Kohler 16Hp
This topic has been archived. This means that you cannot reply to this topic.
11 replies to this topic
#1 pharmer OFFLINE
pharmer
  • 821 Thanks
  • 748 posts
Posted June 04, 2013 - 05:33 PM
http://hartford.crai...3849538703.html
Good price on this one.
#2 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted June 04, 2013 - 10:24 PM
the same engine and pictures are listed in Springfield Missouri CL for 300.00 wonder if it's some kind of scam
#3 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 832 Thanks
  • 702 posts
Posted June 04, 2013 - 10:53 PM
muffler and square piece around tin almost looks like it came from a cub. and then given a spray -bomb "freshened up" engine
#4 chris m OFFLINE
chris m
  • 3,316 Thanks
  • 4,047 posts
Posted June 04, 2013 - 11:02 PM
He put that it was just freshened up at a motor shop, but then he put that it should run ok because it did a year ago. Also why would a motor shop work on this? it isn't electric, it is a gas engine. :D   :poke:
#5 jdslednut ONLINE
jdslednut
  • 677 Thanks
  • 846 posts
Posted June 05, 2013 - 12:43 AM
What does the outboard shop work on then? :D I see a whole bunch of discussion on this one.
#6 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted June 05, 2013 - 12:53 AM
It's a K341 AQS, but it looks to have the big cast iron pan that was on the Allis, Ariens/WheelHorse tractors, most other 16hp brands had gone to the aluminum oil pans with no balance gears and ISO mounts, EXCEPT the carb neck points up letting you know it was probably a service engine, that and the two funny brackets at the front. I doubt the output shaft would fit ANY tractor.
edit, also the solenoid is mounted to the engine, I've never seen that.
Edited by OkieGt, June 05, 2013 - 12:55 AM.
#7 chris m OFFLINE
chris m
  • 3,316 Thanks
  • 4,047 posts
Posted June 05, 2013 - 02:41 AM
Oh that's an easy one. They work on exterior boards only, like clapboards and pressure treated lumber. Some people confuse them with the Inboard guys.  But they only do interior finish work, like crown molding, chair rail and cabinets :rolling: :D
#8 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 11,824 Thanks
  • 8,938 posts
Posted June 05, 2013 - 06:45 AM
If it was on a cub, the shaft would point to the rear and the muffler would be on the back. Same for Case.
#9 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted June 05, 2013 - 07:45 AM
I dont think it was from any tractor
#10 Canawler OFFLINE
Canawler
  • 1,939 Thanks
  • 1,799 posts
Posted June 05, 2013 - 07:50 AM
The ad says it was from a Bobcat.
#11 pharmer OFFLINE
pharmer
  • 821 Thanks
  • 748 posts
Posted June 05, 2013 - 08:59 PM
That's what I read too.
#12 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted June 05, 2013 - 09:29 PM
Yeah, I went back and found where it said that, I missed it the first read, not unusual for my eyes, not to see everything the first time.
