* * * * * 1 votes
2500 replies to this topic
#1996 KennyP OFFLINE
  • 34,252 Thanks
  • 43,374 posts
Posted October 20, 2015 - 05:13 PM
Reworked the steering on the Sears DLT mower. Wanted to get pics, but the camera died! Hope to clean this thing up an make a few $ off it next Spring!
#1997 backwoods OFFLINE
backwoods
  • 2,574 Thanks
  • 2,791 posts
Posted October 20, 2015 - 08:54 PM
Not today but Saturday i paint the grill gloss black an painted the deere yellow.uploadfromtaptalk1445392416131.jpg
#1998 holdenboy1960 OFFLINE
holdenboy1960
  • 1,747 Thanks
  • 939 posts
Posted October 24, 2015 - 07:06 AM
done a toe-in on the Rover 2 , changed the front tyres to these P3080074.JPG
refitted the electric ram to the push blade which works better as i changed the purchase rate for quicker lifting & lowering & removed to nudge bar from the front
#1999 MGP59DB OFFLINE
MGP59DB
  • 1,429 Thanks
  • 687 posts
Posted October 28, 2015 - 09:38 AM
I just realized - I have never installed a set of chains on a tire , until today . I put some on 'Rusty's' other set of wheels for this winter.
I was a bit worried about the traction, it gets icy on the driveway . I found a good deal on a new set of chains sooo...
Edited by MGP59DB, October 28, 2015 - 04:13 PM.
#2000 chieffan ONLINE
  • 8,424 Thanks
  • 5,826 posts
Posted October 28, 2015 - 06:51 PM
Find you another set of chains and put a cross chain between the ones you have on the teractor now.  Those are vehicle chains.  For Gt's you need a cross chain on every other side link.  Remove your rubber chain tightener and tighten the chain up (after adding the extra cross chain) with the locking link.  Doing this will give you much better traction as you will have a cross bar on the surface all the time.  Been there, done that.  You are definitely on the right track by buying car chains and rebuilding them to fit your GT.  Good luck and hope you don't need them.
  • holdenboy1960 and MGP59DB have said thanks
#2001 chieffan ONLINE
  • 8,424 Thanks
  • 5,826 posts
Posted October 28, 2015 - 06:54 PM
Not much today.  Tried to figure out why I don't have any spark on a S14D.  Instructions for checking the stator and ignition module are not for the ones I have on this engine.  Wire color code is wrong.  Still sitting with no spark.
#2002 toppop52 ONLINE
toppop52
  • 4,589 Thanks
  • 4,296 posts
Posted October 29, 2015 - 06:33 AM
Pulled the carb off my 4041 loader last weekend to see why gas was running out of it like a river, float was filled with gas. Waiting a replacement.
#2003 steamer936 OFFLINE
steamer936
  • 111 Thanks
  • 67 posts
Posted October 29, 2015 - 11:38 AM
Not today but yesterday.....
The clutch assembly was removed for repair of the throw out forks. Prepareing for replacing of the clutch linings. Admired the new tires that came in for it.
#2004 holdenboy1960 OFFLINE
holdenboy1960
  • 1,747 Thanks
  • 939 posts
Posted October 31, 2015 - 10:54 AM
striped out this Rover i salvaged from the scrap yard last week & got some good parts from it including 3 pulley sets                   .P3160107.JPG
changed a tube in the rear left , replaced some bolts on the hood ,
repaired the gears on the starter & done some rewiring including where the previous owner pinched the headlight  power wire behind the starter mount ,
dug into my stuff & found a 11 HP cover for the engine
 done a toe-in on the wheels & reset the main steer rod too , adjusted the brake , replaced the throttle & governor unit on the side of the engine , tuned the carburetor ,
replaced the broken air filter housing unit ,changed 2 head bolts so to bolt the fuel tank mount on
Now it starts & runs good for a 1970's 10 HP point type engine
  • Alc and MolonLabe have said thanks
#2005 backwoods OFFLINE
backwoods
  • 2,574 Thanks
  • 2,791 posts
Posted October 31, 2015 - 12:23 PM
Hunted for the clutch disc for the tiller an found some at a local farm shop hoping next week I can go get them.
#2006 toppop52 ONLINE
toppop52
  • 4,589 Thanks
  • 4,296 posts
Posted October 31, 2015 - 09:24 PM
Put the carb back together using a Tecumseh float in my Onan Zenith carburetor, had to file float stop column a bit to allow for the slightly smaller center hole in the float, but works great. I'm back in the front end loader business!
  • MH81, Alc and holdenboy1960 have said thanks
#2007 holdenboy1960 OFFLINE
holdenboy1960
  • 1,747 Thanks
  • 939 posts
Posted November 01, 2015 - 06:34 AM
make do jobs always work better
  • toppop52 said thank you
#2008 637Yeoman ONLINE
637Yeoman
  • 1,543 Thanks
  • 1,250 posts
Posted November 02, 2015 - 03:37 PM
Put my ag tires, weights and the Plow on the 900 Today
any pics?
#2009 michael.kitko OFFLINE
michael.kitko
  • 498 Thanks
  • 459 posts
Posted November 06, 2015 - 06:23 PM
Did a fender swap and swapped tires for winter...now the 140 has some 26x12-12 on the rear and 18x8.5-10 on the front. Just looking into building a light bar and over the next week will be greasing and getting the 49 hooked up and greased. Oh, tried attaching the weights and need longer lag bolts.
#2010 MH81 ONLINE
  • 29,936 Thanks
  • 29,753 posts
Posted November 20, 2015 - 10:14 PM
Got the blower on the 19.9. Kind of a project, but worth it.
Also put the second weights on the rears. 240lbs in cast and almost that much in the seat. Hopefully, with chains, I can back up with the blower raised this year.
  • larrybl, limebuzz and holdenboy1960 have said thanks
