* * * * * 1 votes
2586 replies to this topic
#1876 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 30, 2015 - 03:09 PM
pulled the engine out of the B110 and cleaned out the mouse house and dirt . reconnected ,soldered and shrink tubed the magneto wire the po had cut .got it back in . found some mystery parts under the engine the cage nuts for the hood and the screw for the wire harness . and one two inch long L shaped bracket thats black . cant figure out where it goes .. under the left rear engine mount bolt maybe ? I did have to hold it down with a screw driver to tighten . it runs but I think it needs a condensor ( I can see sparks at the points and it missfires a tiny bit .
#1877 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 30, 2015 - 07:24 PM
altered the blade mounts & lift position & refitted it attachicon.gifPA040041.JPG {works better now & don't hit on the steering rod & cross member now
I like what you did there! Very cool!
#1878 MH81 OFFLINE
Posted June 06, 2015 - 06:03 AM
Was using the Roper 18T and discovered the hydropower loss issue I have been chasing.
I thought it was the pump, seems to be an intermittent slipping belt.
No squeal, not stalling the belt, just slowing under load.
Tightened and will try it tonight.
Also, changed the rear shoes on it and repaired a thorn puncture in the front tire/tube.
#1879 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted June 11, 2015 - 07:20 PM
blew a hydraulic hose on my L112 loader . so I replaced them all . now for the rams and pump .
  • toppop52 and holdenboy1960 have said thanks
#1880 Cat385B OFFLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted June 11, 2015 - 07:37 PM
Snapped a mower deck draft arm in half tonight, the ones on the G152 are home-made. Fired up the diesel generator/welder, and got it fixed. The generator battery had to be charged up, it's been since winter the last time that ran.
  • MH81, toppop52 and holdenboy1960 have said thanks
#1881 propane1 ONLINE
propane1
  • 8,482 Thanks
  • 4,041 posts
Posted June 11, 2015 - 08:34 PM
Cut the grass with the Jacobsen, after I put the 50" deck on it, tilled a garden with the MF 12, used the ford lgt 100 to haul stuff around. Fun day, Noel
#1882 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted June 12, 2015 - 05:39 AM
repairs on the go really suck some times
Cat385B  nice gen & welder kit
  • Cat385B and propane1 have said thanks
#1883 Cat385B OFFLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted June 12, 2015 - 08:50 AM
It's the house backup gennie, also. 8 1/2 hour run time per tank of fuel.
#1884 propane1 ONLINE
propane1
  • 8,482 Thanks
  • 4,041 posts
Posted June 12, 2015 - 09:03 PM
Sharpened the blades on the yt16h ford. Put a pto switchin the Jacobsen, repaired some loose bolts and nuts. Just like a Harley. Shakes it's self apart. Noel.
#1885 Cat385B OFFLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted June 13, 2015 - 10:38 AM
The weld on the mower deck draft arm is holding fine. Blew the lower radiator hose, though.
Three mowing machines, none currently operational. Yee-ha.
#1886 Cat385B OFFLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted June 13, 2015 - 02:13 PM
Found a hose that is close but bends the wrong way. Using a 1" x 3" coil spring inserted into the hose where it wants to collapse. Wish me luck!
#1887 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted June 13, 2015 - 07:13 PM
LUCK!
  • Cat385B said thank you
#1888 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted June 14, 2015 - 10:48 AM
you need to cut the hose & put a peace copper pipe & clamps in to it so you can turn the bend the right way round to stop hose stress
#1889 olcowhand ONLINE
  • 40,381 Thanks
  • 31,180 posts
Posted June 16, 2015 - 09:03 AM
While mowing my yard this morning, my pto locked & killed the engines.  I heard the pto belts squeal when it happened.  I took off the pto shaft to the deck & engaging the pto still kills the engine.  Apparently I have locked jack shaft bearings.  Not feeling quite up to getting into it right now, so I'll mow with the F935 till I'm up to it.
  • KennyP and holdenboy1960 have said thanks
#1890 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted June 19, 2015 - 06:56 PM
Many tasks today! Fixed the nieghbor's ride issue, made a stop for the band saw and got the Ford running good!
