* * * * * 1 votes
2549 replies to this topic
#1726 prosparky OFFLINE
prosparky
  • 2 Thanks
  • 8 posts
Posted July 22, 2014 - 07:19 PM
Bought 10' of 2" square tube 1/4" wall about a month ago for $64. Also picked up 10' of 2 1/2" square tube 1/4" wall for $75. Both were welded tube. Price of steel keeps climbing up here.
That's one reason I don't build half the things I want...too expensive !!
Sent from my SAMSUNG-SGH-I747 using Tapatalk
#1727 lyall OFFLINE
lyall
  • 1,905 Thanks
  • 1,488 posts
Posted July 23, 2014 - 09:20 PM
check the mower deck on my 214 (46" deck)
it was sounding different the last time I mower
had to replace 2 spindles bearings and the main drive spindle bearing
had to go to Deere for 2 more bearings for one of the spindles
cleaned up the desk so that I can put some Pur15 on the deck, starting to get rust
put the Pur15 on the underside and on top in the spindle area
the had a fun time removing the bearings of the spindles
clean up the spindles and pulleys and gave them a new coat of yellow paint
well put it all back together tomorrow, so the I can mower
I will repaint the deck this fall when the grass slow down from growing
#1728 Rock farmer OFFLINE
Rock farmer
  • 1,188 Thanks
  • 1,224 posts
Posted July 23, 2014 - 09:29 PM
I cleaned the spark plug.
Hey, it got it running again!
It may be a walk behind.
But, it's a powered walk behind!
Joe
  • propane1 and richwoodrocket have said thanks
#1729 twostep OFFLINE
twostep
    Rockstar
  • 1,937 Thanks
  • 2,515 posts
Posted July 23, 2014 - 09:59 PM
I thought the ice just melted at your place.  Is it time for winter again??
lol, there is only a few weeks gap between last and first...
#1730 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted August 12, 2014 - 04:58 PM
Yesterday, put the solid steel 90# weights back on the JD 140H3.  Today, pulled the fender pan to replace the broken right brake pedal.
  • twostep said thank you
#1731 Delmar ONLINE
Delmar
  • 2,619 Thanks
  • 2,627 posts
Posted August 13, 2014 - 09:36 AM
I got the carb. linkage in the mail yesterday from Joes Outdoor Power...Thanks Joe!   the W H Raider po was using a piece of 1/4-20 all thread filed down and bent in sort of a z-shape to hook up between the governor and carb.  Joe had the correct piece of linkage on his site and it worked like a champ.
  I also took the tiller off of the W H and got it listed on craigs...I have tillers on 2 tractors now and don't need a third. I had a hitch from another W H in the parts box in my shed so I put it the tractor....
#1732 JDGuy445 OFFLINE
JDGuy445
  • 356 Thanks
  • 428 posts
Posted August 31, 2014 - 07:54 PM
Not my own. Buddy of my brother owns a landscaping company so brought his push mower and two zero turns down to service and test them out. They sure are a nice cutting machine. Checked the bushings, changed oil, cleaned them off. Got them good and running condition. Afterwards gave the 345 a shower.
#1733 Trav1s ONLINE
Trav1s
    Got points?
  • 2,980 Thanks
  • 4,148 posts
Posted September 01, 2014 - 09:50 AM
Working on refinishing the seat pan for my 120 then will install a new seat cushion from Hapcoparts.
Working on repairing the hood for the 110.
#1734 Cub 1650 OFFLINE
Cub 1650
  • 158 Thanks
  • 98 posts
Posted September 06, 2014 - 06:32 AM
Started putting my 317 back together.
#1735 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted September 06, 2014 - 06:40 AM
Great looking JD.  It will be a winner when you are finished.
#1736 toppop52 OFFLINE
toppop52
  • 4,713 Thanks
  • 4,432 posts
Posted September 06, 2014 - 04:15 PM
Installed a second idler on my Simplicity/Craftsman zero turn, it gives me more belt adjust ability.
#1737 cumberland OFFLINE
cumberland
  • 26 Thanks
  • 68 posts
Posted September 06, 2014 - 06:14 PM
Replaced a PTO belt on cub GT2186, re tightened leaking oil filter the old belt knocked loose when it broke. Also fixed the headlights that had four broken & chewed wires.
Changed oil in a ford 841 powerMaster.
#1738 chad2198 OFFLINE
chad2198
  • 1 Thanks
  • 2 posts
Posted September 08, 2014 - 03:57 PM
Today I've been working on the adjustments for my drive belt on my Sears GT 16 Garden Tractor which is an 80's model.
Trying to fix the slipping problem. I drove it around the yard today and it slipped off again. I'm sure I'll get it fixed though. I enjoy working on garden tractors so I don't mind putting the belt back on the pulleys as it doesn't come off that often.
Chad
#1739 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted September 08, 2014 - 09:13 PM
got one side of tines off of my rototiller ( simplicity ) :wallbanging:  only bent the tine mounting plate a little :mad2:  I mean alot ! carrier bearings are crap chain is probably crap , its all rusted to crap and i just hope the gears are okay HAHAHAHAHA ! yea im not counting on it.
#1740 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 08, 2014 - 09:23 PM
I fixed the front end on one of my projects ImageUploadedByTapatalk1410229289.477633.jpg ImageUploadedByTapatalk1410229311.476114.jpg this was the bolt that had no but on it that was holding the front end together ImageUploadedByTapatalk1410229376.325704.jpg this is me the happy guy once the work was done
Tim
  • HowardsMF155 said thank you
