* * * * * 1 votes
2567 replies to this topic
#2041 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,703 Thanks
  • 2,701 posts
Posted January 06, 2016 - 11:13 AM
nope, no pressure.  I work construction, on winter layoff, so I have the time to work on it.   Just sucks that it happened.  Old motor, was running good when I first got it.  I'm going to try welding the nuts on this morning, see what happens.  I have another 20 hp onan in the Sears FF, I only picked it up for the motor.  Three-spool hyd in the 420,versus single spool in the FF, so the 420 will run again.
Edited by Delmar, January 06, 2016 - 11:16 AM.
#2042 skyrydr2 OFFLINE
  • 3,862 Thanks
  • 3,399 posts
Posted January 09, 2016 - 05:26 PM
DOH!! Went out to clean my shed a bit before the big re wire of my Ford LGT 165 diesel when I noticed the charging system was acting funny, charge one minute, the next it was not?? Cleaned shed up so I could work, n d backed the Tractor back in. Got to looking at the charging system and noticed the 6 terminal plug had gotten burnt... So off to find a new connector.... Low and behold don'tiIfind one at the local CAP store. Went home and spliced it in. Thank god for the kubota manual in the manuals section, as i was able to figure out what went where, and even hooked up a charge lamp too, now ill know if i left the key on or not. Now it charges like a champ. But i still need to do the wiring revamp with new junctions and fused circuits. But that may need to wait, as a storms' a brewin for next week. And I need this rig ready to go.
  • limebuzz, KennyP and Rock farmer have said thanks
#2043 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,703 Thanks
  • 2,701 posts
Posted January 13, 2016 - 06:29 PM
I finished working on the broken bolts on the heads on the onan b48g motor on the 420.  The 'weld nuts onto the studs' method was a bust...so I drilled out the studs (all 4) and retapped them.    I cleaned out all the carbon and gunk in both heads, cleaned the intake and exhaust ports,  used new head gaskets, then put it all back together.  It fired right up.  I still have the original problem tho, surging.  can't figure that one out.  It isn't the carb float, I checked that.  getting enough gas in the carb.  I have to choke it some to keep it running smooth.
Edited by Delmar, January 13, 2016 - 06:30 PM.
#2044 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,753 Thanks
  • 4,299 posts
Posted January 13, 2016 - 07:06 PM
Air leaking around the throttle shaft bushings?
#2045 limebuzz OFFLINE
limebuzz
  • 961 Thanks
  • 951 posts
Posted January 13, 2016 - 07:49 PM
Could it be leaking air at the seam of the intake itself. It's a 2 piece intake and I have had one that was giving me trouble.
#2046 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,703 Thanks
  • 2,701 posts
Posted January 13, 2016 - 08:13 PM
Good suggestion. I will check that out. Thanks!
#2047 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted January 13, 2016 - 08:44 PM
Finally got to try out snow blower on the Ford LGT195. Works great. Cold, but works great.
http://gardentractor...owblower/page-4
#2048 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 14, 2016 - 09:26 PM
Put the new fuel pump in the Roper.
It's been hard to get the fuel in the carb as there were many times it wouldn't stay primed.
About 3 seconds, the fuel was in the carb and it starts like it should.
Wish I'd done this months ago.
  • limebuzz and MolonLabe have said thanks
#2049 Tecumseh power OFFLINE
Tecumseh power
  • 1,454 Thanks
  • 1,104 posts
Posted January 14, 2016 - 11:23 PM
Went from this, to this. Almost done
  • MH81, Alc and wvbuzzmaster have said thanks
#2050 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 16, 2016 - 08:58 PM
Really, really nice.
  • wvbuzzmaster and Tecumseh power have said thanks
#2051 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 16, 2016 - 08:59 PM
I put the brass float in the Onan in the Roper today.
Big difference.  Plastic one went in the trash.
Runs like it should now.
  • limebuzz and wvbuzzmaster have said thanks
#2052 shorty ONLINE
shorty
  • 4,975 Thanks
  • 5,033 posts
Posted January 16, 2016 - 09:36 PM
Finished building a three point box for the Gravely 18H. Planning to use it to haul the snowbloower to the neighbors.
  • limebuzz, wvbuzzmaster and MolonLabe have said thanks
#2053 CRFarnsworth ONLINE
CRFarnsworth
  • 4,524 Thanks
  • 2,083 posts
Posted January 16, 2016 - 09:56 PM
Did some work on the Amigo.  We managed to free up the transmission shifting components.  Rebuilt the driveshaft & installed an engine.  After testing the tranny function while on jack stands I actually got to drive this thing around the yard a little bit. Had to remove the hood and reinstall the seat.  I was impressed with how this trans/axle functions.  A very unique machine.     :thumbs:    Rick
  • MFDAC and MolonLabe have said thanks
#2054 70sgreatestrockbands@gmail OFFLINE
  • 8 Thanks
  • 25 posts
Posted January 20, 2016 - 07:37 PM
I built a back-up light. Here is a link to the design.        https://docs.google....0bsMIqCesk/edit
  • limebuzz and CRFarnsworth have said thanks
#2055 Greasy6020 ONLINE
Greasy6020
  • 1,307 Thanks
  • 1,268 posts
Posted January 21, 2016 - 06:11 PM
I re mounted the snow plow on the Moto Mower... After trying to put it on the craftsman unsuccessfully.
