* * * * * 1 votes
2632 replies to this topic
#1771 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted November 21, 2014 - 06:17 PM
Today I got the starter genator on it an now my big ten is running like a top I even got some seat time pushing what little bit of snow was left in the drive way
  • Gabriel, BNK and holdenboy1960 have said thanks
#1772 KennyP ONLINE
  • 41,462 Thanks
  • 47,391 posts
Posted December 07, 2014 - 05:51 PM
Working on getting some paint on my grader blade. I have 4 pieces still on the tractor to take off yet. Might get some pics tomorrow!
#1773 toppop52 OFFLINE
toppop52
  • 5,594 Thanks
  • 4,940 posts
Posted December 07, 2014 - 08:09 PM
I adjusted the valves on my Murray today, 21 hp Briggs V twin, started it for the first time since summer, runs sooooo nice! Quite and smooth, no real use for it though, might sell it. Charged the battery and ran my Wizard front loader for a while, and took my grandson riding on my new Deutz 1920.
#1774 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted December 07, 2014 - 08:20 PM
New positive battery cable and cleaned out 23 years of gunk behind the instrument panel!
Also attempted to replace the ignition switch (not actually broken) but apparently the replacement part wasn't exactly right. Starting worked perfectly but turning the key to off didn't stop the engine. It kept on a tickin! Anyway, put back the old ignition since it wasn't broken and got my $10 back from the store 😬
#1775 Sawdust OFFLINE
Sawdust
  • 6,220 Thanks
  • 3,581 posts
Posted December 07, 2014 - 08:37 PM
Been repairing my plastic dash box on my MTD 990. A little plastic, JB weld, fiber glassing, some metal reinforceing, & some bondo to smooth everything out.
  • BNK and holdenboy1960 have said thanks
#1776 KennyP ONLINE
  • 41,462 Thanks
  • 47,391 posts
Posted December 08, 2014 - 05:07 PM
It got warm enough today to finish some paint work on the grader blade and the wheels I repaired.
  • Sawdust, Gabriel, BNK and 1 other said thanks
#1777 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted December 31, 2014 - 07:30 PM
Changed the seat on my MTD  2001 & replaced the front drive belt  & replaced the rhs cutter bearings + put a better seat on ,much more comfortable
repaired a tubeless tyre for the JD Sabre ( still got to change it yet )
#1778 olcowhand ONLINE
  • 43,145 Thanks
  • 32,005 posts
Posted December 31, 2014 - 07:52 PM
When changing light bulbs in the barn, I laid the light bulbs on the hood of Hogzilla.   Does that count?   :smilewink:
  • Sawdust and holdenboy1960 have said thanks
#1779 PGHsteelworker OFFLINE
PGHsteelworker
  • 96 Thanks
  • 55 posts
Posted December 31, 2014 - 08:45 PM
Put a set of heavier gauge stainless frame mounts on the 2182 super that I made from scrap pieces. The old set was .136" and the replacements are .210" thick stainless. The 5/8" attaching holes were getting egged out a bit.20141228_150217resize.jpg 20141228_150255resize.jpg
  • toppop52 and holdenboy1960 have said thanks
#1780 PGHsteelworker OFFLINE
PGHsteelworker
  • 96 Thanks
  • 55 posts
Posted January 04, 2015 - 08:40 PM
Put a Cub Cadet cab on the 2182 today.20150104_201206resize.jpg 20150104_201224resize.jpg 20150104_201601resize.jpg 20150104_201120resize.jpg
  • Alc, Gabriel and holdenboy1960 have said thanks
#1781 PGHsteelworker OFFLINE
PGHsteelworker
  • 96 Thanks
  • 55 posts
Posted January 04, 2015 - 08:51 PM
Had to tweak the rear brackets back straight and strengthen them by welding 3/8 square stock to the sides for the cab on the 2182 cub super.20150104_162745resize.jpg 20150104_162905resize.jpg
#1782 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 18, 2015 - 10:13 PM
This Garden tractor is a Rover , it has the rear 3 point linkage points & linkage bits under the front ,no clue to what year it is yet , 1st pic as i got it ,2nd pic is as far as i have got with fixing & making it & the 3rd pic is with a trial made carryall which works good but room for improvements.
list of repairs & maintenance done so far
1,change 3 tyres & 1 chube
2, changed 2 m/gear boxes to find a good 1 , the original was a 3 speed & the replacement is a 5 speed
3,straighten the LH stub axle
4, put temporary exhaust on but engine exhaust thread is nearly done for so used a light flex pipe
5,replaced original pad brake with a ride on mower disc brake rod pull type ( not hydraulic or cable )
6,put stainless steel dummy cover on bonnet (hood) just for a little style change
7,repaired fuel tank mount , cleaned inner tank , new fuel line & serviceable filter ,tank homemade cylinder type been modified to fit in front on engine ( previous owner made it )
8,tightened up front end cradle pivot
9,replaced the steering drag link to adjustable type for toe in
10,have another seat to fit yet
11,removed & greased front axles & bearings for future easy maintenance
12,the lift for the carryall is an electric worm thread  type (was 240 volt motor but refitted with an 12 volt motor) & the switch is out of an old style cordless drill with built in reverse ( Easy to fit & wire in )
  • Alc, Sawdust and BNK have said thanks
#1783 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2015 - 12:21 AM
UPDATE on my G/TRACTOR
forgot to put in, fitted the headlights & nudge bar and now done a bit more
1, replaced the engine cover & the safety mech on the flywheel
2, replaced the oil filler tube seal  12 HP IC engine B/S black
3, fitted a small front blade but no pic yet
#1784 shorty ONLINE
shorty
  • 5,919 Thanks
  • 5,452 posts
Posted January 24, 2015 - 05:01 AM
I got the fuel pump on the Gravely torn apart and diagnosed as worn out. As the snow was falling, I quick put it together again in hopes that it lasts for one more storm.
#1785 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 31, 2015 - 12:15 AM
you forgot the liquid nails glue lol
Edited by holdenboy1960, January 31, 2015 - 12:15 AM.
  • KennyP and Sawdust have said thanks
