* * * * * 1 votes
2430 replies to this topic
#1846 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted April 23, 2015 - 08:19 AM
Smooth high quality auto grade enamel paint. I remove all the rust, Zinc Chromate as the primer / base, then Orr-Lac high gloss enamel.
Do you do any wet sanding or put a top coat on the enamel?
I'm thinking 3 coats of automotive enamel should hold up pretty well
#1847 trowel OFFLINE
trowel
    Summer.
  • 4,820 Thanks
  • 4,533 posts
Posted April 23, 2015 - 04:56 PM
Just as is with silicon sprayed on. Same with the snow blower and thrower.
Wet sanding would help more.
Edited by trowel, April 23, 2015 - 04:56 PM.
#1848 holdenboy1960 OFFLINE
holdenboy1960
  • 1,588 Thanks
  • 864 posts
Posted April 26, 2015 - 08:17 PM
pumped the tires up on the Toro XL-440H i just got yesterday off kerbside
#1849 HowardsMF155 ONLINE
  • 2,743 Thanks
  • 2,933 posts
Posted April 26, 2015 - 11:29 PM
Dropped a new battery in the Massey 8, old one had died.  Spent some time trying to work out how the charge must work on the replacement engine, but didn't finish hooking it up as I didn't have suitable wire for a connection.
Played chinese fire drill with tractors, re-arranging so I can get at the next one I want to work on.  Got a "refreshed" tecumseh for my 12 Hydro that has been smoking badly.
#1850 JohnDeere110 ONLINE
JohnDeere110
  • 167 Thanks
  • 77 posts
Posted April 27, 2015 - 03:28 PM
I got the air cleaner put on my 110
#1851 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted April 28, 2015 - 02:20 PM
Finished reassembling the Ford deck. Realized the enamel still isn't super hard after about a week of curing
  • Alc, KennyP and holdenboy1960 have said thanks
#1852 KennyP ONLINE
  • 32,189 Thanks
  • 42,011 posts
Posted April 28, 2015 - 07:25 PM
I got the Cub out of retirement and got it running again. Have an issue with connections at the switch, but a little wiggling and it takes right off. I forgot how much fun it is to drive! May have connection issues in the charging circuit also as the amp gauge isn't moving.
#1853 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 01, 2015 - 06:42 PM
well I broke my tiller  .... then I broke my lift cable... then I broke my electric lift .
so I robbed another tractor of its tiller and another of its cable and manual lift arm .
THAT WAS NOT FUN ! but I can curl a cow with my left hand .......good times :hitting_self_roller:
still better than owning that other brand of tractor ! :bigrofl: the not yellow or red kind
  • Alc and holdenboy1960 have said thanks
#1854 holdenboy1960 OFFLINE
holdenboy1960
  • 1,588 Thanks
  • 864 posts
Posted May 02, 2015 - 05:33 AM
did some wrenching during the week & made some addaptors for different wheels for my Rover rancher 2P9010162.JPG
the 1st pic is of the replacement wheels
the 2nd pic is the original wheels off the machine which is only 4x8 size the replacements are
8x18,1/2 x8 wheels , it altered the gear ratio minimal &  made heaps more traction
Edited by holdenboy1960, May 02, 2015 - 05:34 AM.
#1855 holdenboy1960 OFFLINE
holdenboy1960
  • 1,588 Thanks
  • 864 posts
Posted May 02, 2015 - 05:49 AM
MFDAC
nothing like a smoker engine , makes the real feel to ole stuff , the authentic appeal
#1856 holdenboy1960 OFFLINE
holdenboy1960
  • 1,588 Thanks
  • 864 posts
Posted May 02, 2015 - 05:55 AM
alec
the end result of success  to t/time is what it's all about ,
even if it means rob peter to fix paul & i'm sure we have all done it over time
  • Alc and alec have said thanks
#1857 Trav1s OFFLINE
Trav1s
    Got points?
  • 2,728 Thanks
  • 3,854 posts
Posted May 02, 2015 - 10:26 AM
Changed the oil and greased the 120 then moved onto oil changes for the push mowers.
Edited by Trav1s, May 02, 2015 - 10:26 AM.
#1858 JohnDeere110 ONLINE
JohnDeere110
  • 167 Thanks
  • 77 posts
Posted May 05, 2015 - 02:05 PM
I started to sand off some rust on the wheels on my 110
#1859 holdenboy1960 OFFLINE
holdenboy1960
  • 1,588 Thanks
  • 864 posts
Posted May 09, 2015 - 05:11 AM
P8300131.JPG this is a pic before .
i got a little bit talented , done some cosmetic touches P9220024.JPG , now it looks to flash for the tractor the paint colors are Machinery grey & new copper
Edited by holdenboy1960, May 10, 2015 - 06:09 AM.
#1860 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted May 12, 2015 - 06:45 PM
Rebuilt my landscape rake for my Ford LGT 145!
