked on dried grass and sharpened and balanced all three. Seems to run a little smoother now as the big middle blade was heavy on one end. These blades are carbide faced on the bottom so it didn't take much to sharpen them. I grazed the top of a water meter pit a while back and I was kind of wondering what shape they were in. Looked untouched to me, maybe the water meter pit top is lower now.
Edited by lrhredjb, July 25, 2016 - 12:53 PM.
  • jpackard56 and holdenboy1960 have said thanks
#2224 wbakunis ONLINE
wbakunis
  • 208 Thanks
  • 186 posts
Posted July 25, 2016 - 05:15 PM
Continued to work on the snowblower attachment for the landlord. Painted the chute and covers. Started cleaning the auger / blades. Found that one of the bearings is split so now I need to find a replacement.
EDIT: Aetna Bearing is still in operation and still make those bearings. I sent in a price quote for two bearings.
Edited by wbakunis, July 25, 2016 - 05:48 PM.
  • holdenboy1960 and dualresponse1731 have said thanks
#2225 Greasy6020 ONLINE
Greasy6020
  • 1,219 Thanks
  • 1,183 posts
Posted August 15, 2016 - 04:16 PM
Put new front tires on the Moto Mower, put the massey ferguson dozer blade on, took it off then drove around the yard
  • toppop52 said thank you
#2226 toppop52 ONLINE
toppop52
  • 4,724 Thanks
  • 4,447 posts
Posted August 15, 2016 - 08:14 PM
Started planning the rear hitch for the 3208.
  • Greasy6020 said thank you
#2227 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted August 21, 2016 - 01:29 AM
Broke my Tractor ,Rover Rancher 2 , i twisted a shaft off 20160819_153507.jpg                  20160819_153554.jpg
Had to V grind the shaft & weld & i put gussets on the shaft to the sprocket to reinforce it so it can't flex so much under stress
                        20160819_153525.jpg  then had to panel beat the brake rotor disc so as to re mount the brake calliper,
but i'm going to cut another shaft & remount the 2 sprockets on it  to get away from this repaired 1
Shane
  • jpackard56 and michael.kitko have said thanks
#2228 KennyP ONLINE
  • 35,103 Thanks
  • 44,122 posts
Posted August 21, 2016 - 03:37 AM
Ouch!
  • michael.kitko and holdenboy1960 have said thanks
#2229 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted August 21, 2016 - 06:21 AM
Ouch!
:yeah_that:
#2230 michael.kitko OFFLINE
michael.kitko
  • 504 Thanks
  • 461 posts
Posted August 21, 2016 - 03:55 PM
Broke my Tractor ,Rover Rancher 2 , i twisted a shaft off attachicon.gif20160819_153507.jpg attachicon.gif20160819_153554.jpg
attachicon.gif20160819_153525.jpg then had to panel beat the brake rotor disc so as to re mount the brake calliper,
Shane
Oi...
Mike "Squirrelly" Kitko
#2231 Greasy6020 ONLINE
Greasy6020
  • 1,219 Thanks
  • 1,183 posts
Posted August 24, 2016 - 04:52 PM
Made a long overdue oil change on the Moto Mower
#2232 chieffan OFFLINE
  • 8,802 Thanks
  • 6,035 posts
Posted August 24, 2016 - 06:05 PM
Swapped out a bad fuel pump for a new on in the Boles QT.  Now I need new needle and seat.
#2233 toppop52 ONLINE
toppop52
  • 4,724 Thanks
  • 4,447 posts
Posted August 24, 2016 - 08:44 PM
Changed the oil and filter on my CC 3208, worked on building the hitch for the rear.
#2234 wbakunis ONLINE
wbakunis
  • 208 Thanks
  • 186 posts
Posted August 25, 2016 - 03:19 PM
Tore down the snowplow I got with the Allis B10. Not sure if I should paint it AC Orange to match the landlord or AC Yellow to match the B10.
  • MH81, toppop52 and holdenboy1960 have said thanks
#2235 toppop52 ONLINE
toppop52
  • 4,724 Thanks
  • 4,447 posts
Posted August 25, 2016 - 08:38 PM
Started building the hitch for my CC 3208, didn't get much done, but know the direction now.
