* * * * * 1 votes
2500 replies to this topic
#196 Bolens 1000 OFFLINE
  • 14,220 Thanks
  • 17,846 posts
Posted January 17, 2011 - 01:45 PM
Today I Replaced the Belt on the Bolens 900
#197 olcowhand ONLINE
  • 38,060 Thanks
  • 30,459 posts
Posted January 17, 2011 - 06:34 PM
Worked a bit more on the JBI diesel project.
#198 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted January 24, 2011 - 10:04 AM
spent 5 hours saturday trying to get the Ford LGT 165 to run. It has spark, and fuel, compression feels alright. wont take off and come to life will just cough.
#199 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted January 24, 2011 - 12:10 PM
Today I was going to mount the linear actuator that I have on the 1220 to raise and lower implements. I hurt my shoulder at work and its been a little painful to do it manually. But I could not get it to work without cutting some tin...:mad2: And I'm not willing to do that so instead I mounted a ATV winch under the seat and ran the cable to the lift arm, It seems to work really well. I still need to tuck the wires away but here are some pics.100_2764.jpg Posted Image
#200 Bolens 1000 OFFLINE
  • 14,220 Thanks
  • 17,846 posts
Posted January 24, 2011 - 12:23 PM
Very Nice
That is alot better than manually lifting those Attachments!
#201 mjodrey OFFLINE
Posted January 24, 2011 - 12:48 PM
very nice
that is alot better than manually lifting those attachments!
ditto !!
#202 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted January 24, 2011 - 07:37 PM
I went out a played with this for a while today, its great I LOVE IT.... so much better than the manual lift, and all I had to buy was a couple crimp connectors had the winch sitting in the shop for the last few years. I'm really pleased with how it works. I will be sure to update any changes or problems I encounter.
#203 Tinkerer OFFLINE
Tinkerer
  • 18 Thanks
  • 200 posts
Posted January 24, 2011 - 10:47 PM
I like your method to raising and lowering your implements on your 1220. I am thinking that may be an inexpensive way to update my 1220 to make it easier to raise and lower the snowblower.
#204 Tinkerer OFFLINE
Tinkerer
  • 18 Thanks
  • 200 posts
Posted January 24, 2011 - 11:18 PM
Was wondering if you have down a compression test on it? It sounds like it wants to start but if it is lacking in compression then it won't draw in enough fuel/air mixture to run. When was the last time it ran? Maybe try a new spark plug. That is what I have to offer from what I can tell from your video. Good luck and keep us posted when you find out why it wouldn't start.
  • Chuck_050382 said thank you
#205 Bolens 1000 OFFLINE
  • 14,220 Thanks
  • 17,846 posts
Posted January 25, 2011 - 07:47 AM
Try taking out the spark plug and pouring a small amount of gas in the Sarkplug hole.
I know someone had a JD 318 and it sounded the same way. When they helped it out by adding gas to the sparkplug hole if fired right up and was fine after that.
#206 MH81 ONLINE
  • 29,923 Thanks
  • 29,745 posts
Posted January 25, 2011 - 08:13 AM
Sounds like you're blowing back thru the carb? That first set of noises i thought I heard a little blow back in there.
If compression checks out good... the only unmentioned thing I can think of is RPM on the starter, if the starter was turning over faster, it'd stay engaged a little longer & maybe let you get her running. I see battery cables in there, do you have a good battery to set in & try again?
#207 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted January 25, 2011 - 09:31 AM
Guys I posted more info in http://gardentractor...4270/#post40080 thanks for your suggestions.
#208 tractormike OFFLINE
tractormike
  • 165 Thanks
  • 1,488 posts
Posted January 29, 2011 - 10:36 AM
I got the bearings for my snowblower! I have the shop furnace running to warm the garage up and will be down there shortly to put it back together. The new bearings are just a tad bit thinner than the original. I think one or two 3/4 inch machinery washers should take up the extra space on the shaft. I'll let you know.
#209 MH81 ONLINE
  • 29,923 Thanks
  • 29,745 posts
Posted January 30, 2011 - 09:31 PM
Ryan & I got the last motor bolt in the MF10. We also finished installing the shifter.
Ever have a simple job that made itself much harder than it needed to be? :wallbanging:
After that, we filled the rear end up... 80/90 gear lube runs slow when cold.
Then we rigged up a gas can & started it up. I think the carb'll be fine but we need to adjust the belts as
the clutch won't & it won't go all the way into park yet. Time to read up.
#210 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted January 31, 2011 - 09:04 PM
I welded an old engine block to a bracket and bolted it to a tractor for weight. Then I started building a new snow plow for the tractor with the engine block. So now I have 2 plow tractors, one with a tranny for weight and one with an engine. Now to finish the second plow.
