* * * * * 1 votes
2584 replies to this topic
#2116 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 01, 2016 - 03:44 AM
sheared the wheel keyway on the Rancher 83 model left side axle and replaced the alloy 1 for a steel 1as it should have had all the time .
Checked all the bolts & bits on the home built Tractor , only 1 allen key screw was a tad loose on a pulley , Finished setting up the foot brakes too, (cable brakes )stainless steel cable & they are deadly sudden on the stop
Added grease & oil mix to the g/box on the Rancher 2 & set the drive chain & clutch belt tension as well, Tightened up the front end cradle pivot bolt as it was way loose
Shane
#2117 Dugmf12 OFFLINE
Dugmf12
  • 88 Thanks
  • 60 posts
Posted April 01, 2016 - 07:53 AM
Replaced front wheel bearings in the Massey 14.  The right wheel bearings came out in pieces! :tapping_fingers:
#2118 toppop52 OFFLINE
toppop52
  • 5,008 Thanks
  • 4,626 posts
Posted April 01, 2016 - 08:48 AM
Welded a a bucket rotating pin, and finally cut off the threads on that damn suicide knob bolt that kept cutting my hand!
  • limebuzz and holdenboy1960 have said thanks
#2119 KennyP OFFLINE
  • 37,377 Thanks
  • 45,437 posts
Posted April 09, 2016 - 08:33 PM
Got the JD 68 out and did an oil change. New battery too. Then took over to my daughters for them to use. Gas got some Seafoam and MMO. A little MMO in thje oil too since it has sat for a while!
#2120 Greasy6020 OFFLINE
Greasy6020
  • 1,374 Thanks
  • 1,331 posts
Posted April 09, 2016 - 10:38 PM
Cleaned up 3 bolt holes on the john deere 300 seat, accidentally stripped 4th hole.image.jpg
I also put the seat on and made motor sounds!
Another thing I did. Moto Mower 6020 axle seals are done. Gonna make new ones some time this week...
Edited by Greasy6020, April 09, 2016 - 10:40 PM.
  • Sawdust and holdenboy1960 have said thanks
#2121 Dugmf12 OFFLINE
Dugmf12
  • 88 Thanks
  • 60 posts
Posted April 10, 2016 - 08:12 AM
Made a front weight bracket for my Massey 14 since it was missing its original.  Waiting for warmer weather to prime/paint.  Also started rewiring the 14 as well.
#2122 toppop52 OFFLINE
toppop52
  • 5,008 Thanks
  • 4,626 posts
Posted April 10, 2016 - 10:03 AM
Patched a hose on the front end loader, they really need replacing and aren't that expensive.
#2123 MGP59DB OFFLINE
MGP59DB
  • 1,626 Thanks
  • 749 posts
Posted April 13, 2016 - 06:09 PM
Changed the oil and cleaned the fuel system on the Model 36 motor .
I started and drove Rusty , found out the clutch pulley was loose , so I wrenched it back into place and tightened the set screw. Took his chains off.
Started (turned the key :D ) and drove the SS12 around , parked it out front all day with a 4sale sign , just in case. :thumbs:
Also repurposed a rolling box frame into a rolling motor stand/table for the shop .
And took the wheel weights off of the SS12 to put onto Rusty.
Edited by MGP59DB, April 13, 2016 - 06:14 PM.
#2124 Fordman1955 OFFLINE
Fordman1955
  • 9 Thanks
  • 20 posts
Posted April 13, 2016 - 09:27 PM
Brought a lgt145 home today. Tried charging the battery. No luck. Pumped up tires to see if they will hold. More things to check tomorrow.
#2125 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 16, 2016 - 07:45 AM
replaced the uni balls on the steering rod on the Rancher 2, tightened up the centre cradle bolt on the front end , still got to weld up 1 of the wheel turn stopper blocks on it
took the cutter belt off the JD Sabre to replace when i can as it come off & took pieces out of it
otherwise just oil checks & the odd tyre pump up thing on a couple Machines , 83 Rover Rancher rider & the Toro XL440-h ,1 front tire on each Machine goes down over a week , i am still opting what grill to use on the home made tractor
Shane
#2126 Fordman1955 OFFLINE
Fordman1955
  • 9 Thanks
  • 20 posts
Posted April 16, 2016 - 08:51 PM
New battery in the lgt145. Runs with a lack of power. Checked the idle and main load jet. I backed the main load jet screw all the way out and never could get it to smoke (over fuel ). Making a list of things to check tomorrow. Painting the wheels on the cc782. Hope to get the tires back on next week.
#2127 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 19, 2016 - 06:04 PM
Blew a hydraulic line on the John Deere 300 so now the rear pan is off an.I'm trying to figure out how to get to the line but I managed to get the garden tilled first.
Sent from my SM-S820L using Tapatalk
#2128 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 19, 2016 - 07:15 PM
An here is the line that faught me to get out now the question to I get a factory replacement or get one an work?
Edited by backwoods, April 19, 2016 - 07:16 PM.
#2129 toppop52 OFFLINE
toppop52
  • 5,008 Thanks
  • 4,626 posts
Posted April 19, 2016 - 08:45 PM
I adjusted the valves on my recently required, very low hour Murray Garden tractor. The guy traded it back to me for an old invertor and a stainless gas grill I was going to toss out.
Edited by KennyP, April 23, 2016 - 05:47 AM.
Correct spelling
#2130 MrMarty51 OFFLINE
MrMarty51
  • 141 Thanks
  • 105 posts
Posted April 22, 2016 - 02:42 PM
Got the fuel system of the JD 110 back together. Dumped the crankcase full of 20-50 Harley oil, to use for a flush. Installed the battery, turned on the key, turned to start position, NADA, ZIP,  DEAD. Looking at the wiring, time to build a complete new wire harness.
Moved the tractor into the garage, got out of the sun, time for some fun.
I do enjoy building wiring harnesses, not at all intimidated with doing that, there was a time though;;;;;;;;;;;;;;;;; LOL
Edited by MrMarty51, April 22, 2016 - 04:55 PM.
  • backwoods and holdenboy1960 have said thanks
