* * * * * 1 votes
2595 replies to this topic
#1831 Sawdust ONLINE
Sawdust
  • 5,680 Thanks
  • 3,381 posts
Posted April 10, 2015 - 09:00 PM
I started tearing down my Tec HH120 on the MF12. I've had the tractor ready for paint since last Fall. I've been dreading the engine...a smoker last time it ran about 15 years ago :(
  • MFDAC, holdenboy1960 and larisaPn have said thanks
#1832 devans OFFLINE
devans
  • 371 Thanks
  • 257 posts
Posted April 11, 2015 - 09:34 PM
Scored a couple of forward facing Zenith carbs today for my '63 Gravely L8 walk behind and a hood too. Brought them into work with me, I have one carb torn down an in the dunk tank for a good cleaning. The other will follow.
The hood will go on another walk behind I have.
#1833 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 13, 2015 - 04:35 AM
In the last few weeks
greased the JD sabre & tailor & repaired the front Tyre ......tube was poking out lol
,tensioned the drive belts on the Rover Rancher 2 & removed the carry all & started to build a new tool bar for the Rancher 2
building a 3 tine ripper for the Rancher2 as well .it is partly built all ready ,  hopefully pic's on the weekend coming
#1834 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 13, 2015 - 04:40 AM
I guess I need a stronger grip! I'm also wrestling a pretty rusted pulley bolt
use a rattle gun , much easier & don't need to hold it mostly
#1835 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted April 13, 2015 - 05:10 AM
Grease up and run.
#1836 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted April 16, 2015 - 03:31 PM
Got two rusty old blades off and looking to refinish the bottom of my deck.
On a side note, one of the blades has two bolted on 'wings' and the other is just a regular blade. Of course, I took them both off without noticing which one went where. Would it make sense to have the 'winged' blade on the far end from the chute, and a regular blade closer to the chute?
#1837 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted April 17, 2015 - 03:35 AM
re:- would put the thrower blade nearest the chute to excel the exit throw
  • aevansgatech said thank you
#1838 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted April 17, 2015 - 08:45 AM
Thanks holden!
They're pretty dinged up, but I'm going to try grinding them down and sharpening this weekend
#1839 KennyP ONLINE
  • 38,496 Thanks
  • 45,981 posts
Posted April 18, 2015 - 05:32 AM
Actually, I was using the stupidest implement known to man. I caught some air with the front end coming out of the ditch and the pin rotated just right and got stuck under the axle. So I made half a round in trike mode.
I did that with the Jake 1450 & tiller. Wasn't even thinking about a wheelie, but that heavy tiller made her lift off real easy!
I had the FF out raking the back yard. We had let it get a bit out of hand as the male Rot has been digging to China back there chasing moles. We topped it off the other day and I wanted to get most of the excess cuttings raked off before rain hit. Then the FF starting it's 'hunting' again. Got real bad, so I brought it back up front to see what was wrong. Took the top off the carb and pulled the jets to clean it out. Found some crud in the bowl. Squirted that with carb cleaner and used a q-tip to clean that out. Sprayed down through all little holes to clean some more. Then came in to see what everything needed set at. This is a B48G Onan and the service manual is a bit vague on the carbs. Finally found the float setting for my carb and my float was way high. I reset everything and put it back together. A few adjustments to the jets and it purrs again.
#1840 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted April 18, 2015 - 06:31 AM
Yesterday,
My neighbor ran the Squire 9 and trailer cleaning up the yard.
#1841 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted April 18, 2015 - 06:53 PM
Sanded down my "new" deck as well as I could with a drill attached wire brush.
Knocked off 25 years of dirt, grass, and assorted animal poo and got it down to a fairly smooth but still rusted surface.
Rust reformer has been applied and tomorrow I should be able to prime with Rustoleum over rust and a gloss black enamel. Any recommendations on paints for the Underside of the deck?
  • trowel and holdenboy1960 have said thanks
#1842 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted April 18, 2015 - 07:17 PM
Smooth high quality auto grade enamel paint. I remove all the rust, Zinc Chromate as the primer / base, then Orr-Lac high gloss enamel.
Use Squire 9 and trailer to unload the 27 incher mower and transport to shop for assembly and prep for upcoming mow jobs.
Edited by trowel, April 18, 2015 - 07:18 PM.
  • holdenboy1960 and aevansgatech have said thanks
#1843 MFDAC OFFLINE
MFDAC
  • 3,215 Thanks
  • 1,586 posts
Posted April 19, 2015 - 10:06 PM
Even though the engine is a smoker it still runs great in the old MF12G, so I did the greasing, checked the gear lube, put the cutting deck back on. I also built a makeshift bushing for the front deck roller that was wobbly. It is ready to mow tomorrow if the darn wind will let up a little!
DAC
#1844 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 21, 2015 - 08:11 PM
I was working away at the sawmill, making some rough cut pine, and it
started to snow.
So, I said to myself, Enough.
Went to the shop, and took the snowblower off the MF1650.
Sorry if anyone else got the snow. I should have done that sooner.
  • KennyP, MFDAC and holdenboy1960 have said thanks
#1845 KennyP ONLINE
  • 38,496 Thanks
  • 45,981 posts
Posted April 22, 2015 - 08:25 AM
It's about time, Will!
