* * * * * 1 votes
2625 replies to this topic
#1981 karel OFFLINE
karel
  • 2,326 Thanks
  • 1,494 posts
Posted September 29, 2015 - 06:13 AM
#1982 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted October 02, 2015 - 09:19 AM
Figured out the 3pt hitch and hooked up the Titan trailer hitch.
  • toppop52, holdenboy1960 and MGP59DB have said thanks
#1983 MGP59DB OFFLINE
MGP59DB
  • 1,743 Thanks
  • 796 posts
Posted October 04, 2015 - 05:12 PM
I built a wooden box , that goes on top of the disc' - to throw rocks in for added weight if needed . Just for fun.
What you can't see is the new 'air-vane governor installed . My motor had mechanical , but my uncle fabricated an air-vane type just like the original . I put it on and it works great , I was worried because this engine had a tendency to race sometimes and the throttle was so close to the shifter so it was easy to hit by accident . It is nice to have a little more of a comfort level there. I don't want to blow it apart .
  • larrybl, KennyP, holdenboy1960 and 1 other said thanks
#1984 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,171 Thanks
  • 2,938 posts
Posted October 04, 2015 - 07:18 PM
I put a new fuel pump on the 318 today.  I used one of those mikuni types....I mounted it on the firewall and changed the length of the hoses.  works great.
Edited by Delmar, October 04, 2015 - 07:24 PM.
  • Alc, holdenboy1960 and backyardtinker have said thanks
#1985 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted October 09, 2015 - 08:01 PM
 I was cleaning up the garage this morning , what a mess . And came across the extra engine cover I got this winter for my tractor (I used the other for condition reasons) . A thought crossed my mind and the next thing I knew ... A 'Shop Clock' :smilewink:
I am obviously not a 'pin-striper' . That will need more work . :thumbs:
Oh ,  I did get all of the 'tags' put back on the attachments.
the cover clock looks kool
  • MGP59DB said thank you
#1986 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted October 09, 2015 - 08:09 PM
changed the carbie on the Rover as the mixture & metering jets were messed up some what .
but still running a bit odd , maybe the governor needs re setting a bit ,
but not sure on how to set them correctly ................briggs 10 HP vertical  ( black IC  engine )
#1987 karel OFFLINE
karel
  • 2,326 Thanks
  • 1,494 posts
Posted October 13, 2015 - 07:19 AM
new rears for the meteor
  • Alc, jpackard56 and holdenboy1960 have said thanks
#1988 thadscub OFFLINE
thadscub
  • 73 Thanks
  • 86 posts
Posted October 13, 2015 - 09:14 PM
replaced drivesshaft  and clutch added a creeper gear and put the snowplow on for the winter stuff
  • Alc and holdenboy1960 have said thanks
#1989 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted October 14, 2015 - 07:38 AM
Looks good :thumbs:
  • karel said thank you
#1990 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted October 14, 2015 - 06:45 PM
Started here
Fished new hose through here (tape over ends)
Finished here. Connections made after blowing high pressure air through to make sure no filings or grit from when parts store made up the hose.
Over view of unit.
6 and 2/3 quarts of Amsoil 5w-30 hyd-trans oil and it works like new. The only oil Ventrac uses is Amsoil, sure didn't want to chance mixing types or brands at this point.
Note: the dealer wanted $36.50 per quart for the oil and $104 for the hose... :loosing_it:
I bought the fluid direct from an Amsoil dealer for around $10 a quart and O'Reilys made the hose for a little less than $43
Last thing before coming in, I put the charger on the "O"
Man was it great to get out of the house and do something :dancingbanana:
  • Alc, KennyP, BNK and 1 other said thanks
#1991 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted October 15, 2015 - 11:03 PM
Changed the throttle & governor section on the Rover 10 HP because the governor was not working properly with the throttle ect ect
UPDATE ; Changed the throttle & governor section on the Rover 10 HP because the governor was not working properly with the throttle ect ect  & reset the governor ,so its working good now
#1992 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted October 16, 2015 - 03:53 AM
Went to pickup a yard-roller a few miles from our place. Sweet older gal asked my wife if I would get it out of her garage just before all the trouble started with my vision back in May. Well after some fiddling with the "O" the wife and I went over with the little trailer and pulled this very old yard-roller out, into trailer and back home. Man I just love the way these old Kohlers start, just a little rolling sound and away they go. All my newer stuff has this "cranky, whiny noise"
  • Alc, BNK and holdenboy1960 have said thanks
#1993 MH81 OFFLINE
  • 29,979 Thanks
Posted October 16, 2015 - 08:51 AM
Spent the last couple evenings getting the lighting on the MF165 back in order.
Tab broke off the switch, lots of little issues... One thing begets another sometimes.
#1994 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted October 17, 2015 - 05:17 PM
Well I I finished the cleanup of the free pusher an mowed the lawn with it. Next was on to the jd 300 it was running rough the last time in had it out so I cleaned the carb an adjusting screws now it won't start so the battery is on the charger while I warm up
#1995 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 558 Thanks
  • 321 posts
Posted October 18, 2015 - 07:09 AM
Put the freshly painted dash and side cover/belt guard on the 704 yesterday along with the dash decal and new choke and throttle cables.
Still have the fenders, tool box and steering wheel to finish but that's what winter is for around here.
