* * * * * 1 votes
2595 replies to this topic
#1501 carolspain OFFLINE
carolspain
  • 12 Thanks
  • 14 posts
Posted August 25, 2013 - 12:02 PM
Underside powerwashing day on the Deere Sabre & 86 38" Craftsman. Then trying to work out B & S carb prob. on Craftsman, This wil make a full day
#1502 olcowhand ONLINE
  • 41,288 Thanks
  • 31,455 posts
Posted August 25, 2013 - 12:10 PM
Cleaned up the Massey "2055" in hopes of a sale.
  • Texas Deere and Horse and twostep have said thanks
#1503 Cat385B ONLINE
    HAZMAT CAT
  • 14,018 Thanks
  • 10,013 posts
Posted August 25, 2013 - 12:17 PM
And hooked a trailer to go buy a Pug?
If the wife asks, just say it really fast. She'll think you said pig or pup and give you her blessing.
#1504 olcowhand ONLINE
  • 41,288 Thanks
  • 31,455 posts
Posted August 25, 2013 - 12:22 PM
No, gonna pass on the Pug.  I have the money to buy it right now, but making room in the sheds & paying bills.  Once I get finished, I'll have plenty of room & sweat less every 1st of the month!
  • Sawdust said thank you
#1505 Texas Deere and Horse ONLINE
  • 14,815 Thanks
  • 15,502 posts
Posted August 25, 2013 - 12:37 PM
Well, after getting back from deployment, I have finally went and looked at my tractor in the garage. Bad news here. It ended up with me pulling the battery, pulling the battery tray, and making a paste of baking soda and water and slathering it everywhere. Yep, that is right, the JD Strongbox battery has been leaking for the last three months. Now, tomorrow, I have to correct the rest of that issue. I am starting to think the tractor wants a full restore. -Mike
Mike, Thank You for your service to our Country. Sorry to hear about the battery acid issue, I hope you got to it before it really did so damage.
#1506 Texas Deere and Horse ONLINE
  • 14,815 Thanks
  • 15,502 posts
Posted August 25, 2013 - 12:42 PM
Sure looks good Daniel, I always liked the way that Massey looked with that twin under the hood.
#1507 hatedge OFFLINE
hatedge
    Beer Guzzling Canuck
  • 292 Thanks
  • 577 posts
Posted August 26, 2013 - 04:15 PM
Today I sat down and watched the K 321 off the MF14. Must 've spent a good hour just sittin there watching and pondering about this and that. Eventually Idecided that since no-one on the forum had time to answer my question I would go ahead and take a chance to order the new piston. Hopefully it will be the right one. That woke me up and I closed back the engine and put it away to clear some room for more pressing matters.
#1508 JDGuy445 OFFLINE
JDGuy445
  • 356 Thanks
  • 428 posts
Posted August 30, 2013 - 05:00 PM
Put this on.
Edited by JDGuy445, August 30, 2013 - 05:08 PM.
#1509 DPike43 OFFLINE
DPike43
  • 28 Thanks
  • 24 posts
Posted September 18, 2013 - 01:27 AM
Today, I replaced the hydro charge pump on my 1978 John Deere 316. It only needed adjusting, but all kinds of stuff went wrong, that finally lead up to the whole pump being replaced.
#1510 KennyP ONLINE
  • 38,513 Thanks
  • 45,987 posts
Posted September 18, 2013 - 05:34 AM
In anticipation of the upcoming plow day, I greased the steering components on the FF. Made sure the front tires had the correct pressure to ease steering. Added another 4 of the 7 lb. window weights to my front basket (8 total for 56 lbs + basket at 10+/-).
Then got to looking at the headlights. Might need them! Light switch was there but no wires to it nor the headlights. Got out the meter after removing the switch. Had continuity through the switch, so I cleaned the connectors. Referred to the wiring diagram & sure enough, the hour meter had the wire there for the lights. Ran a wire to the switch, scarfed the headlight wire from the GTV/16 parts tractor & VIOLA! I have headlights. Pretty bright, too.
  • Newpaws493 and twostep have said thanks
#1511 KennyP ONLINE
  • 38,513 Thanks
  • 45,987 posts
Posted September 18, 2013 - 02:20 PM
Don't know if this is kosher or not, but I brought the trailer up and put the FF on the back with the plow hanging off. Set the sleeve hitch for a total 6" depth. I can work the rest with the depth control knob. Also adjusted the plow so it sets level at that depth. We'll see how that works til my 3-point plow arrives.
  • HowardsMF155 and twostep have said thanks
#1512 HowardsMF155 OFFLINE
  • 2,864 Thanks
  • 2,988 posts
Posted September 18, 2013 - 04:40 PM
Sounds like it should work quite well  :urock:
#1513 dropped82 ONLINE
dropped82
    Nut Case
  • 2,504 Thanks
  • 1,821 posts
Posted September 18, 2013 - 05:31 PM
Don't you hate it when you get something all painted and pretty then realize you still have to weld the nuts to it. Just finished doing what I hope is the last of the welding. Just removed the deck from my Case 226 and am in the process of mounting the sleeve hitch. Should be the last thing besides filling the tires that I need to do for plowing this fall. Oh and forgot about the wheel weights.
Eric
Sent from my SPH-D700 using Tapatalk 2
#1514 KennyP ONLINE
  • 38,513 Thanks
  • 45,987 posts
Posted September 18, 2013 - 05:43 PM
That's no fun at all! Especially if the paint turned out perfect!
  • dropped82 said thank you
#1515 dropped82 ONLINE
dropped82
    Nut Case
  • 2,504 Thanks
  • 1,821 posts
Posted September 18, 2013 - 05:46 PM
Luckily you guys won't see it at Daniel's. Unless of course your under my tractor! I'm coming with an unpainted hitch and weight bracket on one Case. Paint can come later.
Eric
  • olcowhand and KennyP have said thanks
