* * * * * 1 votes
2585 replies to this topic
#1861 breimer OFFLINE
breimer
  • 132 Thanks
  • 164 posts
Posted May 15, 2015 - 10:21 PM
Put the dozer on the Ford 120 for the first time since i bought it today. Found that I was missing a lift link as well as some of the mechanism to angle the dozer. Manufactured the missing pieces from scrap metal I had laying around. Quite pleased with the results.
#1862 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted May 17, 2015 - 05:07 PM
ImageUploadedByTapatalk1431900433.068812.jpg ImageUploadedByTapatalk1431900444.855172.jpg ImageUploadedByTapatalk1431900455.838268.jpg
#1863 grnspot110 ONLINE
grnspot110
  • 4,105 Thanks
  • 2,624 posts
Posted May 17, 2015 - 06:38 PM
Oops!
#1864 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted May 17, 2015 - 09:16 PM
ImageUploadedByTapatalk1431915351.282979.jpg ImageUploadedByTapatalk1431915361.201468.jpg
My dad is painting the wheel now we got to do the other three to make them match.
#1865 chieffan ONLINE
  • 9,598 Thanks
  • 6,425 posts
Posted May 18, 2015 - 06:51 AM
Removed the drive shaft to replace the bearing.
#1866 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted May 19, 2015 - 04:51 PM
Finally got some time, without pouring rain. too get my hands dirty on the Springfield. Can't for the life of me see why it won't start. Time to start looking into ways to clean that tank.
Edited by Nxt2doc, May 19, 2015 - 05:26 PM.
#1867 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted May 19, 2015 - 05:05 PM
Fired up the Roper 20T's Onan for the first time after rebuilding it.
https://www.youtube....h?v=6m5CRK5diN8
https://www.youtube....h?v=9z8_naTVcEA
:dancingbanana:  :dancingbanana: :dancingbanana:  :dancingbanana:  :dancingbanana:  :dancingbanana:  :dancingbanana:  :dancingbanana:  :dancingbanana:
  • KennyP and holdenboy1960 have said thanks
#1868 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted May 19, 2015 - 07:16 PM
Just when I thought I could start saving some money the new tire tube has a hole in it.
#1869 KennyP ONLINE
  • 37,510 Thanks
  • 45,512 posts
Posted May 19, 2015 - 07:19 PM
Now that's a real bummer!
#1870 chieffan ONLINE
  • 9,598 Thanks
  • 6,425 posts
Posted May 19, 2015 - 07:45 PM
Started to change the muffler and get it in closer to the side of the engine.  Removed the brake assessable to put new pads on.  Measured the link belt to get the length that I need.  Engine change back down the road messed things up a little.
#1871 toppop52 OFFLINE
toppop52
  • 5,031 Thanks
  • 4,637 posts
Posted May 19, 2015 - 09:29 PM
Took the 48" deck off the 1920 Ultima, getting it ready for the hitch and bucket to come.
#1872 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted May 27, 2015 - 03:07 PM
The Springfield is running!!!!!!! Went outside with a can of WD40 and a toothbrush. Took off the carb and did a clean up job. put a little gas in the carb and it hit on the first pull. Washed some gas through the tank and washed the loose rust out. Hooked it all back up then two pulls and it was running. Hopped my ecstatic back side in the seat and took a few spins through the yard and in he street.
I was transported back in time before 1982 only I was the old man on the little tractor and Isabella was the wide eyed kid watching.
Its by no means all of the way right. It has a god awful vibration when I let the go pedal out. Still have to clean the tank right and that tired old motor is going to need a rebuild or maybe a repower since its not original anyway. It spit and sputtered, belched and farted but it ran. I couldn't have been happier if I was driving a $100,000 Lambo.
Edited by Nxt2doc, May 27, 2015 - 03:14 PM.
#1873 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 29, 2015 - 08:14 AM
altered the blade mounts & lift position & refitted it PA040041.JPG  {works better now & don't hit on the steering rod & cross member now
Edited by holdenboy1960, May 29, 2015 - 08:17 AM.
  • KennyP, FilledTires and toppop52 have said thanks
#1874 MH81 OFFLINE
Posted May 30, 2015 - 06:15 AM
Last night, I brought the derelict sears with the loader on it and with the kids help, pulled the loader off.
One of the PO's had permanently added weight to the back plate, so I will be making that into a removable piece on the next FEL tractor.
I've decided to put it on the Roper 18t unless there is a big unknown reason why I can't.
#1875 KennyP ONLINE
  • 37,510 Thanks
  • 45,512 posts
Posted May 30, 2015 - 08:18 AM
I would think it would work on there. Very similar to what it came off of.
