* * * * * 1 votes
2460 replies to this topic
#1696 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,157 Thanks
  • 1,330 posts
Posted June 05, 2014 - 06:12 AM
Looks like one of those oily mess oil filter change outs since it is bottoms up. :)  What do they recommend for oil and filter change  intervals with Mobil 1?
#1697 shorty ONLINE
shorty
  • 4,419 Thanks
  • 4,581 posts
Posted June 07, 2014 - 05:19 AM
Changed out the spindle bearings last night on the little LT. Got a few holes and cracks to deal with yet. The deck is just about done for, just hope to get a few more years out of it yet.
#1698 KennyP ONLINE
  • 32,733 Thanks
  • 42,339 posts
Posted June 07, 2014 - 06:45 AM
With the demise of the MTD mower, another machine needed to put in service. So I put the deck onto my #2 FF. First, I sharpened the blades and greased the spindles. Blades could use another sharpening, but I didn't want to get them too hot. Seems to mow well!
  • HowardsMF155 said thank you
#1699 Trav1s ONLINE
Trav1s
    Got points?
  • 2,792 Thanks
  • 3,923 posts
Posted June 07, 2014 - 07:40 AM
It was earlier this week but I put sharpened blades in the 120. Now it cuts grass!
#1700 KennyP ONLINE
  • 32,733 Thanks
  • 42,339 posts
Posted June 07, 2014 - 07:15 PM
The #2 FF needed the hydro fluid changed and a new filter. Spent most of the morning getting the drain plug out. They must have used a 10" cheater to put in in as I had to heat it to get it back out, Rounded the head. Tried welding a nut on it to back it out. Weld wouldn't stick to it. Had O'Reillys find filters for it (I thought). Ordered the Wix 51410's. That was wrong as they are for a 3/4-16 thread  screw on and the FF has a 1"-12 thread. Had to drive into Tulsa to NAPA for some 1259 filters. It's running again. Need to level the deck yet!
Edited by KennyP, June 08, 2014 - 05:38 PM.
Edit thread sizes
#1701 KennyP ONLINE
  • 32,733 Thanks
  • 42,339 posts
Posted June 08, 2014 - 05:40 PM
The rain let up a while ago, so I brought the Toro up to change it's hydro filter. Got it done & topped off. Then the #1 FF got it's turn. They all have fairly new fluid in them now.
#1702 prosparky OFFLINE
prosparky
  • 2 Thanks
  • 8 posts
Posted June 08, 2014 - 07:59 PM
It is a bit messy. The filter has a long service life, like 12000 miles. I don't know what this would equal in a small engine, but I'll change it once a year.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
  • GTTinkerer said thank you
#1703 KennyP ONLINE
  • 32,733 Thanks
  • 42,339 posts
Posted June 14, 2014 - 08:05 PM
Got the FF out and leveled the deck. Mowed for about 20 minutes and smelled a belt getting hot. Had a little smoke, but couldn't figure out where from. Mowed a bit more and it sounded like something was wrapped around a blade. Looked under and saw nothing. Finally gave up and pulled the deck back off. Took the cover off and the idler bearing had given out. Went to TSC and found an idler and deck belt. They didn't have a new PTO belt. I'll have to get it later on.
#1704 Natureboy OFFLINE
Natureboy
  • 76 Thanks
  • 90 posts
Posted June 16, 2014 - 04:21 PM
Got the hydraulic lift valve rebuilt in the S16H, reinstalled it and replaced 2 hydraulic hoses. Got one more small leak to chase down, I think its the park pin on the hydro.
#1705 trowel OFFLINE
trowel
    Summer.
  • 4,821 Thanks
  • 4,533 posts
Posted June 16, 2014 - 07:43 PM
Mow the grass.
#1706 FrozenInTime OFFLINE
FrozenInTime
  • 620 Thanks
  • 381 posts
Posted June 18, 2014 - 04:34 PM
Installed an elec. fuel pump from NAPA on my Snapper 1855A.  Sounds like the fuel starvation problem is gone, but still have small probs.  Anything over 1/2 throttle, most times runs great but occasionally will falter requiring throttle back then it straightens out.  Then it runs great again, sometimes for short periods, sometimes the rest of the day.  Strange
Also re-assembled the sno blo'r's gear box, attached to tractor and test'd good.  I can wait until winter to check it out in snow, I'm NOT in a hurry on this test..... LOL
Ordered new shoes all way round earlier.... can't wait!!
#1707 trowel OFFLINE
trowel
    Summer.
  • 4,821 Thanks
  • 4,533 posts
Posted June 21, 2014 - 05:03 PM
Squire 9,
clean deck, wash off tractor, remove and sharpen blades, grease all her nipples,........all of them :D ,....anyways,.. looks like mid-mount PTO drive belt is needed, will order that next week.
Mow with the Ariens a bit, sharpen the blade (it was very dull).
#1708 ranchruler@yahoo.com OFFLINE
  • 17 Thanks
  • 44 posts
Posted June 27, 2014 - 12:25 AM
Broke the crank on my tecumseh  :mad2:
#1709 prosparky OFFLINE
prosparky
  • 2 Thanks
  • 8 posts
Posted June 29, 2014 - 06:26 PM
I began fabricating a 2" hitch receiver mount on my Conquest. I don't need it to pull a trailer around with a ball, but I will use it to change from a small trailer (1/2" pin), to a shackle or hook for pulling my rock sled, to maybe a holder for shovels, to a weight plate bracket, or whatever else I can think of. I need to get some 2" square tubing so I can make some different things.
  • michael.kitko said thank you
#1710 michael.kitko OFFLINE
michael.kitko
  • 496 Thanks
  • 458 posts
Posted June 29, 2014 - 07:04 PM
Converted my JD 140 from the original 18w incandescent lights to 9w led lights...before, in-progress, and after included below...
Sent from my CAT B15 smartphone.
