* * * * * 1 votes
2595 replies to this topic
#1966 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted September 11, 2015 - 07:39 PM
:urock:
I am restoring my 1970 Ford 120 Lawn tractor.  I stripped it down to the frame.  Every part will be stripped, primer 3 coats, Paint 3 coats, and clear coat 3 coats.  They then get polished and waxed.  See the frame and rear end pics attached.
Really nice! You guys are setting the bar really high for me......Gotta make sure I don't get spanked ;)
#1967 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted September 11, 2015 - 07:46 PM
Oh man hunting season is about to start around here and all you guys are doing really cool rebuilds and stuff to the tractors right now. They all look great. Maybe I'll hunt the morning and work on my tractor in the afternoon tomorrow. Decisions decisions...............
#1968 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted September 13, 2015 - 10:32 AM
Did more disassembly on the 5120H yesterday and flushed out the fuel tank which had about 12oz's or so of really bad gas in it. Used brake-kleen  for first round of flushing, then rinsed out with garden hose. Moved on to using some purple power degreaser and flushed again several times. Then put about 1/2 quart of acetone in and agitated awhile and dumped back into another container for future use. rinsed again and filled with about 1/2 quart or phosphoric acid and repeated previous process and did this for two rounds. Rinsed again and inspected inside of tank. Looks very clean from the few limited views I have access to. All the caked on crap that was visible before is gone and I dumped out a good amount of crud throughout the whole process. Will need to get a new fuel sender and fuel tank shut off with grommet. Other photos show some of the metal work that needs to be done.
Edited by backyardtinker, September 14, 2015 - 07:11 PM.
#1969 MGP59DB ONLINE
MGP59DB
  • 1,675 Thanks
  • 765 posts
Posted September 20, 2015 - 05:44 PM
I spent the entire weekend working on these attachments , blasting- priming -painting -wrenching . I just can't help it . Time off and all I do is work on this stuff.
#1970 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,994 Thanks
  • 4,411 posts
Posted September 20, 2015 - 05:52 PM
Sounds like my weekend. Waxing and detailing Old Girl and her attachments for the show next Month.
  • holdenboy1960 and MGP59DB have said thanks
#1971 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted September 23, 2015 - 06:32 AM
Tractor seat change for the better on the Rover Rancher
P2070005.JPG   I left the original rubber blocks there ,
just added proper spring mounts for more comfort as the rubber blocks were to hard ,
 and what a difference it made
#1972 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted September 24, 2015 - 06:38 AM
Looking great!
#1973 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted September 24, 2015 - 06:39 AM
Wow, that thing looks brand new!
  • larrybl said thank you
#1974 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted September 24, 2015 - 06:40 AM
attachicon.gifP2070005.JPG   I left the original rubber blocks there ,
Looks like it has a lot of cushion! Good for those long seat time days....
#1975 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted September 26, 2015 - 07:08 PM
Some metal repairs,media blasting and finally some paint on the Bolens 5120H. Did the metal repair two weeks ago, finished the blasting on about 3/4 of the frame/ dash tower, etc. today and put some color on it. This not a full restoration but it is a serious reconditioning. Hoping to have it running and usable for plowing this winter but it's a long shot. Still have my Craftsmen for plowing but it would be nice for me to have the two of them. One for me the other for my Son or Dad to use and get things done twice as fast or just one as a back up incase something unforeseen happens.
  When I installed the new section of steel in the floor section, I cut it to fit too snugly and there was a bit of warpage after welding it up. Had to cut a relief through the center and re-weld the relief cut back together to get rid of the bow.
tractor forum pics 003.JPG tractor forum pics 008.JPG tractor forum pics 009.JPG tractor forum pics 018.JPG tractor forum pics 022.JPG tractor forum pics 056.JPG tractor forum pics 055.JPG tractor forum pics 057.JPG tractor forum pics 059.JPG tractor forum pics 061.JPG
Edited by backyardtinker, September 26, 2015 - 07:11 PM.
#1976 MGP59DB ONLINE
MGP59DB
  • 1,675 Thanks
  • 765 posts
Posted September 27, 2015 - 10:12 AM
 I was cleaning up the garage this morning , what a mess . And came across the extra engine cover I got this winter for my tractor (I used the other for condition reasons) . A thought crossed my mind and the next thing I knew ... A 'Shop Clock' :smilewink:
I am obviously not a 'pin-striper' . That will need more work . :thumbs:
Oh ,  I did get all of the 'tags' put back on the attachments.
Edited by MGP59DB, September 27, 2015 - 10:17 AM.
  • KennyP, karel and backyardtinker have said thanks
#1977 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted September 27, 2015 - 05:43 PM
Love it!
  • MGP59DB said thank you
#1978 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted September 27, 2015 - 06:10 PM
More progress on the Bolens today. Unfortunately, I only noticed the needed repairs AFTER I painted it yesterday and it necessarily screwed up my paint job which now has to be retouched.  :wallbanging: I noticed the lift rod  brackets on the lift bar for the deck/dozer blade were all egged out where the lift rods attatch. Removed the lift bar assembly and flange bearings which one of those was also in rough shape as well. The ends of the lift bar were also galled up pretty bad and so were the bearing bores in the tractor frame as you can see in the pictures. Anyway, made the needed repairs by building up with weld and "re-machining" with the standard field expedient "machine shop" tools known as angle grinders, files, and pneumatic high speed de-burring/polishers. I make it a habit to never scrap all of my scrap metal and always keep "whatever looks handy" around. Found a piece of 3/16 flat stock in the scrap metal pile and made the two lower cradles for the lift bar bracket holes and cut out the bad areas and welded in the cradles to make a nice tight fitting hole for the lift rods. Since the brackets are 1/4 inch thick, I had to fill in the back side of the new piece with weld to build up to 1/4 inch level thickness
tractor forum pics 001.JPG tractor forum pics 002.JPG tractor forum pics 005.JPG tractor forum pics 008.JPG tractor forum pics 011.JPG tractor forum pics 012.JPG tractor forum pics 003.JPG tractor forum pics 004.JPG tractor forum pics 014.JPG tractor forum pics 015.JPG tractor forum pics 014.JPG tractor forum pics 018.JPG tractor forum pics 019.JPG tractor forum pics 020.JPG tractor forum pics 022.JPG tractor forum pics 017.JPG tractor forum pics 024.JPG
  • KennyP and MGP59DB have said thanks
#1979 MGP59DB ONLINE
MGP59DB
  • 1,675 Thanks
  • 765 posts
Posted September 27, 2015 - 06:31 PM
/\ That looks like a very nice repair !!
  • backyardtinker said thank you
#1980 Alc ONLINE
  • 6,885 Thanks
  • 7,460 posts
Posted September 29, 2015 - 05:40 AM
Since my wife scraped some paint off the back-hoe on the  now running Ford 3400 http://gardentractor.../48584-it-runs/ I thought it would be in my best interest if I primed and painted lol , Put some primer on Sun. so last night sprayed the hoe gloss black , using an old Sears ( siphon feed set up ) spray gun. It leaked , make that blowing , around the gasket for the canister  , I had the little valve screwed in so it wouldn't become a pressure feed ( never even tried using it that way )  wasn't until I was cleaning the gun and the big mess it made , that I saw that I forgot to put a little seat under the valve that shuts off the pressure to the canister :wallbanging:  :wallbanging: :wallbanging:   it was sitting on the work bench from when I cleaned the gun Sun .  , Still shouldn't have leaked so bad so will need to get a new gasket for it
