* * * * * 1 votes
2625 replies to this topic
#1 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted November 04, 2010 - 09:20 AM
My BIL had a good idea. Split "What Did You Do with Your Tractors Today" into two stickies, this one dealing with what you did TO your tractor (general service, repair, cosmetics), & the original sticky to what you did WITH your tractor, such as tilling, plowing, hauling, etc.
This will be a sister thread to the other, with this also being an infinite thread.
So tell us, What did you do TO (not with) your tractor today?
  • skunkhome, holdenboy1960, CharlesDes and 5 others have said thanks
#2 Bolens 1000 ONLINE
  • 15,421 Thanks
  • 18,279 posts
Posted November 04, 2010 - 09:21 AM
I plan on assembling the chute crank on the Bolens when I get home
#3 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted November 04, 2010 - 09:26 AM
Finished make a new rear PTO shaft to drive 40 GPM hydraulic pump with with one of the Masseys or Snappers for used oil pickup.
Right now I used a 5 GPM diaphragm pump. Trying to speed up the operation a bit
#4 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted November 04, 2010 - 09:28 AM
Just responded to a Craigs List listing for a FREE parts rig for the Sears SS16, hoping to hear that I can come get it for spares!!!
#5 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted November 04, 2010 - 09:36 AM
Yesterday I cleaned the crud off the fins on the hydro on the Ford LGT 165. Then I turned the tires around to check clearence.
The stock tire size is 23x10.5-12 and this tractor has 26x12-12 on it. So there wasn't a lot of clearence between the tire and the sleeve hitch lift bar.
here is a before.
after I turned them.
I will turning them back soon. I think they stick out to far like this. I will have to put the tires and wheels from the 145 on this one if I want to use the sleeve hitch and tire chains.
Also worked on freeing up the seat slide. Got it to slide some, but it won't lock in place so go up a hill or stab the forward pedal and you get that falling feeling as the seat slides back.
  • holdenboy1960 and 637Yeoman have said thanks
#6 harrycu OFFLINE
harrycu
  • 4 Thanks
  • 80 posts
Posted November 04, 2010 - 09:46 AM
Mounted my new Nanco 23x10.50x12 lugs onto my rims for the new JD212. Took them to a tire shop and had them mounted and filled for 25 bucks. Now, that's also my favorite way of fluid filling my tires. :laughingteeth:
Harry
#7 mjodrey OFFLINE
Posted November 04, 2010 - 10:22 AM
Harry
I bet they look sweet on there,did you take any pics ?
#8 harrycu OFFLINE
harrycu
  • 4 Thanks
  • 80 posts
Posted November 04, 2010 - 11:16 AM
No, not yet. I haven't mounted them on the tractor yet, either. It has been raining here, but it has stopped now. I am about to go out and work on it. I also have to mount my tri-ribs on the front and install my new motor mounts.
Harry
#9 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted November 04, 2010 - 05:09 PM
Cleaned up the 420 & 20 plow, put the plow away for the winter & changed the oil (& filter), & greased it. ~~ grnspot110
#10 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted November 04, 2010 - 06:49 PM
My JD 330 had a oversize battery in it when I got it that was sitting bout a inch higher on one side. Re-engineered (bent and beat flat) the original sides of the battery tray and then slit some old gas line to cover the edges of the top of the grill frame. Nice tight fit and setting level now...
#11 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted November 04, 2010 - 09:23 PM
On the AC B-10,
started reassembling the differential...
need one axle washer still
replaced one key in the bevel gearbox, reassembled and painted...
waiting on the last seal
cleaned, deburred and painted many parts
painted transmission... done
ground the rough edges to square and smooth on front weight plate,
painted... done
nearly finished preping the frame for paint
#12 harrycu OFFLINE
harrycu
  • 4 Thanks
  • 80 posts
Posted November 05, 2010 - 09:01 AM
Mounted my new ag tires on the JD212.
Finished installing new motor mounts and rear engine cradle.
Harry
#13 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted November 05, 2010 - 11:40 AM
Does working on GTT count as working on my tractor? Seems to be what I have been doing lately. Plus it is too cold out for me to really wanna go outside.
  • MH81, skunkhome, holdenboy1960 and 1 other said thanks
#14 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted November 05, 2010 - 12:11 PM
I've not had a true day off in over 2 weeks now, but plan to get shop time Sunday...my next day off. Gotta get my propane line hooked back up to the shop. Took that line off to side that side of the house. Gonna be pretty cool Sunday.
#15 Bolens 1000 ONLINE
  • 15,421 Thanks
  • 18,279 posts
Posted November 07, 2010 - 03:45 PM
Put my ag tires, weights and the Plow on the 900 Today
